05-05-2024, 04:10 PM | #1 |
Back in a BMW
293
Rep 389
CTEK Charger
So I have apparently not been driving the x5m enough. Battery maintenance light almost every day. Added the CTEK TODAY and it’s been on for a few hours
Still looks super low charge. Thiughts team? Should I do this everyday? It’s just clipped to the front terminals atm.
21' Donington on Black X5M | Comp | Exec
11' 1M Coupe Valencia 6MT OEM+ 289 of 740 |
05-06-2024, 07:08 AM | #2 |
1008
Rep 1,507
How long does it sit w/o driving? On my 2006 Mustang, which is my show car, I plug in my charger from time to time to keep the battery at peak. Sometimes it sits for up to 4 weeks.
2021 Jeep Grand Cherokee SRT Black 2006 Ford Mustang GT Convertible (show car) |
05-06-2024, 09:15 AM | #3 |
Rep 8,835
I use my ctek daily and even if my battery is at 90+ % it will still take the ctek a few hours to move from 3 to 7/8. Usually within a few hours it would move to that status but if the battery is low where I haven't used the ctek for awhile it would take closer to 15-20 hours to get to stage 7/8. I usually verify the battery level using the bimmerlink app.
05-06-2024, 11:31 AM | #4 |
Rep 1,022
OP. FWIW, hit mode. It should be set on AGM fwiw.
The one you have is set for flooded cell.... Your unit is 5A output. They do make a 7 and 10 . The larger units will be faster during the bulk charge, which is step 3 that your pic seems it's still on. IME, on the opposite spectrum, a decent charged battery may take anywhere from 45-90 minutes for it to be on bulk. The Loooongest times is the absorption phase, which is basically # 4 on your unit. But every Ctek unit is different in its algorithim. The larger unit on mine, in absorption seems to run a bit *faster* than my smaller unit...which like 2X faster but it shouldn't as it's just declining current trying to fill up every nook and cranny. Regardless, you're on the right path as *all batteries* as most happiest at full SOC Last edited by chefwong; 05-06-2024 at 12:10 PM.. |
05-06-2024, 03:45 PM | #5 |
Back in a BMW
293
Rep 389
Thanks everyone duly noted the information. It’s typically driven every day but probably not more than 10 to 15 miles. I typically drive it to work but I’m pretty local. But I did notice today, It was operating a bit better after being charged overnight.
I will look into getting the larger unit though.
05-07-2024, 08:25 AM | #7 |
Rep 1,022
Don't let my bad experience sway you buy I used to keep the entire fleet on chargers. Had pigtails installed for easy access, etc. I once had an expensive deep cycle go bad - and the only thing I could attribute it was possibly the charger....
So I don't keep them on the car consistently but only -charge/maintain/top it off- based on known use cases - where it's been driven 1-2X over the course of 2weeks, and it didn't see much -alternator charging, etc. Bear in mind, with efficient dynamics, the alt is on clutch, so it mainly charges when you're braking, etc. There is a threshold where the Alternator will turn constant it if the battery is low enough but regardless, any battery is best when it's always at a full SOC |
