03-11-2024, 02:45 AM | #1 |
Rep 4
My X5 xdrive50i Front Differential failed at 40K!! And I'm out of warranty
Are there any other options rather than replacing the differential? At least a temporary option.
One German garage advised to disconnect the driveshaft so the car will only drive rear wheels. Will there be any side effects? Help |
03-11-2024, 09:06 AM | #2 |
Rep 404
I am sure if you disconnect without reprogramming you will get errors as the car detects the disconnect - perhaps this if it applies to G05? https://www.xautomotive.com/products/xdelete
I am not an expert and I am not recommending anything - simple responding to your question above. |
03-11-2024, 10:29 AM | #4 |
Rep 1,145
Drives: 2022 x5 40!
What year is the x5 ? I’ve had this problem with Land Rovers over the years and what I started doing was getting a rebuild kit for the dif and having a local shop that specializes in transmissions and differentials to rebuild it much cheaper
volodp199.50 |
03-11-2024, 11:21 AM | #5 |
Rep 257
specialized shop in transmission and diffs should be able to provide a re-build, which should be much cheaper
that's my route in case if it ever happens |
03-11-2024, 12:41 PM | #6 |
Rep 105
Thats concerning as mine hasn't even hit 23K yet. Granted theirs is a 50i, but I would guess its using the same parts.
2021 X5 xDrive40i M-Sport | Phytonic Blue / Cognac
03-11-2024, 02:44 PM | #7 |
Rep 4
Update.
Turns out the differential is fine but there’s a leak as shown in the pictures which reduced the amount of oil inside, and that caused the car to shake/ vibrate when turning right & left or increasing the speed. I think this can be easily fixed by closing the leaking areas & refill the oil in any garage other than the dealer. The dealer cannot fix it. They want to replace the whole differential which is too expensive. Cost around 17k usd here in Saudi Arabia. |
04-11-2024, 11:31 AM | #8 |
Rep 1
Mine too - 2020 X5M50I front differential failure
Bought my 2020 X5 M50i brand new in Aug 2019 at the dealer and only service it there. Noticed a weird grinding noise, thought it was brakes but only happened on acceleration. Took to dealer yestereday and front differential is shot, driveshaft not running true, and the transfer case is likely also shot. $15K repair estimate (total). Was informed that BMW NA will offset potentially half or more of the repair cost. 46k miles.
04-11-2024, 12:01 PM | #9 | |
222
Rep 329
Current - ? 20 X3MC
ED 2016 - F80 M3 - SO/SS CP, LP, EP DAPP, 6 SP :drive: MY ED 2016 WRITEUP 2013 - 2010 E93 M3 DCT, White/ Black - beauty. :Perth, Aust. (sold 2014) 2011 - 2006 E46 M3 Conv SMG Black/black - great (except for SMG) (Perth, Aust). 1st foray into M's -slippery slope (sold 2013) ED 2009 E90 335i - Le Mans, (sold 2010)[URL="http://www.bimmerfest.com/forums/showthread.php?t=365925 |
04-18-2024, 10:22 AM | #11 | |
1053
Rep 1,952
04-18-2024, 01:04 PM | #12 |
Rep 1,008
Sorry to hear.
I posted the comment about these things are great while in warranty , but once out, all bets are off. Better to keep for the 3-4 lease/finance and turn them over once out of lease or warranty. If one can't do simple things like plugs/coils/brakes, some fluid changes, brakes, rotors - things can expensive when OOW. I can only wonder what a module replacement may run |
