08-31-2023, 09:19 AM | #1 |
Rep 208
50e recommendations for my first long trip please.
I’m about to take my first long trip, 500 miles to Panama City Beach and back. No plug-in where I’m staying. Other than going down the mountain from where I live, Asheville, it’s all flat.
Atlanta is the only major city I’ll go through, planning on the middle of the day for that. I’m sure it will be bumper to bumper traffic, so would I need the battery? I will want Electric in PCB for pre-conditioning, etc. Should I just do battery hold when I first start out on my trip? Any recommendations are appreciated… |
08-31-2023, 09:39 AM | #2 | |
Rep 187
I’d use batter hold for the highway driving for sure. I notice even when I am in hybrid and on battery hold when I’m stopped it still uses the battery. Remember they block out like 20% of the battery so you have more juice than you think. Enjoy the trip - let us know how it goes. |
08-31-2023, 10:20 AM | #3 |
13462
Rep 20,058
I'm sure others who own one will chime in but probably best to hit battery hold around 30- 40% and not worry about anything else. This will allow you to have preconditioning and you don't have to worry about finding charging which likely will not only take time but be more expensive than using gas.
08-31-2023, 10:50 AM | #4 |
Rep 689
Drives: 22 TR X3MC
Just drive around with the battery hold on and it'll charge up the car to 4 miles of range with regular driving
2022 X3M Comp
2013 335i xDrive (Sold) |
08-31-2023, 11:40 AM | #5 | |
Rep 8,744
Drives: eVeRyOnE mAD!
and to clarify, the unusable capacity in the U.S. 50e is ~32% |
cdhowell127.50 |
08-31-2023, 12:11 PM | #6 |
Rep 208
So if I'm driving on the interstate in hybrid mode, would that be using any battery?
Also probably 100 miles of the trip is 2 lane and through some small towns. |
08-31-2023, 12:14 PM | #7 |
Rep 8,744
of course, that’s literally what “hybrid” means. a hybrid vehicle combines two drivetrains: the electric motor and ICE. choosing Hybrid drive mode confirms you’re letting the vehicle decide when to efficiently use either
08-31-2023, 12:24 PM | #9 |
Rep 8,744
that’s what I would do, too. takes away the guesswork if Hybrid mode will use up all the usable capacity or not as well as having to actively think of Battery Hold.
RetSurfer Sport mode will maintain about 16-20% of usable capacity. NOTE: once you select Electric mode for the local drives, you’ll have to pay attention to the battery capacity so you don’t get too low and lose the ability to precondition |
08-31-2023, 12:47 PM | #11 |
Rep 3,696
I kind of think BC on highway is the same as sport mode on highway with usable HVB deplete? If we believe this is equal, then I have been seeing 24-25 in 45e. Highway sport mode with good HVB SOC, it is more like 27-28.
2022 G05 B58/PHEV
+ a few very old BMWs |
08-31-2023, 01:00 PM | #13 |
Rep 899
Don't know about MPG, but I do feel sport has a bit more aggressive shifting pattern than battery hold, RPM is significantly higher
08-31-2023, 01:17 PM | #14 | |
Rep 3,696
the 2nd part is incorrect. In sport mode and in "D", transmission will go into 8th gear in normal highway speed. As long as that happens, RPM is the lowest possible at the speed. It is only in "S" transmission will NOT go into 8th. It will remain in 7th well beyond speed limit. But I am not talk about "S".
2022 G05 B58/PHEV
08-31-2023, 01:33 PM | #15 | |
Rep 187
08-31-2023, 01:40 PM | #16 |
Rep 3,696
where do you see "zero"?
2022 G05 B58/PHEV
08-31-2023, 01:45 PM | #17 | |
Rep 99
I found the best method was just to leave everything in the default modes for the overall maximum ranges in the trip. The computer did modify the discharge rate slightly, leaving a little under 5% more reserve in the battery. But it definitely didn't "save" the battery for later on in the trip. Assuming that the 50e is programmed in a similar manner then to use the minimal fuel don't play around with the settings. |
tooloud10783.00 |
08-31-2023, 01:48 PM | #18 | |
13462
Rep 20,058
nparker135.50 |
08-31-2023, 01:55 PM | #19 |
Rep 519
I wish the hybrid mode was adjustable. I would love to have a hybrid mode for long trips where I could set it to automatically switch to ICE anytime the car was going more than 35 mph so the battery is more reserved for in-town travel.
08-31-2023, 01:55 PM | #20 |
Rep 187
08-31-2023, 01:58 PM | #21 |
Rep 187
I will say - when I did a recent 150 mile trip I plugged it into the Nav in hybrid eco pro and when I got home I still had I want to say 9% left on the battery…so I would recommend using the nav so it knows best what to use…
08-31-2023, 02:10 PM | #22 |
Rep 3,696
In this case, I am sure, when dash display "---", the usable HVB is not at 0%. You can see the % in app. From my observation, there is somewhere between 3-6% left of usable HVB. In fact, to get the usable portion down to 0%, it isn't even that easy. You need to do some purposeful trick to get there.
2022 G05 B58/PHEV
nZtiZia4687.50 |
