01-25-2023, 11:43 AM | #67 | |
Rep 192
Faults 038400 038404 stored for remote upgrade, per test plan D8700_RSU0000_90_214 Programmed Vehicle I-Level 21-07-585 to 22-11-550, remote upgrade performed during programming. They also changed the key fob battery 66-12-6-912-985 (common 2130 button cell) as it was low so not sure if that had anything to do with the fault codes, probably was coincidental? YMMV. |
kgelfen3602229.00 bandersen594.00 |
01-25-2023, 01:22 PM | #68 |
Rep 1,448
I just picked up my G05. The problematic fault code mentioned to me was that an attempt was made to install while on an incline.
My driveway is steep but my garage is not. During one day of running errands I put on the brake on the incline and according to SA the car could not overcome that fault code. They insisted no problems with my battery.
2015 BMW X5 xDrive 50i/XL/CW/DA+/EP/LP/FVS retired; 2008 X5 4.8i; 2012 X5 5.0i retired, 2004 X5 4.4i retired R360c + EL, V1G2 + V1Driver, Uniden R8 |
kgelfen3602229.00 |
01-25-2023, 03:10 PM | #69 |
Rep 2,037
Thanks for info. Yea not sure what my issue is eventually I will go to dealer when it’s due for service and I guess find out.
But with regards to battery when I used CTEK charger according to the charger the battery was below 80%. So I guess I am just unlucky and have multiple things blocking the update. |
01-25-2023, 08:49 PM | #70 |
Rep 6,862
FWIW, it's not a great idea to perform the update tucked away in your garage. While the odds of something going wrong once it actually starts is small, if it does, you probably won't be able to start the vehicle, or get it into neutral to pull it out so it can be worked on. Find a flat surface outside, and perform it there.
01-26-2023, 06:28 AM | #71 |
Rep 284
Mine was updated to 11.2022 by the dealer yesterday.
They said the software update was done at the same time as the DDE control unit safety recall and that could have been causing the issue as to why it wouldn't update. |
02-04-2023, 03:43 PM | #72 |
59
Rep 49
Same thing for me. Upgrade was stuck for weeks. I tried charging the battery, left the key in the car (garaged of course) with the parking brake set, rebooted I-drive, all without success.
Took it in a couple of days ago for an oil service and asked them to check on it for me. They were able to get it programmed (no charge) to 11/2022.50 This is what the service order said: 39371 Vehicle-end preconditions not fulfilled. Connected battery charger to maintain battery voltage. Performed vehicle test to check faults. Found fault 038400: Vehicle -end preconditions not fulfilled. Per customer request, programmed and coded vehicle to update vehicle I-Level. Performed post programming initializations. Last edited by 2heeldrive; 02-18-2023 at 01:25 AM.. |
02-11-2023, 09:15 PM | #73 |
Rep 2,037
I ran BimmerLink and I also 038400 code. I’ve tried deleting and comes back right away after I shut down the car. Battery is charged with trickle charger and according to BimmerLink is at 84%. I park in garage flat surface.
At this point not sure what the issue is that triggers that code. I won’t be going to the dealer for service for another few months and I don’t feel like going there just for this software update. So I guess just gonging to give up on it. |
03-06-2023, 04:57 PM | #74 |
Rep 17
My late 2018 G05 downloaded the update (on my phone) and it's sitting waiting. Nearly 2 weeks now
I also ran BimmerLink and the 038400 code is there. Car on level ground, handbrake on car has been on my Ctek charger, done a full recondition cycle and a normal cycle the following week. Went for a 80 mile round trip last week, still nothing. Battery has been around 85% to 95% when checked. I am due to go into BMW for a recall in 7 weeks, will update if it needs the dealer to do it. S |
04-27-2023, 11:56 AM | #75 |
Rep 17
My BMW came up with a message software time had run out and would not update.
Just had a visit to the dealer for EGR software update. Told them about the software but updating. When I picked up the car, they said they could not perform a remote software update at the BMW dealer. Just looked at the software version and it's 03/2023.45 so looks like it was done. Is this the most upto date software? S Last edited by Stone41; 04-27-2023 at 12:52 PM.. |
04-27-2023, 02:04 PM | #76 |
13453
Rep 20,019
It is the most recent major version, minor versions are release all of the time so hard to be current on those.
06-01-2023, 10:08 AM | #77 | |
Rep 5
i have 45e, uploaded the upgrade to car without issue, but it never notify me to install |
06-03-2023, 11:28 PM | #78 | |
Rep 6,862
Mine asked me to connect my phone, but even when the app said everything was connected, it never uploaded to the vehicle. I eventually had the dealer apply the upgrade after they witnessed the problem. For whatever reasons, sometimes it works properly, sometimes it doesn't. I've had four updates...two worked as expected, and the dealer had to do two of them after things failed on their own. |
06-08-2023, 12:50 PM | #79 | |
Rep 1,448
I am in the middle of a move from OK to TN and apparently will need to put this to a TN dealer next month when we do an oil change.
06-08-2023, 01:41 PM | #80 | |
Rep 2,037
06-08-2023, 06:07 PM | #81 | |
13453
Rep 20,019
06-08-2023, 09:03 PM | #82 | |
Rep 1,448
What else in my G05 is not being updated properly? I know the maps had to be done by the dealer last time. I pay for the app to notify me about red light cameras and it has not worked for months? Will I get video from the BMW app should I be an accident?
2015 BMW X5 xDrive 50i/XL/CW/DA+/EP/LP/FVS retired; 2008 X5 4.8i; 2012 X5 5.0i retired, 2004 X5 4.4i retired R360c + EL, V1G2 + V1Driver, Uniden R8 Last edited by Xeno; 06-08-2023 at 09:46 PM.. |
06-28-2023, 12:19 PM | #83 | |
Rep 14
I was able to update iDrive in the past but this one for some reason is just getting stuck after uploading to the car. Previous updates also downloaded successfully to my phone and then the car but was pending for so long that they just ended up deleting themselves. I put the car on a charger earlier this week for 2.5hrs and got the battery up to 90% but still no dice. |
06-30-2023, 09:39 AM | #84 | |
Rep 1,448
My last night on the road, I got tricked into changing my password for the Connected Drive. Since that time I have not once seen a notice that the installation could begin. I did see a flashy video today about July 4th, but nothing about this OTA update.
07-18-2023, 12:12 AM | #85 |
Rep 4
Hi everyone,
I have the same issue with my 2020MY X5 xDrive40i Since few months I can’t update it on 03/2023.50 and stuck on 11/2022.31 Dealer said car is out of warranty so asking for $450 to perform the update. Any good advice on this? Like wait for another update? Still thinking to try to buy a charger and charge the battery. Does anyone has a good picture where the negative terminal located under the hood on g05? |
07-18-2023, 12:28 AM | #86 | |
Rep 8
07-18-2023, 07:34 PM | #87 |
Rep 4
Called a dealer today, he said that there is a known bug in current update release and bmw is working to solve it. He suggested to wait few months and a new update should become available which will be easy to install without a need to come to a dealership.
He said even if I want to come to dealership they won’t be able to install it manually. |
07-18-2023, 07:49 PM | #88 | |
Rep 65
