06-30-2021, 12:09 PM | #23 |
Rep 29
Drives: 2022 BMW X5 MSport
spacers
I just recieved the Dinan spacers 12mm for front and 15mm on rear. I went with 40mm and 45mm lugs. Once installed and we put a few miles on them we will include a pic and an update.
dananelson1226.00 |
07-01-2021, 12:13 AM | #24 | |
Rep 2,610
Assuming that my caution above is unfounded, you will still have to keep track of front vs rear bolts now since 45mm bolts on 12mm spacers would definitely not be ok. In hindsight, it probably would have been simpler to stay at 40mm bolts all around for the 12/15mm spacer configuration as highlighted multiple times on this thread … but it's not that big a deal either.
07-04-2021, 07:33 AM | #25 | ||
BMW Junkie
176
Rep 306
Current Stable: 2021 BMW X7 xdrive40i, 2020 BMW X3 xdrive30i, 2017 Toyota Tacoma TRD-OR
Retired BMWs: 1999 BMW 328i, 2005 BMW M3 ZCP |
11-30-2021, 03:38 PM | #28 |
Rep 262
chuckins9 debating between the popular 12/15 setup vs perhaps what you did as middle ground between the other popular 15/20 set-up.
Can you post pics? Or did you somewhere else? Thanks. |
12-13-2021, 03:27 PM | #30 |
Rep 262
12-14-2021, 12:43 AM | #31 | |
Rep 558
I got them from Dinan's site - https://www.dinancars.com/products/w...ories/spacers/ Will upload some pics tomorrow, but if I were to choose again I will go with 10mm front, since the front tires stick out more than the rear now. |
dananelson1226.00 |
12-14-2021, 03:46 PM | #32 | |
Rep 262
Interesting that you'd go 10mm up front. The guys at RG Sports and vast pool seem to give the impression that a 12 front/15 rear is the cleanest set-up, with 15/20 being the clean aggressive set-up. Perhaps like what you did, I was thinking of a 12/17 set-up as a happy medium...
Look forward to pics. Are you on 740m, 741m or other wheels? Quote:
r33_RGSport13070.00 |
12-14-2021, 10:57 PM | #33 | |
Rep 558
The offset of different rims and tire choose will make a difference, but in my case, even 12mm front makes the OEM Pirelli tires stick out (a tad) past the fender. |
12-15-2021, 08:51 AM | #34 | ||
13070
Rep 18,774
I always use the top of the fender as reference point. Here is an example how I look at it from my view.
12-31-2021, 10:59 AM | #35 |
Rep 56
Just to be on the safe side would 10mm spacers all around work as well?
dananelson1226.00 |
01-20-2022, 05:56 PM | #36 |
Rep 262
motherkin any updated photo's of the 12/17 spacers on your wheels, etc? vs 12/17 Finally refreshing my needs here between Dinan; FutureClassic; or H&R; 12/15 vs 12/17, etc.....
All seem good.... Cheers! Last edited by dananelson1; 01-25-2022 at 02:23 PM.. |
01-17-2023, 04:25 PM | #37 |
Rep 21
Drives: Bmw g05 Bmw e66
Got mine today from Dinan
Was so disappointed that 3 out of 4 have dings on them, box was intact with no physical damage. Each spacer was nicley wrapped, it blows my mind dinan puts product in such codition into packaging and ships it out to a customer. Not that big of a deal but still..... |
