03-20-2019, 05:29 PM | #2 |
456bhp for breakfast
425
Rep 913
I can't find the trunk nets but this is close:
http://www.realoem.com/bmw/enUS/show...diagId=03_0701 |
03-20-2019, 05:35 PM | #3 |
425
Rep 913
Actually I may have found it...
http://www.realoem.com/bmw/enUS/show...diagId=51_A209 Item #10 "Trunk Flap" |
AndroidRobot4331.50 Ilyam5894.50 |
03-20-2019, 07:04 PM | #5 | |
65
Rep 360
fakinit7524.50 |
03-20-2019, 07:29 PM | #6 | ||
Rep 6,121
03-20-2019, 07:47 PM | #7 | |
Rep 7,477
When I did a generic search for the same diagram...item #4 was listed...which also listed the multiple colors and options for item #10. Click the following link to see what I mean...scroll down to #10 and select the one that matches your interior color..AND...also has "YES" in the supplemental column that asks if you have option S418A...also take note that you may need item #4, too for #10 to fit correctly. Once you have the correct 11 digit BMW part number...you can simply type BMW xx xx x xxx xxx (where x=the actual BMW part nbrs) into a google search box to find vendors that are selling that part. Or you can call your local BMW dealership's Parts Dept and give them the part number and have them look it up for cost and/or ordering.
03-20-2019, 10:21 PM | #8 | ||
Rep 6,121
03-21-2019, 11:29 AM | #9 |
Rep 7,477
Call your nearest BMW dealership's parts department...give them the correct 11 digit BMW part nbr you need and inquire how much it costs...and how long would it take to arrive if ordered? They will be able to tell if the item is available state-side...or if its back-ordered due to this model being new.
AndroidRobot4331.50 |
03-21-2019, 05:53 PM | #10 | |
Rep 6,121
03-22-2019, 02:42 PM | #11 | |
Rep 157
HTH |
03-22-2019, 03:04 PM | #12 | |
Rep 6,121
05-06-2019, 02:00 AM | #13 | |
Rep 421
05-07-2019, 04:15 AM | #14 |
13
Rep 32
Drives: 2019 G20 330i M-Sport
Any ideas how it may be order?
05-07-2019, 08:49 AM | #15 | |
Rep 7,477
In regards to cost...you will need to inquire with your local (or nationally advertising) BMW dealership's PARTS Dept...or try a google search using a simple search phrase like "BMW xx xx x xxx xxx" (where x=the actual 11 digit BMW part number). Regarding install...if you open your tailgate and you can easily remove the panel that the net is installed into...then replacement should be a simple reverse install. See suggestion above in my reply to MotoWPK.
KDDI12.50 |
05-14-2019, 02:15 PM | #16 |
12
Rep 35
Forgive my ignorance, but the only colors for part #4 I am seeing are "Mokka", "ANTHRAZIT" and for part #10 I see "black" "SCHWARZ" and "mokka".
I'm assuming if we DON'T have Leather Vernasca Canberra beige which seems to correlate with "Mokka," then we select "Anthrazit" for part #4 and "black" for part #10? If it helps, I have CB exterior and Coffee merino interior. Has anybody successfully ordered and installed these parts and nets yet? Thanks so much! |
04-28-2022, 03:29 PM | #17 |
Rep 1
DYI project to make a perfect OEM Side Netting for G05
So, I had my frustration by buying a G05 M50D and not having a single place to store bottles or else in the boot. My car was second hand, so it did not come with storage luggage option (expensive), nor I wanted to venture in buying the side panel with netting (P/N 51475A0B5A6) because it costs £133 and dealer could not confirm that such panel would actually come with the net.
So, here is how I manage to build the identical replica with BMW parts for 20£ and 1.5 hours of work. 1) I bought the "storage Net Luggage Compartment" (PN 51477435855) for a BMW 2 Series F45, which is the metal frame and the net, for £15 in ebay (or 25£ from dealer) as well as the "inclusion of luggage network" (PN 51477330724) for £2.19: these are the plastic supports to fix the base of the metal frame to the base of the panel 2) I remove the netting from the metal frame 3) The metal frame is approx 3 cm longer than the car side panel, so it needs to be adjusted. To do so, I have straightened one side of the metal frame, by heating and putting into a vice. Then I have calculated the exact lenght of the base of the metal frame and moulded the straightened side of the frame exactly as the side which I left intact. You need to use a blow torch to heat the frame, as it is a relatively stiff 5mm iron wire and would not bend easily unless heated up. This requires a bit of ability and a good pair of gloves to avoid burning yourself, but nothing too difficult 4) Once i adjusted the panel properly, I sanded it from the burnt black paint and resprayed it with black metal paint, so that it looks original. 5) I drilled 2 holes of 10mm each in the base of the panel to accomodate the 2 plastic supports. Do not make them too narrow, otherwise the support will not screw in, or too wide otherwise the support might move and disloge from the base. The holes shall be 7-8 mm from the border of the panel (since the panel profile is rounded in the back and you need to counterscrew the fixing on the flat side of the panel 6) I then placed the metal frame on the supports and calculated exactly where to drill 5 mm holes in the side panel for the upper extremities of the metal frame. 7) I had then reinstalled the net and voila' ... all done. Pls notice that the net become a bit longer than necessary to fit the 2 U shaped original positions, but you could shorten it by cutting and restiching the upper elastic band. In my case, i did not and kept it original, since it fits higher up close to the metal frame extremities and contains better heavy water bottles etc 8) I also have taken the opportunity to create a mini handle on the top of the panel, so that I can remove it whenever I want and have access to the huge space behind and below the panel, which BMW decided not to use (my previous F15 used all that space with a proper panel and storage compartment0. Be careful to storage everything here with proper wrapping, to avoid that anything might damage the fuse box). For the handle, I have made 2 * 1cm cuts one cm apart and used them to pass through a velcro strap, which has become the handle. Shame on BMW for selling a 100K car without proper storage, but happy to have it resolved easily and without spending a lot. Enjoy the project ! |
08-08-2022, 10:37 AM | #18 |
Rep 154
Drives: X5 40d G05
I might need to do the same although would prefer to find original part for X5
08-08-2022, 03:42 PM | #19 |
Rep 274
Does anyone know if buying the left and right flap is just as simple as replacing the existing ones? I know its expensive but those nets there would be very useful for me
08-08-2022, 10:02 PM | #20 | |
Rep 422
-Rear Cover P/N 51-47-7-479-782 This part number was taken from an X5 with the luggage compartment package. Part was ordered and it still didn't have the storage net. The second option is for the X3 but indicates that it fits the G05 X5 -Storage Net Storage Comp.Lug 51409947 P/N 51-47-9-471-112 There were no instructions included for installation Last edited by lknbimmers; 08-09-2022 at 11:21 PM.. Reason: Added Info |
comebackidlci32.50 |
08-09-2022, 11:00 PM | #21 |
Rep 274
09-28-2022, 03:39 PM | #22 |
Rep 213
If you were able to order the side panels with nets, they are over $100 each. There is no part number for the nets only.
If you're a bit handy, so can solve it this way: https://g05.bimmerpost.com/forums/sh...6&postcount=46
X5 xDrive 45e 2023 / Mineral White / Tartufo / Anthracite-Brown Poplar
dnachmerp4.50 |
