11-05-2022, 02:37 AM | #3 |
Rep 47
I previously encoded Assist driving and TLA and everything works. Later I wanted to delete the errors that usually come out after encodings, but these remained in memory.
11-05-2022, 03:53 PM | #4 |
Unapologetic Tool Hoarder
734
Rep 964
Sorry can't help you there. I only use E-sys launcher pro, BimmerUtility or ISTA if I need to do more advanced coding since it works out the dependencies with other modules. BimmerCode is fine for tweaks but if you start changing settings and don't do all related modules, you can get errors or non-working. Not sure if your tool does backups of the before coding. You could try rolling back and see if the errors go away. Then you'll just have to work out what you might have missed.
11-06-2022, 07:26 AM | #5 | |
Rep 47
