Hit the 1/4 mile dragstrip today in my 335is!
04-17-2021, 09:20 PM | #1 |
Rep 545
Finally got a chance to hit the 1/4 today after waiting a couple hours for the track to dry from morning showers.
Anyway, launching off idle with no burnout or spinning the car did a best of 11.6 @130. This is on the e40 file, stage 2 LPFP, and no PI. The three 1/4 mile runs were as follows. The first run below is when they were limiting to 1/8 mile due to the damp track. 11.73 @ 127.85 11.63 @ 129.01 11.64 @ 130.68 There's something going on with the transmission causing it to short shift from 2nd into 3rd. Also there were a few shifts that didn't feel right, maybe a little firmer than expected. Otherwise there wasn't too much drama. Definitely felt more solid on the track than on the street. Sixty footers were an embarrassment @ 2.2 every run, but fully expected. By the way, boost is limited in 1st (9psi) and 2nd (15psi). In hindsight I should have bumped it up in both. I especially could have used it in 1st - maybe next time. Below is a link to two datalogs if you're curious. The drag radials apparently are throwing off the speedo around 7mph which was only obvious to me by the top speed of each log not matching my time slips. https://datazap.me/u/awheelus/e40-v2...og=0&data=3-23 There's still some torque limiting taking place that I need Chris to take a look at.
- 335is DCT - 10.5 @ 132 and dropping!
04-19-2021, 10:26 AM | #2 |
Rep 1,419
Man if you can get a good 60' I think you are touching 10's.
I really want to play with LC more but I always had my test times just going easy into throttle and once I could tell the tires would hold floor it.
2011 335is DCT BQ Tuning / BMS CAI / VRSF kittyless DP's / Synapse BOV and charge pipe / 7" VRSF Race FMIC / Walbro 535 and 450 on BMP4 / E90 tune / Diff Brace / PR Coils / Relocation Inlets / DAW Stage3+ Turbos / MMP port injection / xHP Stage 3 / FPR and -6 fuel lines
Grip Grip181.50 |
04-20-2021, 08:49 PM | #3 |
Rep 545
I hit the local 1/8th mile tonight to try out a new revision. Ran a couple times with a full tank of gas and a little more boost in 1st and 2nd, which netted 2.15 and 2.18 sixty footers vs the range of 2.23-2.29 from my last runs in the previous post.
On the last run I decided to get a little greedy and adjusted boost to 13psi in 1st and 18psi in 2nd, this got the sixty footer down to 1.99. Anyway, the 1/8mile time went from a best of 7.85 @ 102 to a 7.53 @ 100. That's 3 tenths off the 1/8 mile ET which at a min should net the same off the 1/4 mile ET. Chopping away at low 11's.
IllSic_Design2124.00 Biginboca3767.50 |
06-15-2021, 10:08 PM | #4 |
Rep 940
Very nice trap speeds ! Big single or upgraded twins ??
2007 E92 335i / FBO + Inlets / E85 Custom Tune by WedgePerformance / 9.68 @ 140 / TPC Stage 2 19T / 2.1s 0-60 mph / 2010 535Xi 6MT - 437M - MHD / Instagram @Silent9n54
06-15-2021, 10:25 PM | #5 |
Rep 545
Thanks. I'm running the Dynamic Autowerx 775rs – stage 2+ turbos. Once I have the port injection sorted it'll be turned up. I just installed it and it's not working.
06-16-2021, 01:15 AM | #6 | |
Rep 940
06-16-2021, 06:31 AM | #7 | |
Rep 1,419
Maybe the AIC controller is not wired right?
06-16-2021, 10:13 PM | #8 | ||
Rep 545
Now I've got the port injection not working so I"m really starting to wonder what I did to get this kind of bad karma. Anyway, I bought another AIC1 which arrived today, so hopefully that's it. I'll get it wired up this weekend and find out. FWIW, really not a fan of no test file for the PI to test things at idle. Will likely create my own test file before flogging the car to figure it out.
06-17-2021, 06:48 AM | #9 |
Rep 1,419
Yeah I know what you mean about testing it. But you should be able to tell you have a live connection to the AIC.
I have been considering just running an LED indicator or some sort of read out to tell when/if it is spraying.
06-21-2021, 11:41 AM | #10 |
Rep 545
Looks like the rpm tap into the black wire (#21 I believe) was bad, causing an intermittent signal. I trimmed the insulation for better contact and it's working great now.
10-23-2021, 10:27 PM | #11 |
Rep 545
Finally got back to the track today after a bunch of DIY maintenance (leaky oil cooler, bad water pump, replace full suspension, etc.).
Anyway, still not using launch control so 60' times were atrocious, but that's fine. I now have a set of spare axles so will be using XHP LC @ around 2,500 rpm's on my next outing. From an idle I was able to get a 11.5 @ 132 and a 11.4 @ 133. Another car broke an oil pan and doused the entire track and after a 90 minute cleanup rain hit the track (Beech Bend) and ended the day early before I could try LC. If the axles and differential hold up it should be in the 10's with LC and decent sub 1.9 sixty footers. Here are the datalogs: https://datazap.me/u/awheelus/10-23-...21-22-23-24-30 Right Lane #78.
NoGuru772.00 Silent9n54573.50 |
11-07-2021, 02:37 PM | #13 |
Rep 940
what tires are in the back ?
11-08-2021, 08:19 AM | #15 |
Rep 1,419
I am guessing the tires are what helped your 60'?
11-08-2021, 11:14 PM | #19 | |
Rep 1,494
N54 is, as you know, prone to CBU. CBU is basically sulfated ash turned into carbon. M1 0W40 has ridiculous amount of ash. I think byproduct is 1.32%. Castrol is around 1.15%. It is huge difference! The lower SAPS amount the less CBU. Best would be going XW40 LL04 oil such as Motul X-Clean 5W40 Gen2, but not worth the price difference. Now, you are doing drag racing not track. You can try Pennzoil Platinum Euro L 5W30 from Wal Mart. It is exceptional oil. SAPS level is around 0.8%. HTHS should be around M1 0W40 so it won't influence protection of bearings etc. Just change it at 5k not more. |
11-09-2021, 08:35 PM | #20 | |
Rep 545
11-10-2021, 07:49 AM | #21 | ||
Rep 1,494
Really good oil, probably undisputed darling of European enthusiasts is Castrol Edge 0W30. HTHS around 3.6, very low KV100 bcs. very sophisticated base stocks. It is basically thinner and older brother of Edge 0W40 but with less polymers (good thing!). Problem? Price. Sometimes you can find it on sale at Auto Zone or AAP for $33 for 5qt. Otherwise $50's for 6qt on Amazon. |
Grip Grip181.50 |
11-30-2021, 07:54 PM | #22 | |
Rep 545
