10-25-2023, 09:05 AM | #1 |
Rep 27
Drives: BMW X5 xDrive 40i
2021 X5 Change Drivers
I'm sure this has been answered here before. But, would very much appreciate some help.
My wife and I each have key fobs programmed with individuals profiles. When she get in the passengers seat (with her fob) the car adjusts to her profile setting. Then I walk around the car to the driver's side (with my fob) the car seat and settings are set to her profile. How do I get the car to reconfigure to my profile settings; i.e., read my fob's profile settings? Thanks for your wisdom and insights. |
10-25-2023, 09:19 AM | #2 | |
Rep 4,335
- She stays out of range till the car sees your key. - If we're just driving around town, she doesn't take her key with her. - On trips, she puts her key in a faraday pouch so the car doesn't recognize it. A Faraday pouch will also prevent her key from transmitting and being detected by a relay theft. I also put mine in a pouch when we park the car. |
10-25-2023, 11:01 AM | #3 | |
Rep 8,700
Drives: eVeRyOnE mAD!
on my 2021 45e, we noticed this issue and used to do the above or use a faraday pouch for the unused fob, but we very rarely have this issue now because I found that holding the driver door handle for about 3-4 seconds before opening the door will recognize my fob then switch to my driver profile. additionally, I don’t let go until I see the ambient LED change to my color and my seat begins to move into position |
Marty in NY2720.00 |
10-25-2023, 11:19 AM | #4 | |
Rep 4,335
10-25-2023, 12:34 PM | #5 | |
Rep 850
Drives: BMW Z4 M40i, BMW X5x40i
2023 Z4 ///M40i Thundernight Metallic/Cognac Vernasca/Moonlight/Shadowline/19" Black 799M/PP/DAP/ACC/HK
2022 X5 xDrive40i Phytonic Blue/Cognac Vernasca/DAPP/LSP/PP/CCP/PAP/20" Style 738/Spare Tire/Trailer Hitch |
10-25-2023, 12:51 PM | #6 | |
Rep 8,700
10-25-2023, 07:42 PM | #7 |
Rep 27
Damn!!! The touch the door handles for 4 or 5 seconds recommendation has worked for me (for my wife and me) 5 or 6 times today.
nZtiZia - Thank you very much for taking time to share this information. You've solved a nagging problem for us. Thank you, very very much. I knew about the Faraday pouch solution, but my wife did want any more "stuff to manage in her purse just to ride in the car." I also tested the "lock and unlock" option. That's a functional solution that I'll keep as a back-up if needed. Thanks to all who replied, I really appreciate you taking to read and reply. |
nZtiZia4656.00 |
10-26-2023, 09:49 AM | #9 |
Rep 8,700
I’ve never seen that message pop up automatically, only when I manually select the driver profile icon up top then select a different profile. please share what “set up” you are referring to as I’m not aware of any setting
