11-26-2020, 09:42 PM | #1 |
1164
Rep 1,777
Is anyone else's auto-hold *too strong*?
I cant believe I never asked this before but on our g05, the auto-hold brake is very jerky from moving to stop, and then again from stop to moving. The feature works fine as it should but it makes for a pretty abrupt launch whenever it disengages.
I usually use the back up assistant to back out of the garage every day, but with the auto-hold enabled, pretty much every day I have to step harder on the gas to release it and then immediately i step on the brake because its just going too fast for me. the auto-hold feature is damn near perfect on our f15. its very smooth and overall, i still like the feature, but I'm wondering if that was just a change to the g05 to make it so strong, or if I just got one that is like this. And if so, will the local dealer be able to adjust it when I take it in for service in a couple of months? |
11-26-2020, 10:44 PM | #2 |
Rep 6,789
It can be adjusted. This one is fine, but I've had to have it adjusted on one previous one.
thereef5101164.00 |
11-26-2020, 11:00 PM | #3 |
Rep 4,491
Drives: 2022 iX xDrive50, DGM
It's pretty smooth on mine. Engages and disengages fairly invisibly, but I would probably turn off if I needed to do precision parking.
11-26-2020, 11:02 PM | #4 | |
Rep 85
11-26-2020, 11:07 PM | #5 |
1164
Rep 1,777
11-26-2020, 11:08 PM | #6 | ||
1164
Rep 1,777
11-26-2020, 11:17 PM | #7 |
Rep 4,491
Haven't had to have mine adjusted, but I think it just engages the parking brake electronically, triggered by the brake pedal, so should be a simple fix.
11-26-2020, 11:23 PM | #8 | |
1164
Rep 1,777
Stepping on the brakes manually produces predictable results every time so hopefully it is an easy adjustment or maybe some sort of software glitch |
11-27-2020, 12:43 AM | #9 |
Gear Head
113
Rep 303
I use mine every morning...works very smoothly. Though, at times, the ASS seems to shut the engine down a micro-second too soon while coming to a stop.
2021 X5 M50i, Carbon Black, Ext Coffee Merino interior, 21" Y Spoke wheels, Matte Poplar woodgrain trim. Adaptive M-Susp, DHP, Exec Package, Park Assist Plus, Driving Assist Pro, Traffic Jam Assist, Heated/Ventilated seats/armrests, Alacantara headliner, Increased speed limiter.
My wife drives a 2020 X2 M35i. |
11-27-2020, 03:53 AM | #10 |
Rep 236
Mine is a bit jerky but I never had F15 to compare. Thought this was normal but from the thread it seems it is not. Will get mine looked at next time.
11-27-2020, 06:16 AM | #11 |
1164
Rep 1,777
TomCat6065113.00 |
11-27-2020, 08:37 AM | #12 |
199
Rep 353
I haven't found a use for the auto hold yet on the X5. I used it occasionally on my last car on hills with the manual transmission. What are people using it for on the X5? Maybe I'm missing out
11-27-2020, 08:43 AM | #13 |
Rep 236
I notice that when the auto hold kick in it leaves your rear brake lights on, same as if you had your foot on the brake. Quite useful if you have traffic coming up behind at speed. I use the auto hold as default on the vehicle.
11-27-2020, 08:45 AM | #14 |
Rep 116
Drives: 2024 X5 50e LCI
The main reason many people use it, is after coming to a complete stop, you don't have to hold your foot on the brake pedal and then just press the accelerator and the brakes released and you are on your way. Laziness is a better description.....
11-27-2020, 08:48 AM | #15 |
1164
Rep 1,777
although i'm not entirely sure (or care to find out) but with auto-hold, if you get rear ended while stopped, it'll keep the brakes applied. but its mostly because of laziness.
11-27-2020, 08:49 AM | #16 |
Rep 5,319
My 2019 G05 X5 was really grabby to the point it would be thump when letting go. I turned the feature off to get a few miles on the brakes. It did smooth out.
My current X7 M50i auto-hold is almost seamless and silent. I can’t even tell it’s even on. I live on a mountain in a rural hilly area so it does have its purpose. I can see it being really useful if you were pulling a trailer and stopped on a hill or at the boat launch backing your boat down the ramp. |
11-27-2020, 08:53 AM | #17 |
Rep 4,491
Probably one of those automated comfort features it would be easy to do without, but I actually missed it on my Q7. It also provides a moderate safety enhancement, for example, waiting in the multi-car line for the ATM, or Burger King drive-through, without having to constantly be aware of your foot on the brake looking for your wallet or change, reaching through the window for your Big Mac combo or breaking up a fight between your 8 year-old progeny. Many high-end vehicles have it, and it does have some utility.
11-27-2020, 09:06 AM | #18 |
1164
Rep 1,777
I already have about 5000 miles on the clock but the auto-hold feature was active since day 1. are you saying if I take it off for a while it'll smooth out? i really don't want to take it into the dealer unless I have to
11-27-2020, 09:15 AM | #19 | |
Rep 66
To the OP, the feature works pretty smoothly for me, however, I do disengage the feature at times when I need really slow speeds while parking.
2019 X5 40i MSport
11-27-2020, 09:29 AM | #20 |
Rep 5,319
I don’t know, mine did after about 3k miles. If I were you, I would let my dealer adjust it next routine service.
thereef5101164.00 |
