05-20-2021, 08:33 AM | #1 |
Rep 264
Rear Defroster button blinking
What does this mean? I can't get to the online BMWUSA manuals for car. Google searches say low battery.
I know it's not low battery because I checked at the jump start points and directly on the rear 12v battery. Fans in HVAC aren't running and when I go into the Comfort Setting to set the SYNC between driver and passenger, it's unavailable
2019 M5 Competition
2021 X6 xDrive40i M Sport 2018 Toyota RAV4 AWD 2008 Corolla S Souped Up - The Black Widow Last edited by GREENPUS; 05-21-2021 at 06:18 PM.. |
05-21-2021, 02:32 PM | #3 |
Rep 264
Rebooting didnt help. Im curious what others have when they look at their Energy Flow Monitor on the mild hybrids. I wonder if thats real world, real time or just a pretty picture that gives people a warm fuzzy feeling. Mine says the 44v Lithium battery is half charged.
2019 M5 Competition
2021 X6 xDrive40i M Sport 2018 Toyota RAV4 AWD 2008 Corolla S Souped Up - The Black Widow |
05-21-2021, 06:17 PM | #4 |
Rep 264
Dropped by the dealer and was told its multiple failures and never seen before. Going to leave it at the dealer next week...
2019 M5 Competition
05-25-2021, 02:21 PM | #5 |
Rep 264
Dealer came back with X6 had programming errors. Took the dealer about 2 hours to reinstall programming.
This started the same day I hooked up a ctek agm smart charger to the jump start points under hood. Im starting to think mild hybrid = POS
2019 M5 Competition
06-06-2021, 02:05 AM | #6 |
BMW Elite Master Tech | HV Gen 5 | HV Specialist
3511
Rep 4,208
Mild hybrid system doesn't charge the low voltage battery or vice versa when the hood is opened fyi. It's a standard feature that the mild hybrid system is deactivated when the hood is open.
GREENPUS133.00 |
06-06-2021, 08:37 AM | #7 | |
Rep 264
Thanks. I wasnt trying to charge the 44/48 volt lithium battery. I was attempting to charge 12volt. Its my understanding the 48 volt system is deactivated when hood is opened and this is the correct way to charge 12volt on mild hybrid car. Sad part about this situation, my bmw dealership knows nothing about these mild hybrids
2019 M5 Competition
freshxdough3510.50 |
06-06-2021, 01:57 PM | #8 | ||
3511
Rep 4,208
GREENPUS133.00 |
06-13-2021, 01:34 PM | #9 |
Rep 264
Here we go again. I connected the CTEK smart charger to the jump posts under hood. After 2 days the heater defroster light started blinking again. My climate control system is dead. I know this CTEK is good because I use it on another car with AGM battery
2019 M5 Competition
06-14-2021, 03:13 PM | #11 |
Rep 264
timmahh I have a few cars/bikes I keep on smart chargers during winter months since I can't drive them daily.
Never had this issue before with CTEK smart chargers and this one I am using has been tested on other cars and bikes with AGM batteries. When I park this X6 this winter I need to know this smart charger works and apparently something is up with this X6 and the mild hybrid tech which doesn't want to play nice. I'm getting to the point of saying screw it and connecting directly to the 12 v AGM battery....
2019 M5 Competition
06-14-2021, 05:10 PM | #12 | |
ghey
483
Rep 2,041
21 G05 > 20 G05 > 17 G30 > 14 F30 > 08 E90
06-16-2021, 05:22 PM | #13 |
Rep 264
Dropped it off at dealership. Service manager told me there is a service bulletin on this car for this issue. Apparently there's a special procedure for trickle charging these mild hybrids that BMW didnt bother telling anyone If this service bulletin works Ill try and get the info and post here.
On a good note he gave me a 2021 X3 M Competition as a loaner. Stomped the mother and all 503 HP's and had it up to 101mph in seconds. Hope the dealership didn't see me
2019 M5 Competition
2021 X6 xDrive40i M Sport 2018 Toyota RAV4 AWD 2008 Corolla S Souped Up - The Black Widow Last edited by GREENPUS; 06-16-2021 at 06:04 PM.. |
07-07-2021, 09:30 PM | #14 |
Rep 264
SIB 61 01 21 dated 3-2021 which replaces the version that came out in January 2021. In my case using a smart charger on my mild hybrid forced it into transport mode requiring X6 to be reprogrammed by dealer twice
2019 M5 Competition
2021 X6 xDrive40i M Sport 2018 Toyota RAV4 AWD 2008 Corolla S Souped Up - The Black Widow Last edited by GREENPUS; 07-08-2021 at 05:27 AM.. |
11-03-2022, 02:00 PM | #15 | |
Eagle1
19
Rep 57
Info needed ref your post
Hi What do you mean by: force into transport mode? (I usually speak french sorry) Thanks John |
11-03-2022, 09:29 PM | #16 | |
257
Rep 332
P.S. I saw that this thread is over a year old but since it was revived anyways, thought I would add the SIB.
2020 BMW X5 M50i . Tanzanite Blue II . Black Merino . Extended Shadowline . 742M Black / ART Replica 181
07/2019.55 (since birth Oct.1,2019)-> 11/2019.70 (OTA Aug.11,2020)-> 11/2020.36 (Dealer Nov.25,2020)-> 03/2021.50 (OTA Jun.15,2021)-> 07/2021.85 (OTA Mar.1,2022)-> 07/2022.58 (OTA Dec.9,2022)-> 11/2022.60 (OTA Mar.2,2023)-> 03/2023.50 (OTA May.31,2023)-> 07/2023.35 (Dealer Aug.21,2023)-> 11/2023.50 (OTA Feb.9,2024) |
11-05-2022, 06:31 AM | #17 |
Rep 264
The Transport Mode is a setting originally designed to prevent the batteries from being drained during the transportation of the vehicle from the factory to the dealership. Normally, you can have the Transport Mode reset by visiting your local service dealership. You can also do it yourself by using the DIS software. In my case it totally ended up being corrupted and had to be reloaded. If I remember right it was close to 2 hours to complete. I no longer use a trickle charger on my X6
2019 M5 Competition
