04-27-2021, 08:49 AM | #1 |
Rep 202
Drives: BMW X5
Possible solution for missing spare tire kit
I found a website called Modern Spare, which offers spare tires and jacks and tools for cars which came with run flats and no spare.
They are not shipping current orders until about 5-6 weeks so it will be late May before I have the tire. I'll report back when it comes in. The cost was about $440 all-in, which is way more than it would cost to just order the tire in your build ($150) - but way less than BMW charges to get the parts later. (About $900). https://modernspare.com/product/2019...e-kit-options/ You can also order just the tools, or just the tire. Last edited by Timmer-Bimmer; 06-12-2021 at 04:46 PM.. |
04-27-2021, 09:09 AM | #3 | |
Rep 8,739
Drives: eVeRyOnE mAD!
that part you referenced is only the wheel. |
04-27-2021, 09:17 AM | #4 | |
Rep 1,452
I looked into this while shopping around cars that weren't equipped with the spare. In the end I decided against it, because I didn't like the idea of having to use a spacer while running the spare if you had the M brakes. Changing a flat can often be dangerous enough and often done in conditions not ideal, I didn't want to have to add any extra steps or complexity to the process for safety reasons.
No. Try not. Do. Or do not. There is no try.
-Yoda |
04-27-2021, 09:21 AM | #5 |
Rep 1,452
Nope. There is no OEM after purchase kit. You have to buy all the pieces separately. I priced it out when shopping cars without spares and it was like, $800-900 minimum. Its a no brainer to add to the build for $150, but expensive as hell if you add it after the fact.
-Yoda |
iconoclast7265.50 volodp199.50 |
04-27-2021, 09:25 AM | #6 | |
Rep 202
Drives: BMW X5
04-27-2021, 10:51 AM | #7 |
Rep 179
Drives: 2024 X5 40i
I recently purchased the space saver tire "kit" through BMWPartsPro.com. AKA Steve Thomas BMW. A very smooth transaction and delivery within a week of placing the order. Be mindful to share your VIN when ordering. I was in the same scenario - bought for my 2019 X50i Msport CPO with 21" wheels that did not originally come with the spare option. I also bought the OEM jack, crank handle, lug wrench and wheel chock.
Keep in mind that, at least with my 50i which came with the "luggage compartment" option, the spare will NOT fit in the tub under the rear compartment (where it would be if configured that way when built). I will only load the spare when I am on road trips away from the Metro area where I live - just as a backup if the need crops up when I am not close to a BMW dealer or a reputable tire dealer. Because the spare cannot fit in the tub under the floor of the luggage area, there are a few parts that come with the OEM setup one can't use - e.g. the "tray, rod, wing nut" that in an OEM setup retain the spare when it's in the tub. I went with the OEM space saver tire and tools because I wanted to make sure it fit and the tools would work. I bought a vinyl tire cover off amazon ($20) to keep the spare in and will simply lay it down in the rear luggage area when on road trips. All told with shipping and handling it came to about $900. Higher than a generic whatever off of Ebay, but more confidence that it will fit and I'll have the tools to change out a flat if the situation arises. |
04-27-2021, 11:05 AM | #8 |
12
Rep 37
I know this has been asked before but has anyone discovered an easy compact spare kit option for Canadians? I have an x5 xdrive40i wit 20" wheels. I tried to get a compact spare kit when ordering my vehicle but the dealer just kept saying flat out that the OEM spare is not an option at all. I welcome any secret tips. I'll have my RFT all seasons until they die, then I'll replace with non-RFT and my winters will be non-RFT. It makes me nervous and extremely frustrated at BMW Canada for making this so difficult.
04-27-2021, 11:23 AM | #9 | |
Rep 266
2019 M5 Competition
2021 X6 xDrive40i M Sport 2018 Toyota RAV4 AWD |
04-27-2021, 12:14 PM | #10 |
Rep 8,739
04-27-2021, 02:42 PM | #11 | |
Rep 1,452
Go to the BMW parts counter or Genius with a VIN from a spare equipped car and ask them to get the parts number for the spare tire kit replacement - if something is defective, missing or damaged they have to be able to replace it and thus have the parts individually. Additionally, I would assume that the US spec parts numbers will work/match. Have you or anyone in Canada looked into ordering the US spec parts? Posted above that someone recently purchased through BMWPartsPro.com (AKA Steve Thomas BMW).
-Yoda |
04-27-2021, 04:43 PM | #12 | ||
Rep 2,610
04-27-2021, 05:07 PM | #13 | |
Rep 229
I also plant to switch out the runflats after they are done. Thats why i insisted on getting it. |
04-27-2021, 05:11 PM | #14 | ||
Rep 2,610
04-27-2021, 06:50 PM | #15 | |||
Rep 229
Although my dealer was asking me why you want that? He keeps telling me you get run flats either way. |
04-27-2021, 07:02 PM | #16 | ||||
Rep 2,610
And I don't have any viable theories why both BMW and many dealers sales have this ridiculous attitude towards the spare. Too low a profit margin is the only thing I can come up with, but that just seems petty.
04-27-2021, 07:05 PM | #17 | |||||
Rep 229
He also insists that its just extra weight. |
04-27-2021, 08:52 PM | #18 |
Rep 179
Drives: 2024 X5 40i
Agreed, it's a no brainer option if you're ordering or manage to find the rare vehicle on the lot that had it specified. If nothing else, spend the $150 on the option and then flip the tire/wheel and tools to another owner who's looking for an OEM solution. It would be easy enough to triple your return compared to what it cost to add the option.
04-27-2021, 08:57 PM | #19 | ||
X5 Enthusiast
462
Rep 762
Drives: 2021 X5
BMW Canada discourages the dealers to NOT sell it and there is financial ulterior motives involved (🤐 .. 🤫 .. sell more RFT with star ⭐️) The part # is in the system, but with an warning message, something like … for garage use only. 100% pure BMW Canada BS 🤥
2021 X5, Excellence, M Sport, DHP, DAP, RSE, MW, Merino.
04-27-2021, 08:57 PM | #20 |
821
Rep 1,790
If I end up trading my X5 I'll be removing the spare tire/wheel and all the tools. Sell it online.
COL(Ret), US Army Hagerstown MD 2019 X5 40i MSport Alpine White/Coffee (my 13th BMW) 2015 Mercedes SL400; 2009 Lexus RX350 |
gqgambler717.50 |
04-27-2021, 09:00 PM | #21 |
X5 Enthusiast
462
Rep 762
Drives: 2021 X5
Can I put deposit for the tools 😀? First come first serve right?
04-27-2021, 09:39 PM | #22 |
Rep 3
Am curious if anyone has 'created their own spare' by ordering a single tire and single wheel package from Tire Rack?
https://www.tirerack.com/content/tir.../packages.html Tire Rack's Tire & Wheel Package arrives mounted, balanced and ready for installation. (with or without TPMS) |
