M2 Technical Topics > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > Rear parking sensor on/off switch installed
      02-04-2017, 06:54 PM   #89
Enriquezar1
Drives: 2017 BMW M2 LBB
Originally Posted by MerlinPurple View Post
I tackled the removal of the drive mode switch today and took some pics to help others.
There's different ways to tackle it, here is what I did:
I removed the DCT cover using a card and non-scratch interior trim tools:
I mounted a card and trim tool in the location circled below:
like this...
The drive mode switch has an 'elbow' on either side. I used my trim tool to pry it upwards and unit popped out.
After this you'll need to unclip the connector on the drive switch panel - look for a tab on the connector, press it and pull the connector away from the panel.
Hope this helps
Any tips on replacing the sport comfort switch on the new switch which comes with the sport eco mode. Thanks !!!
      02-04-2017, 07:35 PM   #90
MerlinPurple
MerlinPurple's Avatar
Drives: M2 LBB
Sure, it's very much like the OP said, an easy swap.
  1. Remove the top cover off the unit.
  2. Hold down the "sport" side of the rocker button.
  3. Using your thumb, pull the "eco" side of the rocker button upwards - it will come off with a bit of persuasion.
  4. To install the old rocker button literally align the rocker button over to where it should be and push down, it'll snap right in.
Here's a quick pic so you can see how it's mounted:
The pivot/fixing point is in the middle.
Appreciate 3
      02-07-2017, 04:49 PM   #91
CantComplain
Drives: '17 6MT AW M2
Originally Posted by CommitConfirm View Post
Nope. The mod part has 2 or 3 extra pins.
Not from the research I did. I'm not saying I couldn't be wrong but I think I found images of the back of all of them and they were identical. Any chance you can confirm this?
      02-07-2017, 05:45 PM   #92
Prodigy.
Prodigy.'s Avatar
Australia
698
Drives: ///M2
Ordered one off ebay, should be here in a couple of weeks, local dealerships asking over $260 AUD for the part!!
      02-08-2017, 12:50 AM   #93
kiysersosae
kiysersosae's Avatar
United Kingdom
436
Drives: 1M, M2CS, M3CS
They have probably clocked on to what we are all doing and inflated the price
      02-08-2017, 01:22 AM   #94
Aust350z
Aust350z's Avatar
Australia
243
Drives: F87 M2
Got a link for RHD? I can just find used ones.
      02-08-2017, 01:44 AM   #95
Prodigy.
Prodigy.'s Avatar
Australia
698
Drives: ///M2
Sorry, the one i'm getting is also used, although apparently 'like new'.
I did however get a quote for a RHD new one from CotswoldBMWMini who is a member on here from the UK. He was very helpful and was able to provide one at a cheaper price than locally, i just couldn't justify spending $200+ on a new switch in the end. Send him a PM and see what he can do for you.
      02-08-2017, 07:17 PM   #96
Enriquezar1
Thanks again for the pointers. I finally installed the switch !
      02-10-2017, 12:49 PM   #97
AndrewC1989
AndrewC1989's Avatar
Drives: 2015 328d xDrive
Originally Posted by arquitecto View Post
Love the OEM look this solution has.
lol that's because it is OEM
Appreciate 3
      02-10-2017, 02:06 PM   #98
CommitConfirm
United Kingdom
475
Drives: The Bus
Does that £200 include shipping to AUS?
      02-11-2017, 10:50 AM   #99
CommitConfirm
United Kingdom
475
Drives: The Bus
The one on the left is the 'new' switch with the extra button. The one on the right is the 'old' original switch.
Appreciate 4
      02-12-2017, 05:04 AM   #100
MR.
MR.'s Avatar
4399
Drives: BMW M2 CSL Turbomeister
Guys, I got the part as order from BMW, but after installing it I noticed mine says ECO PRO instead of comfort.
I clearly forgot to replace the switch, so now I have to go back to my carand do that as well...
MR
      02-12-2017, 03:16 PM   #101
Kantalias
Drives: 2016 M2
Anyone want to sell their original module (the one without the parking sensor button)? I'm thinking of mounting a volume control for my radar detector where the parking sensor button goes. But I'd need to disassemble the module and I'd hate to screw that up with only one on hand...
      02-12-2017, 09:31 PM   #102
AndrewC1989
yeah, you can have mine for $40 shipped. Car has 600miles on it so it's in perfect condition. Just PM me.
      02-13-2017, 09:35 AM   #103
jimmy9980
BMW DRIVER ///M
jimmy9980's Avatar
106
Drives: BMW 2017 M2 07/16 Build
Best $40 bucks spent on the car so far lol!
Current
Waiting 2022 G80 M3 AWD Comp Brooklyn Grey
2004 E46 M3 White
END OF LIFE = 2017 M2 07/16 Build, 2014 M5 05/14 Build, 2008 M3 ESS Supercharged, BMW 2003 M3, BMW 2001 325ci
      02-13-2017, 01:46 PM   #104
AndrewC1989
damn near life changing. i ended up spending 80 though. 120 for a brand new one and sold the old one for 40.
      02-14-2017, 10:37 AM   #105
jimmy9980
BMW DRIVER ///M
jimmy9980's Avatar
106
I posted the link to eBay. $ 40 from Germany used but was in perfect condition.
Current
2004 E46 M3 White
      02-14-2017, 10:41 AM   #106
AndrewC1989
They are sold out so I wasn't able to buy there
      02-19-2017, 06:33 PM   #107
CantComplain
Thanks! I stand corrected.
      02-19-2017, 09:36 PM   #108
bmwdd
Drives: F30
For those who doesn't have backup camera option installed from factory, I believe you only to wire 1 additional cable from the console switch to the ICM module to make the P button work.
mjsaville101.00
      02-20-2017, 03:11 AM   #109
DivideBYZero
Never underestimate the Home-Bowl
DivideBYZero's Avatar
United Kingdom
484
Drives: F87 M2<E92 M3<E46 M3
Sounds simple when you say it quickly.
2017 F87 M2, MG, M-DCT
2002 E36/7 Z3 2.2 Sport 5MT
2016 F22 M235i Coupe, MW, ZF8
      02-20-2017, 03:39 AM   #110
bmwdd
Drives: F30
For those without backup camera from factory, unplug the console switch and check the wire plug if there is a cable for pin 1 *edited - as confirmed by post 135
If pin 1 is missing, then this is the missing wire. You need to make yourself a wire (something like 50-60cm), then route the cable from the console switch cable plug pin 1 to ICM (located under the iDrive controller area) cable plug pin 28
This is not something new and actually how F20 / F30 retrofit the Front PDC option (exchanging the console switch is part of the Front PDC retrofit) and it totally makes sense that F87 follows the same. You can find the official BMW retrofit guide here on page 10 which explains the steps with diagrams how retrofitting console switch is done (and forget the rest).
Now I speak it more slowly, hope it doesn't make it awfully complicated to prevent you from trying I don't own a M2 so I can't verify it unfortunately.
mjsaville101.00
m2
