07-16-2018, 10:32 AM | #23 |
Rep 1,216
If youve read any of the spark plug threads, many people have issues removing the coil as its tight fitting and if you pull hard enough you can damage the coil. Thats why there are specific coil pack pullers. This could be the issue, but Im not the type to blast ones friend or mechanic, just know this does happen time to time.
2011.5 E90 M3
LeMans Blue |
DrFerry6731.50 |
07-16-2018, 10:55 AM | #24 | |
Rep 163
my friend felt bad when he found that the first coil error and reduced his labor cost because I was forced to get a new one at the dealer that day. So, that is why Ii trust him and it is a bummer that the second one failed. Just got off the phone with FCP and they also said that it is a matter of time that the other coils fail and so better to consider replacing them all. They were intrigued when I suggested why not replace the NGK spark plugs with the OEM and see if that fixes for the issue, and said that they could give me a refund of the NGK if that was indeed the case. So, I am thinking of ordering a new OEM coil from ECS ($90) plus a full set of OEM sparks from FCP. And then after ensuring my tech friend does it properly including the vacuum, keep my fingers crossed. Edit - two knowledgeable persons informed me that they are sure that the properly gapped spark plugs do not cause the coil to fail. So, I am going to follow what Scrippy suggested - double-check the gap of the existing ones and keep aside the plan to swap the NGK with OEMs for now. Ordered the OEM coil from ECS. Last edited by BimmerRules!; 07-16-2018 at 02:18 PM.. |
DrFerry6731.50 |
07-16-2018, 12:30 PM | #25 | ||
Lord Scrip
1823
Rep 3,018
Drives: 2011 M3 Coupe
BimmerRules!110.00 DrFerry6731.50 |
07-16-2018, 01:08 PM | #26 | |
935
Rep 1,930
07-17-2018, 01:50 PM | #27 | |
Lord Scrip
1823
Rep 3,018
07-18-2018, 05:20 AM | #28 | |
Rep 163
Problem was, it was a very busy Sat when he did at this shop and this 30 minutes actually took 1.5 hours because of constant interruption and roof being replaced on his garage. So, this time around, I am planning to drop off the car on Thur so that he works on it on Friday when he is hopefully less busy. Plus, I plan to give him some of the suggestions a few of you had made so that he is aware of it. Thanks! |
07-18-2018, 08:05 AM | #29 |
935
Rep 1,930
It's a relative easy job and the intake assembly has to come out. The hardest part is getting coil #4 and #8 which has the least amount of clearance by the firewall.
BimmerRules!110.00 |
07-18-2018, 03:12 PM | #30 | ||
Lord Scrip
1823
Rep 3,018
07-18-2018, 11:29 PM | #31 |
Rep 163
07-18-2018, 11:41 PM | #32 | |
Rep 163
This is #7 that I need to replace and this is the last but one on the driver's side. Even if I get to do it, I still need to figure out how to deal with the faulty codes. To be frank, I am in awe of my car for all the wonderful things that the previous owner had done and hope to keep it the same way for ever - with its exterior wrap, its BPM coding, Akra exhaust and aFe intake So, I am nervous about doing something that could screw up one thing or the other and leave me stranded as there is no reputable mechanic shop nearby. Prepared to pay a bit more to someone who knows what they are doing and if it is a local, I will be glad that I gave them some business. I scheduled an appointment this Friday with Shade Tree Garage, a long standing and reputed mechanic shop who are also involved with my NJ BMW CCA association. Will share what they say. Thanks for the feedback! Last edited by BimmerRules!; 07-20-2018 at 11:56 AM.. |
DrFerry6731.50 |
07-20-2018, 11:55 AM | #33 |
Rep 163
Update -
Got the plug replaced @ Shade Tree Garage, one oft the reputed shops that also supports our local BMW CCA chapter. Great place and very professional! From what I learnt from the tech who worked on my car: - slightly surprised that coil had failed for a low mileage car but he has seen that happen. - cannot tell by just viewing the coil (both of which btw look only mildly used) as sensors on top could have been the issue. - checked the NGK plugs and said that its been pre-gapped and that its best to leave it the way it is. - noticed a lot of debris/dirt where the coil goes and that he had cleanred it all out. That could have also played a role in this failure. - if another coil goes, just replace the remaining 6. - no issues of the oxygen sensor and car looks/run fantastic. Delighted to drive the car back with its usual super power and smoothness. So, i am going to check with my master-tech friend if he can check and clean out the other 7 and hopefully that will be all I need to do. A minor thing I noticed when exiting the shop and when stopping @ the first few lights - a split second loss of power (as if car didn't have gas or was misfiring) when shifting at the low gears (1-2 and then 2-3). It happened a couple of times but then I entered the highway and didn't notice again even after exiting the highway and taking the local roads to home. Hoping that it was a temporary one at the initial stages because of the new coil. Fingers crossed. |
04-24-2024, 04:29 PM | #34 |
Rep 61
Drives: 2008 E92 M3
Reviving this thread...
So it's 2024 and my 2008 M3 finally had its first coil failure.
Check control message was in limp mode (engine malfunction, reduced power) and also Increased emissions. This was a few days until I could get it to the dealer so driving locally wasn't a problem. Then the malfunction disappeared but the acceleration was hesitating. Cylinder 3 coil failure confirmed by the shop. They SA suggested to change all the coils but really dealer's choice. SA said it could be months before the next coil fails. So it's either $400 now (for one) or $3500 later (for all). I'm opting for one coil and keeping an eye out for the next failure (whenever that happens) via OBD scanner. 228k+ miles on my car so far.
2008 E92, Sparkling graphite metallic, Fox red interior, Carbon roof, iDrive
04-24-2024, 05:37 PM | #35 | |
289
Rep 1,543
Not bad !! |
04-24-2024, 07:46 PM | #36 |
Rep 4,176
There's no need to preemptively change all the coils, especially not at today's prices. Just change the ones that are broken.
RocketyMan230.50 |
