08-14-2022, 02:12 PM | #1 |
Rep 20
Swirls in glossy black plastic trim on door pillars
Car is about 2 months old and already getting swirls in the for pillar trim. I guess is is not that unexpected from my research. Also found that PPF on the trim should help for a period of time.
PPF is an option for me, but am wondering if anyone here has found a more "DYI" solution to these swirls. |
08-14-2022, 04:01 PM | #2 | |
Rep 212
As you said, PPF does a marvelous job at hiding fine scratches; mine was pretty bad and now they're barely noticeable; I used Adams Graphene coating on top of the PPF and it's even harder to see anything now. The piano black trim is also covered by a clear coat, so my buddy polished his before applying the PPF, and I have to say, it does look slightly better than mine, though I'm not sure if it's worth the risk. He followed these instructions (), but the danger is that the clear coat can be destroyed if things get too hot or fast, so you need to be pretty careful. |
SeldomSeenKid7.50 |
08-14-2022, 05:38 PM | #3 |
Rep 442
Third BMW with the same trim. I hit it once or twice a year with Meguiar's cleaner wax on the orbital buffer and they look great.
Actually two weeks ago, my dad purchased a two year old F150 with similar trim that had two scratches on the passenger side window trim. I assume swiping a tree limb at some point. The Meguar's and my orbital buffer did a great job. I don't overthink it and have had great experience maintaining these. My two cents. |
SeldomSeenKid7.50 |
08-14-2022, 10:50 PM | #4 |
Rep 20
TB-M5 Chas8283
Thanks for the tips. I think I am going to go the polish route this next weekend and see how it turns out - it's my detail weekend anyhow. Think I could use hand polish on the inside piano black trim? May get kind messy.... |
08-15-2022, 08:01 AM | #5 |
Rep 442
Didn't realize this was (or was also) interior. If you're talking about piano black wood trim (or other high gloss trim), then yes I've done the Meguir's there too with good results. If you're talking about the high gloss black plastic on the center console I haven't had to deal with any scratches there (yet). If/when I do I'd likely use a polish designed for plastic.
Regardless, if doing by hand, use to use a soft towel and light pressure and take your time. Should turn out good. |
08-15-2022, 05:15 PM | #6 |
42
Rep 38
polish it out and then ppf it.
had it on my RR black trim panels and it never swirled. the black paint with modesata coating, swirled up and got water spots all the time. never getting a black car ever again... ugh. so hard. |
