      05-21-2019, 04:27 PM   #1057
Sassicaia
Sassicaia's Avatar
4453
Drives: SMB F80 6MT
let me trying posting this again..
fired up the bakerstone this weekend (sorry dont know why images are uploading sideways)
P111572.00
      05-21-2019, 04:40 PM   #1058
KenB925
Drives: ZL1, Raptor
Looks good.
How long does it take to cook?
What temp does it get up to?
      05-21-2019, 04:40 PM   #1059
Sassicaia
Sassicaia's Avatar
4453
Drives: SMB F80 6MT
Originally Posted by KenB925 View Post
Looks good.
3-5 minutes. It gets VERY hot in that oven.
      05-21-2019, 04:44 PM   #1060
Sassicaia
Sassicaia's Avatar
4453
Drives: SMB F80 6MT
Here is the pizza doe recipes if anyone is interested. Its very easy
415 grams flour (00) see picture for best choice
9 grams salt
270 grams water
1.5 grams of fresh yeast, or 1 gram of dry
Olive oil for coating.
Tap water should be 65 F.
Add yeast to water and stir to combine
Combine flour and salt
Make a well in a mixing bowl and combine flour/salt to water.
Mix roughly with a spoon to combine.
Then put the bowl in.a stand mixer with a dough hook and mix on medium speed for 7.5 mins.
Dust work surface with flour and shape the dough into a ball.
Put the dough in a bowl and cover with a towel and let ferment for 6/8 hours, better 8 if you want to use it tomorrow.
Make sure the room is around 65 F.
Use a scale and divide the dough into 3 230 gram balls, or 2 bigger ones if you like larger pizzas.
Put oil on your hands and cover the balls and transfer to the fridge and let rest for 30 mins uncovered.
Then either cover with an airtight lid, or wrap individually with cling film and rest overnight in the fridge.
30 mins before you are ready to make the pizzas, take them out and rest on a floured surface before shaping.
Stretch into the pies on a floured surface and make your pizzas!
      05-21-2019, 04:51 PM   #1061
bimmer456
Drives: 340i
Send me amazon link for bbq pizza oven.
      05-21-2019, 04:54 PM   #1062
Sassicaia
Sassicaia's Avatar
4453
Drives: SMB F80 6MT
https://www.bakerstonebox.com/
its really inexpensive.
homedepot is the easiest place to get it.
      05-21-2019, 05:18 PM   #1063
KenB925
Drives: ZL1, Raptor
9 grams salt
270 grams water
Looks like a solid recipe.
It is surprising how much of a difference 00 flour makes over even bread flour.
If you start messing around with fresh milled flour you won't believe what a difference it makes.
Sassicaia4453.00
      05-21-2019, 05:21 PM   #1064
bimmer456
Drives: 340i
It's $128 at Home Depot but it's out of stock.
      05-21-2019, 05:33 PM   #1065
Sassicaia
Sassicaia's Avatar
4453
Drives: SMB F80 6MT
You should be able to order direct from bakerstone.
      05-21-2019, 05:44 PM   #1066
bimmer456
Drives: 340i
Looks like it comes with the pizza spatula at Lowe's. Also out of stock though. Not sure if you can order direct from the mobile site maybe need the desktop version or someone in the Amazon marketplace.
      05-21-2019, 06:17 PM   #1067
Sassicaia
Sassicaia's Avatar
4453
Drives: SMB F80 6MT
it should come with both the pizza spatula and wooden peel as standard.
      05-22-2019, 12:46 PM   #1068
TrevorM3
3322
Drives: 6.3 AMG
lsturbo, post 988, teach me.....
      05-22-2019, 12:58 PM   #1069
12v_dub
12v_dub's Avatar
Drives: 21' M340i
Did a bird on JoeTisserie over the last weekend. Came out amazing
View post on imgur.com
Appreciate 4
upstatedoc7559.50
bimmer4562960.50
P111572.00
      05-22-2019, 01:38 PM   #1070
UncleWede
UncleWede's Avatar
Drives: G01 X3 M40i Dark Graphite
Originally Posted by lsturbointeg View Post
Fam Bam wanted burgers Saturday night so here's how I do mine!
Ground sirloin?
      05-22-2019, 02:40 PM   #1071
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
Originally Posted by UncleWede View Post
Ground sirloin?
I believe so. there's actually 2 varieties that Sams Club sells and maybe you guys can tell me the difference. one says sirloin while the other says angus. arent' they both the same? prices are about $1 difference
~F90Conversion~21"3Piece Forged AvantGardeWheels~KWV1Coilovers~CQUENCE slotted/drilled rotors~GoodridgeStainlesslines~MeisterschaftQuadEx haust~Akrapovic 4"tips~VRSF DP~VRSF CP~TurboSmart BOV~K&N filter~CarbonFiberExteriorComponents~GladenAlphaCo mponents~MatchUp7BMW~Punch P300-12T~
Follow me on Instagram: lsturbointeg
      05-22-2019, 02:50 PM   #1072
lsturbointeg
pretty much you can use whatever meat you like. I use kosher salt and let it tenderize for about 1.5 hours in the refrigerator. than wash it off and pad dry with a paper towel. than whatever seasoning you like. my family likes Applewood Rub and or Montreal/Chicago steak seasoning. on a very hot grill 2 minutes than turn 180 the other way to get the grill lines for another 2 minutes. flip them bad boys over and repeat. lower the heat on half the grill, turn the other burners off and let the meat cook on the cold side until you're desired likings. for me I find it takes about 12 min total for a medium cook steak.
upstatedoc7559.50
nyalpine907433.00
      05-22-2019, 03:25 PM   #1073
Alfisti
Drives: 2008 Saab 9-3 Combi
Barbarians is the best steak seasoning, brings out the flavour without the terrible over-black peppered taste most steak seasonings have.
http://www.barberians.com/steak-spice/
      05-22-2019, 03:34 PM   #1074
lsturbointeg
awesome! was about to order it from Amazon but shipping is ridiculous! $17.48
anyone else have recommendations for some pretty good steak seasoning?
      05-22-2019, 05:44 PM   #1075
UncleWede
UncleWede's Avatar
Sirloin is the cut of the cow that is ground up into patties and generally has a higher quality/flavor, with slightly less fat than chuck(normal burger). Angus is the type of cow that is genetically different and supposedly has better marbling and flavor of the meat.
      05-23-2019, 07:42 AM   #1076
Alfisti
$18! Damn. It's really, really good because the meat still tastes like meat, there's no overpowering flavour it just enhances the beef. Try direct from the store.
      05-23-2019, 01:19 PM   #1077
lsturbointeg
Hmmmm...probably cause it's coming from Canada?
      05-23-2019, 01:54 PM   #1078
Alfisti
Yeah but still ... jebus that's a hell of a fee.
