10-24-2022, 11:02 AM | #1 |
Rep 50
7 Pin Trailer Aux 12v Fuse
Hello,
Looking for diagrams on the fuse boxes and locations of them to try to replace the 12v aux feed in the trailer 7 pin connector. Accidentally popped the fuse when raising my electric tongue jack hit it's max upward position and definitely overloaded/popped the fuse. If you know where this fuse is located or if not have a good source for fuse diagrams that would be greatly appreciated! Many thanks, Ryan |
10-24-2022, 11:17 AM | #2 | |
Unapologetic Tool Hoarder
734
Rep 964
10-24-2022, 11:28 AM | #3 |
Rep 50
Thanks so much for your help. The second image is a bit fuzzy so I can't read the numbers. Also which fuse box location do you think it is (213)? I believe there is one in the trunk somewhere, passenger up near feet and one more?
10-24-2022, 11:55 AM | #4 |
734
Rep 964
The second one is just a screenshot of the guide that's in the rear wheel well. Pop the panel out and you should see the power distribution box/fuse panel. The white paper guide is folded up in there next to the fuse removal tool. Pull it out and unfold it if you need the reference. But yes, I believe it is Fuse 213 and you can remove it with the tool.
10-25-2022, 12:37 PM | #5 |
Rep 50
Thanks so much for your help weinerbarn! You hit the nail on the head, that was the fuse, super simple and 12v aux in 7 pin connector works as it should again. I appreciate you taking the time to help a fellow X5 owner out
