04-16-2024, 12:59 AM | #23 |
Rep 659
Drives: 2024 X5MC LCI, 2017 F86 X6M
I've had this nuisance of a sound from the second month.. and it's gotten even worse nowadays. Doesn't seem that there is a long term solution as of now
2009 E71 X6 50i- Azurite Black - Sold
2014 F15 X5 50i - Sophisto Grey - Sold 2023 G70 740i - Oxide Grey - Sold 2017 F86 X6M - Donington Grey 2024 F95 X5M Comp LCI - Isle of Man Green |
04-16-2024, 02:23 AM | #24 |
3179
Rep 1,852
There’s many posts talking about the isweep brakes and their effectiveness.
r33_RGSport13051.50 |
04-16-2024, 08:56 AM | #25 |
Rep 8,833
EBC Reds as well. I tried both on my X5M.
isweep is2000 is completely silent all the time and i'd say 50% less dust than oem pads EBC Reds would occasionally make a squeal for a split second time to time but you only hear it if you have your windows open and you are looking for it. Non issue imo. I think these dust slightly less than isweep is2000 and maybe more in line with is1500. Brake feel is very similar in both pads.
r33_RGSport13051.50 xmanpro3178.50 |
04-16-2024, 10:23 AM | #26 |
3179
Rep 1,852
I’m running the is2000 and like the bite compared to the oem. It still has minimal dust but I can live with it. Those oem pads were rough! These were after less than 200 miles and taken at my installer right before the iSweeps went in.
04-16-2024, 11:03 AM | #27 |
Rep 215
I have 25k miles on my '23. Only had this issue once or twice for a few days, but I try to get some hard braking in often and I do run it through a tunnel wash once a week.
OEM pads, so not sure why it hasn't come back but might be worth trying! |
04-16-2024, 12:31 PM | #28 | |
Loving Life
64
Rep 38
Brakes will make a bit of noise when the surfaces are not perfectly aligned, but it should be a rare occasion, not an every day/every minute experience For what it's worth, I own a Porsche 718 Cayman GTS 4.0, and the brakes are silent whether I am on the street or on a track. Last edited by fallen; 04-16-2024 at 08:10 PM.. |
04-16-2024, 04:05 PM | #29 |
Rep 494
What about looking at this "brake squealing" from a different perspective?
Our big M brakes are extraordinary engines, by far the most powerful on board: on demand, they may instantaneously deliver a very high torque at each wheel - they are incredibly compact engines, considering that they are rated up to 1500 hp for a few seconds. Of all the design compromises that such an high power engine may require, the one of ensuring that each of the front three piston pairs will have exactly the same pressure on the pads when the brakes are just "caressed" - that's when they squeal - is a low priority one: it means that one of the pads may just be barely touching the rotor and may so start a mechanical vibration similar to when you caress the rim of a crystal glass cup with a wet finger... both the cup and the rotor will start singing like a diapason. A while ago my wife started complaining that her 435xd Grand Coupe would start squealing when braking lightly. I told her to play with it and try to brake so as to increase the squealing. For a while she actually had fun at it, then got bored and forgot, problem solved. Let your 1500 hp monsters sing their tunes from time to time... I'd say they even earned it! |
fallen63.50 |
04-16-2024, 11:17 PM | #30 | |
Rep 53
04-16-2024, 11:19 PM | #31 |
Rep 53
04-16-2024, 11:23 PM | #33 | |
Rep 53
However, if it's a known issue, BMW should consider changing the brake supplier. |
04-16-2024, 11:26 PM | #34 |
Rep 53
Has it been happening every time you drive since then? For us, it's not happening all the time. We didn't hear a sound at all today.
04-16-2024, 11:29 PM | #35 | |
Rep 53
Our car has the same color as yours. Cheers! |
04-16-2024, 11:37 PM | #36 | |
Rep 53
Interesting point. The sound is not unbearable nowadays, and it comes and goes. We'll just leave the brakes as they are for now. Thanks for sharing. |
04-16-2024, 11:40 PM | #37 | |
Rep 53
04-17-2024, 06:03 AM | #38 |
Rep 638
I think the Porsche video posted above helped explain it, the sounds does come and go and it seems to align with what they were saying, since I did notice when it was wet from rain, it would do it a lot more often
?21 X3M Comp
'18 M3 Comp '15 M4 coupe '12 M3 coupe '09 335xi coupe '07 328xi coupe |
05-03-2024, 05:36 AM | #39 | |
Rep 659
I took it to the dealer and asked them to check it - the car already has a brake recall so i'm hoping they clean it while doing the necessary service.
05-03-2024, 10:58 AM | #40 | |
Loving Life
64
Rep 38
The replacement process is very easy for DIY and takes about 30 min for a qualified shop to do. Some people find the sound tolerable; I personally, being a mechanical engineer with OCD, could not tolerate it |
