06-05-2023, 09:27 PM | #243 |
Rep 275
Anybody knows what the maps represent on race chips?
r33_RGSport12999.50 |
06-05-2023, 09:29 PM | #244 |
13000
Rep 18,728
In a nutshell.
Higher map number, more boost. More boost, more hp gain.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com PM for Everyday DEALS!! MSS iSweep RaceChip Sterckenn AutoTecknic Akrapovic Vossen Wheels Eventuri Active Autowerke KW H&R Ohlins Remus and more... |
06-11-2023, 11:09 PM | #245 |
23
Rep 42
does this work on the new 2024 BMW X5 LCI??
06-12-2023, 08:57 AM | #246 |
13000
Rep 18,728
Which X5 engine variant? 40i, 50e, M60i, or M?
06-12-2023, 10:10 AM | #247 |
23
Rep 42
06-12-2023, 02:05 PM | #248 |
13000
Rep 18,728
AFAIK, BMW haven't update the engine on 40i, so I would say it is the same as Pre-LCI.
06-12-2023, 09:42 PM | #249 |
23
Rep 42
So I was on the phone with dinan today and they told me that while the connections may be the same and it will fit the tuning or calibrations on these systems was made for the PRE Lci tune. Meaning the 2024 B58 make more power from the factory so their device needs to be calibrated to account for this extra power. I believe previously the power was at 335hp for the 2024 LCI model its up 375hp.
06-13-2023, 09:03 AM | #250 | |
13000
Rep 18,728
10-11-2023, 09:08 PM | #251 |
Rep 204
Anyone running RaceChips GTS Black on an X40i with an AA Catted Downpipe?
Wondering if the added boost = additional exhaust = CEL light for cat inefficiency. What mods are compatible with the RaceChip and, should we expect any codes to trigger? Thx! |
10-11-2023, 09:48 PM | #252 | |
13000
Rep 18,728
I got a few customers running their downpipe with RaceChip. No CEL reported so far.
Bottom1615.50 |
11-04-2023, 08:06 PM | #253 | |
Rep 131
Dealership says it is cat efficiency and doesn't change performance. They sent me photo of cat with tiny hole in the center. I contacted AA and they said that is part of manufacturing and won't be a factor in setting off the CE light. That there may be a break in period. I had the dealership reset it. Came back on right away. Every once in a while, it will start and go from A to B without it coming on, but there's no difference in how it drives with CE on or off. I'm not going to keep messing with resetting the light. Maybe I'll consider the CEL delete option? Not really worried or even concerned about it. The dealership knows about both the Racechip, AA DP, FTP charge pipe and BMS intake filter. They said I'm fine unless I grenade the engine or kill it during an overboost situation. The X5 runs amazing and sounds great with the add ons. No regrets! FWIW: Yes the CP, DP, and filter were professionally installed and DP broken in correctly, at the manufacturer's recommendations.
Been going against the grain since I was a sapling.
r33_RGSport12999.50 raannathr33327.50 |
11-04-2023, 09:28 PM | #254 | |
13000
Rep 18,728
I know that AA catted is guaranteed no CEL.
11-09-2023, 09:42 AM | #255 | |
Rep 117
Here's my experience...
Did I get a CEL? Yep. Will you, even with an AA Catted Downpipe? More than likely. What did I do? I bought the MIL CEL delete kit and had my friendly BMW master tech install it for me. No CEL anymore. However, every once in a blue moon, if I arrive somewhere and the car goes into READY mode, and I open the door to get out for just a second, the car obviously shuts off. When I turn the engine back on, it will get a CEL until I do a proper shutdown and restart... Don't know if that makes sense. |
r33_RGSport12999.50 Tch-Nrd124.50 |
11-10-2023, 06:12 PM | #257 | |
Rep 204
11-11-2023, 07:06 PM | #258 | |
Rep 131
I only had the check engine light reset once. I'm not sure what code it's throwing now. Runs/drives great. Not worried about it. When I have it at the dealership Wednesday for remote start troubleshooting. I may have them reset it one last time.
raannathr33327.50 |
11-18-2023, 10:29 AM | #259 |
Rep 25
New to this, but I've seen mods/chips for the X5 45e and was wondering if there is any experience with the new X5 50e. Although they both use the B58, I'm wondering what the implications are for the electric motor and if it would mess up the PHEV power management, ie. draining EV engine, causing issues with transitions, etc.
11-19-2023, 10:59 AM | #260 | |
13000
Rep 18,728
11-19-2023, 04:06 PM | #261 |
Rep 25
Is there a specific chip for the 50e or just use the 40i version?
11-19-2023, 04:11 PM | #262 |
13000
Rep 18,728
I have yet to datalog 50e. So not available yet in the meantime.
11-20-2023, 03:35 PM | #263 |
146
Rep 344
Anybody can share improved numbers (0-60 etc.) on 40i and 45e with the max map of a RaceChip?
11-20-2023, 05:38 PM | #264 |
Rep 76
Do you guys know if the factory boost gauge is accurate? It shows 10psi max boost during WOT on 50E
