10-31-2019, 09:00 AM | #265 | |
150
Rep 365
Your recall is an update to the iDrive to allow OTA updates. Its common knowledge to never allow BMW (or any dealer to prep the car) just a big no no Absolute nonsense about your friends advice. There is no way that a car would notify anything of that sort via wifi. They would not invalidate warranty, they wouldn't uphold a claim if your engine went pop because of a remap. However, if your sunroof started leaking, its unlikely they'd blame an ECU remap? I'm very friendly with my local dealership. They said that they wouldn't go looking for a remap unless they needed to. Its also not a case of them running a diagnostic and big red flashing sign coming up on the computer saying ECU remapped. They'd need to check the DME log, look for over runs and over boost in data logs. Check when data was manipulated. latest remaps are smart enough to effectively wipe those entries at a point when you turn the car off, however, a deep dive within data would still show when an ECU was altered. The quickest way to show a remapped car would be to test drive, as its stupidly obvious then. Last edited by sjak92; 10-31-2019 at 09:06 AM.. |
10-31-2019, 09:19 AM | #266 | ||||
Rep 137
Now - G05
Previous - F32 |
10-31-2019, 09:52 AM | #267 | |
150
Rep 365
£92.25 gets you 660 miles so 92.25/660 = 0.0139 If you did better MPG and got 700 miles from a tank, your calculation would be 700/92.25 = 0.0758 and it wouldn't make sense that you'd get more miles from same pric costing more per mile 92.25/700 however = 0.0131 which is slightly cheaper as you'd expect. |
10-31-2019, 10:20 AM | #269 |
Rep 253
10-31-2019, 11:33 AM | #270 | |
Rep 195
Excellent deal, similar to what I managed to get but on a M50D.
First they were having none of it, apparently no support on M50D but when I told them another dealer was offering the same support as that on a 30D they matched and bettered it. My only nag, my dealer got me a MY19 which I didn't know, the other dealer was getting me a MY20 directly from the docks, I was under the impression both were quoting for the same car. Unfortunately, that was not the case but regardless, I am enjoying the drive albeit MPG could be much better Quote:
G05 X5 M50D - Carbon Black - Tech Pack - Comfort Pack - Sky Lounge - Individual Merino Leather
10-31-2019, 05:34 PM | #271 |
Rep 691
I wish mine was frugal ... as expected sub 13-14 mpg in town and probably around 18 average. The exhaust note could have been raspier. However the V8 twin turbo has the pace when required and it does move like anything. All hail the M50i.
I have driven the 45e already which was very nice and the transition between electric / ice was second to none. It should be a compelling choice for people doing a lot of stop start driving. |
10-31-2019, 07:07 PM | #272 | ||
Rep 137
Now - G05
Previous - F32 |
11-01-2019, 03:26 AM | #273 |
Rep 236
Mine was from Sytner dealership.
Question. Isn’t the fuel tank 80/83 litres as in my manual. Also all used G05 being advertised with oil service at 24 months/25000 miles. My car said oil service in 16000 when I got it. Has this changed? My friend was a technician for bmw for 10 years and I was only stating what he told me. He said the remap practically does flash up on the screen. No it won’t invalidate a leaky sunroof but he said it would on engine and gearbox related claims . Mpg . I’ve done 1600 miles now mostly motorway . 39 mpg in a long run. 32 mpg since car was purchased . |
11-01-2019, 04:24 AM | #274 | |
150
Rep 365
25k service would be maximum interval, ie only motorway. 16k is the base line for when its reset. The computer then analyses your driving style and adjusts accordingly increasing or decreasing the interval. My car has done 853 miles and service now down to 14k (so its nicked a 1000 miles off of the interval) due to my driving style (most around town) As for warranty, i agree, if something went bust then engine, gearbox diff and probably transfer case in an X wouldn't be covered. However, the engine tolerancies as so far from limits on a stock map a remap adding 60bhp and 100nm does not even come close to causing issues. You'd have to be really unlucky to have problems, especially if the remap is done by a reputable company and not Joe Bloggs cowboy in a back alley shed/garage |
12-09-2019, 03:56 AM | #275 |
150
Rep 365
Hi All, my X5 has been in for some alignment work already (3 times in fact), it has had a full kds and EPS done.
I still think its not right. Question. Is your steering wheel dead straight when driving down the road or has a slight tilt to the left (in my case). I know road camber etc etc (but my old G30 was not this pronounced) I am getting paranoid or is this normal on the car due to fat tyres, camber etc etc? |
12-10-2019, 03:13 AM | #277 |
150
Rep 365
12-10-2019, 03:22 AM | #278 |
Rep 1,155
Must be something wrong, in the UK the camber on roads means if anything the steering wheel should be tilted to the right to keep it straight.
05-08-2020, 11:43 AM | #280 |
150
Rep 365
To revive an old thread - the tuning part...
I purchased the True Tune OBD device as intended back in January however was never able to use it as cars software is too new and OBD mapping was blocked. The idea is fantastic, almost untraceable and a proper remap. However, with constant updates to the car (hopefully OTA soon) the map would be wiped with every dealer visit/update. With newer protocols each time, it's likely I'd have to wait months to remap after the latest update. After all, my November update is still not OBD enabled. So I returned the device and went for a unit from TDI Tuning. Yes I know it will not get the 330bhp and 720nm as advertised, yes I know it is a glorified piggy back device and fools the system. However, install was (once I got to grips with it) 25 minutes. The difference on program 7 is significant. I thought it was a placebo effect but the butt dyno was not lying. With the box installed the 0-62 time measured at 5.7 seconds. That's 0.8 faster than standard and sub 6 seconds is fast as far as I'm concerned. |
05-08-2020, 11:52 AM | #281 | |
Rep 810
Is this just a remap of existing ECU, or is it a new plug-in ECU? |
05-08-2020, 12:32 PM | #282 | ||
150
Rep 365
It then intercepts the signal and alters it on the fly. In effect, it will tell the car that's its running x amount of boost when car is running more therefore, it tricks the car and car ECU sends more boost than it thinks it is actually sending. A remap also does this in theory, but in a much more refined way and can alter many more parameters than the box. First impressions are good. Will see how it performs over a few months |
05-09-2020, 07:23 AM | #283 | |
Rep 68
Any issues along the road, engine errors on dash, problems, and how fuel economy is affected on most aggressive program?
BMW X5 G05 40i M Sport
05-09-2020, 07:34 AM | #284 | ||
150
Rep 365
I would take the Bluetooth add on. Allows map updates remotely |
05-09-2020, 04:33 PM | #285 |
Rep 123
What's the downside to doing this? I assume that if BMW could have coded in more power and better fuel economy to the stock ECU then they would have.
Is it worse emissions? Or more wear on components? Or something else ...? |
05-09-2020, 06:01 PM | #286 | |
150
Rep 365
What do you think the difference is between a BMW 116d and 120d? Or a 320i and 330i? The engine is the same and the difference is mainly in software. The benefit? Improved drivability, more power and torque potentially less fuel consumption (think more torque so less need to shift between gears, more power means more efficient acceleration to motorway speed for example) The downside? More strain on components in theory (but not to a level where they would fail unless you are real unlucky) |
