11-17-2023, 05:44 PM | #1 |
Rep 12
2024 X5 Not recognizing some speed limit signs
Just changed from 2022 540i to 2024 X5.
X5 recognizes speed limit signs, but it does miss some, too. (This was never the case with 540i) Is there any sensitivity setting or adjustment? Thank you for your input in advance. |
11-17-2023, 07:20 PM | #2 |
Rep 2,105
There is no user setting for this. However my recommendation would be to leave it for now and see how you get on.
In some situations like direct sunlight it will have issues. My assisted driving system was malfunctioning with errors (its the same camera thats used for reading speed signs and assisted driving). The dealer installed latest software and then recalibrated the system. It took them about 200 miles of test driving and 3 days without the car (kept getting errors and failed to recalibrate) and i still dont think its right. The augmented reality view looks all washed out and messed up now. It was much better before they started fiddling with it. |
11-18-2023, 01:27 PM | #3 |
Rep 114
My 2023 X5 has a quirk where if it doesn't see a sign it defaults to 40km in town, whereas the unposted speed limit is always 50km, so it constantly tells me i am driving 10k over the speed limit in red. Not a big deal, but frustrating.
03-15-2024, 07:15 AM | #5 | |
Rep 131
If you can get access to the camera lens, try cleaning it with some alcohol and a cotton swab. |
03-15-2024, 12:06 PM | #6 | |
Rep 12
My dealer said the problem was a program and by re-programming this "was" fixed. There was a recall on the programming which could cause false Check Engine signs, too. |
03-15-2024, 03:02 PM | #7 | |
33
Rep 49
Not Quite
My wife's Miata does much better using map data instead of the camera. |
03-15-2024, 03:10 PM | #8 | |
13275
Rep 19,800
03-15-2024, 05:00 PM | #9 | |
33
Rep 49
03-15-2024, 05:26 PM | #10 |
Rep 887
This feature is kind of flanky at the best lol
MJBradley1967192.00 |
03-15-2024, 05:29 PM | #11 | |
13275
Rep 19,800
03-16-2024, 03:50 PM | #13 |
13275
Rep 19,800
I would have the same expectations as you. I can't remember either my X5 or M340i missing a sign.
03-16-2024, 04:42 PM | #14 |
Rep 474
Drives: 2022 BMW X5 xDrive 40i
Mine occasionally shows 20mph after turning a corner onto some Wisconsin back roads, even though there was definitely no 20mph sign anywhere around.
Illinois school speed limits are 20, Wisconsin's are 15, so no idea. Otherwise pretty accurate, at least when I'm paying attention to speed limits
2022 X5 xDrive40i
Black/Black/Black Last edited by MJBradley1967; 03-21-2024 at 02:04 PM.. |
03-16-2024, 06:17 PM | #15 |
Rep 850
Drives: BMW Z4 M40i, BMW X5x40i
The whole system is problematic at best. It does pretty good on major roads, but even there it has issues. On multiple laned roads, there are times trucks will block the view of a sign resulting in the system holding the last read sign.
My biggest gripe is school zones. Here they are 20 mph when active which amounts to about 3% of the time over a year. So the majority of the time, it's telling me the speed limit is 20 mph when it isn't. And there are issues at the end of the school zones. Some just have an END SCHOOL ZONE sign which doesn't reset the system so it will show the speed limit as 20 mph until the next sign. The one nearest my place has the END SCHOOL ZONE sign butted directly above a 35 mph sign. The system correctly reads this sign about 20% of the time. What scares me is the politicians that want to use these systems to actually limit the speed of your car. It's a recipe for disaster.
2023 Z4 ///M40i Thundernight Metallic/Cognac Vernasca/Moonlight/Shadowline/19" Black 799M/PP/DAP/ACC/HK
2022 X5 xDrive40i Phytonic Blue/Cognac Vernasca/DAPP/LSP/PP/CCP/PAP/20" Style 738/Spare Tire/Trailer Hitch |
eluded3043.00 |
03-21-2024, 10:04 AM | #16 |
Rep 5
Tombstone, AZ. That is apparently an 80 mph speed limit sign. At least according to my X5. https://maps.app.goo.gl/pWj9cfz9g79Rc5V57
03-21-2024, 10:10 AM | #17 |
221
Rep 326
I just did a trip from Houston to Colorado and I did not have any issues with missed signs. Weird.
Current - ? 20 X3MC
ED 2016 - F80 M3 - SO/SS CP, LP, EP DAPP, 6 SP :drive: MY ED 2016 WRITEUP 2013 - 2010 E93 M3 DCT, White/ Black - beauty. :Perth, Aust. (sold 2014) 2011 - 2006 E46 M3 Conv SMG Black/black - great (except for SMG) (Perth, Aust). 1st foray into M's -slippery slope (sold 2013) ED 2009 E90 335i - Le Mans, (sold 2010)[URL="http://www.bimmerfest.com/forums/showthread.php?t=365925 |
03-21-2024, 12:33 PM | #18 |
Rep 162
Drives: 2024 BMW X5 M60i
Mine frequently lists the speed limit, but incorrectly. For example, I live 4 blocks from a school zone but it always shows 20mph school zone on my street.
03-22-2024, 10:17 AM | #19 |
Rep 208
This was my drive through Florida, Alabama and Georgia last month. The car read everything really well.
I had to constantly keep hitting the "SET" button, (it's set for 8 MPH over when 45 and up and 4 MPH under 45). The speed sign on the dash would change just as I passed the sign... |
aussieintexas220.50 |
03-22-2024, 03:38 PM | #21 |
13275
Rep 19,800
They reversed the logic so it takes the speed limit from the map data first and then the camera. That is supposed to be fixed in a later update.
03-22-2024, 03:43 PM | #22 |
Rep 11
So even if the camera sees a limit of say 45 mph but map data has 35 mph, the speed limit on the instrument cluster will keep showing 35 mph - is that a correct understanding?
