12-05-2023, 02:21 PM | #23 |
Rep 1,098
Drives: '01 Z3M, '12 335is, '22 540i
Garage List 2012 BMW 335i [5.25]
2012 BMW 335is [5.00] 2008 Infiniti QX56 [0.00] 1967 Chevrolet Corv ... [10.00] 2001 M Roadster [10.00] 2022 BMW 540i [0.75] 2009 528i [9.50] |
Just to run 240V? I paid less than half that to get a 120V run to our spots so that I could plug in a battery tender. I paid less than half of that to get a 240V drop for our pool heater in FL. Also, for $2k, I am not including the actual charger, just the power drop.
12-05-2023, 02:47 PM | #24 |
Rep 483
The entire fire sprinkler system need to change. Water and electric mix equal to nightmare. Who is paying for the sprinkler $$$$$$$ upgrade?
12-05-2023, 03:35 PM | #25 |
6918
Rep 3,277
Drives: E46 M3 Coupe/G80 M3CX
Correct. Water does not work on lithium ion battery fires unless you can submerge the entire battery unit. Thermal runaway is thermal runaway. And the gases that come off the fire will turn your lungs into popcorn in one breath. In the age of EVs you couldn't pay me to live in a condo with underground parking. EVs are complete trash.
eugenebmw1498.50 |
12-05-2023, 06:21 PM | #26 | |
Slow.
3782
Rep 7,151
Drives: Single Turbo N54 on Meth!
People try and put a 8 kW solar system on their house and can be told they need to pay 30k in upgrade fees. Not often but it all depends on the feeder they are on and its capacity. Level 2 chargers can draw 20 kW basically. So a 640kW draw peak you want to add to the property. Lets pretend the cost is only 500k that means a 16k check as to be cut up front. You want to drop 16k to charge your car, which will also cost you money. Average cost for an ICE car is $1100 a year in gas. So basically 15 years to break even not including the cost to charge your ev. That would push the roi out to 18+ years. You staying at that condo for 18 years to get your money back on your investment? Your condo is not instantly worth 16k more because of an ev charger. Also, good luck on your EV charger lasting 18 years without needing replacement. Who wants to break even 18 years later with an old ass ev charger? I just do not see how the numbers work. I would love to know to real estimate of the job. Edit: all of this ignores the space requirements. You will not have 32 parking spaces anymore. Last edited by Torgus; 12-05-2023 at 06:54 PM.. |
carseatsm5839.50 |
12-08-2023, 07:24 PM | #27 |
Rep 3,006
They'll install something like this https://www.chargepoint.com/solutions/parking-operators
or probably something w/ads like this https://www.wsj.com/articles/ev-char...rs-11661421601 |
