03-26-2023, 08:13 AM | #1 |
Rep 195
front windscreen washer not working suggestions?
I have noticed my front windscreen washer doesn't work as intended anymore, I can hear the system trying to spray water but hardly any water coming out of the front washers, sometimes it is just a small amount covering bottom of screen only, other times nothing at all, if I stop and start it several times I may get some water on screen but not always.
The rear screen washer works perfectly fine, no issues there at all. Any suggestions on what to check to see if there is a blockage somewhere at front? Thanks
G05 X5 M50D - Carbon Black - Tech Pack - Comfort Pack - Sky Lounge - Individual Merino Leather
03-26-2023, 08:44 AM | #2 |
Rep 2,919
You could have a failing pump motor or a clogged filter by the pump motor, , but more likely the crusty blue stuff that forms has clogged the jets. On thing to try is to open the hood and disconnect the hose downstream of the jets and see what kind of stream comes out when you activate it. That takes the jets out of the equation. If hardly anything comes out, then it's not the jets. Our you could try putting a small needle in the jets.
03-26-2023, 10:06 AM | #3 |
Rep 8,812
Drives: eVeRyOnE mAD!
hopefully you didn't use Rain-X washer fluid (or similar)
03-26-2023, 11:03 AM | #4 | |
Rep 195
03-26-2023, 11:04 AM | #5 |
Rep 195
Nope, I have stayed away from that stuff, just water and sometimes the washer fluid you can pickup from fuel stations.
nZtiZia4735.50 |
03-26-2023, 11:24 AM | #6 |
Rep 7,548
If you raise the hood…the hoses to the wiper jets should be obvious & visible.
#1 = washer jet #2 = washer jet chain #1 = washer jet chain (below) Before digging deeper into clogged hoses…take a pin/needle/safety pin and sticks the pointy end down into your washer jets to see if they are clogged up with crusty deposits. If the jets aren’t crusty…then look further down stream. TIPS: since many modern homes don’t have sewing pins/needles…perhaps the tip of an old ear ring will be thin enough to unclog a washer jet. Or if you have a new shirt still packaged…or you removed any pins from an old “new:” shirt… you may have tossed aside a pin that was used to keep the shirt together on your dresser etc. …or you may have an old boutonniere or corsage laying around from a past wedding or formal event that has a long straight pin still stuck in it.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 03-26-2023 at 11:41 AM.. |
imyb53.00 Car-Addicted7218.00 |
03-26-2023, 01:15 PM | #7 |
24
Rep 32
I had this issue on my Genesis. I took a syringe, you can use anything that attaches to the hose going to the reservoir, and put water INTO the reservoir through the hose. This let me know that section needed to be cleared.
If you have enough extra hose, you can cut off an inch or so where it connects to the sprayers and use the syringe to push fluid through the sprayers to see if THAT area is clogged. I drained the reservoir using a syringe and a long hose. You would be AMAZED at the amount of junk that forms down there. I continued filling the reservoir through the hose and draining it. I took about an hour, but it was better than removing the reservoir. I put nothing but washer fluid through it. |
imyb53.00 |
03-30-2023, 08:39 AM | #8 | |
Rep 195
I've tried to remove the jets from the back of the hood but can't seem to figure out how to do it, any suggestions?
03-30-2023, 09:26 AM | #9 | |
Rep 7,548
I wonder what happens if you remove the screw (#2) completely?
04-01-2023, 09:39 AM | #10 |
Rep 195
thanks, I wasn't able to find anything online either.
04-01-2023, 10:04 AM | #11 |
11584
Rep 11,145
Pump is going out or is clogged. On my previous F15, had my first one replaced under warranty. When the second one went out and I got quoted some silly amount to get it fixed, my SA told me I have a 50% of fixing it by draining the tank and filling it with vinegar. I had to let it sit in there for weeks, but eventually the clog dissolved and all is well again.
04-01-2023, 10:25 AM | #12 | |
Rep 195
Could you please elaborate on the vinegar scenario, what type of vinegar did you use, how much to put in tank and should I try and use washer with vinegar in there?
04-01-2023, 11:32 AM | #13 |
11584
Rep 11,145
I just used the cheap supermarket brand white vinegar. I diluted it 50/50 with warm water and filled up the tank. I let it sit for a while (weeks) before I actually tried to use the windshield wipers washers again. I would do it before washing the car so all the vinegar would be rinsed off the vehicle. Didn't want to let that sit on the paint.
09-04-2023, 05:44 AM | #14 |
Rep 1
Through using the info above, along with an idea from a video I found online for an older X5, I managed to fix this quickly myself (at least for now!). In my case the pump was activating, however limited-to-no jet flow. The jets themselves did not seem clogged.
The resolve, I did the following: 1) Removed (pulled/unclipped) the final jet. 2) Removed (unclipped) the outer jet casing. 3) Loosened the small wires from the sheath that is built into the pipe, so as to reduce chance of damage when.... 4) Yanking/twisting the jet off the end of the pipe. 5) Opened the washer tank lid to allow expel 6) Attached an air pump to the end of the pipe where the jet had been removed and blow air through a few times (video I saw used compressed air gun, which I don't have, so I just used a foot pump gently manipulated by hand). 7) Reattach final jet. Assumedly draining the tank by syphon and refilling would be an ideal next step to reduce chance of repeat, however I have not done that yet. |
09-04-2023, 09:29 AM | #15 |
Rep 547
After you get this resolved, stick to OEM fluid or something compatible. There have been several threads on this site about additives in some brands of washer fluid that tend to cause problems in BMWs.
09-04-2023, 09:45 AM | #16 |
Rep 7,548
Silicon…it’s a warning in many of the BMW owners manuals to avoid using washer fluid that contains silicon.
It apparently can have a negative affect on the capacitive washer fluid level sensor.
10-04-2023, 03:27 PM | #17 | |
Rep 10
03-05-2024, 10:15 AM | #18 | |
Rep 646
Like to get the thing off the unit so I can see what I'm doing. Thanks |
04-03-2024, 12:29 PM | #19 |
Rep 52
Would appreciate any help based on this question. I was able to detach the sprayer from the hood by gently pulling down in the direction of the arrow. I have heated sprayers, so there’s wiring inside the rubber tubing. I started to try to disconnect the sprayer from the tubing but feared I would pull the electrical wiring is well. And it seemed pretty tightly held in place. So any guidance on how to safely disconnect the hose from the sprayer would be greatly appreciated.
