05-05-2023, 12:56 PM | #45 |
Rep 6,862
On the i3, it was for a remainder of <70% that would trigger a warranty claim. I thought that was in the Federal regulation, so may not be listed in the warranty.
05-05-2023, 01:12 PM | #46 |
Generalissimo
654
Rep 1,408
Actually, I understand corrected. The car charges all battery cells to 100%. It's the discharge percentage that sets the usable battery capacity. So, the car let's all the battery cells discharge to a certain percentage above 0 and forces you to charge up again. So, on 50e in the US the discharge percentage is about 32% which means around 9.5 kWh unusable buffer during discharge (0.32*29.5 kWh gross capacity), i.e. 20 kWh usable capacity. Outside of the US, this discharge percentage is expected to be around 13% (0.13*29.5 kWh gross capacity) which means around 3.8 kWh unusable buffer during discharge, i.e. 25.7 kWh usable capacity.
05-05-2023, 01:16 PM | #47 |
Rep 6,862
To balance the cells, which improves the overall capacity as it will only discharge to the percentage of the lowest cell, you must fully charge the batteries or you're wasting a lot of capacity. You do want all of the cells to be as close to the same level of charge as possible.
nZtiZia4680.00 |
05-05-2023, 01:33 PM | #48 | |
Rep 3,692
2022 G05 B58/PHEV
+ a few very old BMWs |
05-05-2023, 03:07 PM | #49 | |
Rep 12
If BMW want the battery to last, they will set a 90%-10% SOC like Toyota RAV4 Prime, instead of 100%-30%. I assume BMW put much more emphasis on performance than longivity. The current BMS logic will make sure 83kW output available accross all allowed SOC range and thus produce a very consistent throttle feel, un like most BEV with worse acceleration at low charge level. It will be interesting to see wheather EU spec 45e can produce 83kW output power at low SOC (11%) All this will not be an issue on 50e with the introduction charge limit. For those 45e sold in CA with 10yr warranty, maybe one day someone can find them chep on used market and claim warranty and fit them with 50e or possibly future 60e's battery? For the rest of us, this issue will most likely disappear in 3-4 years with a shiny new toy. Last edited by aquanox; 05-05-2023 at 03:40 PM.. |
05-05-2023, 04:29 PM | #50 | |
Rep 3,692
2022 G05 B58/PHEV
05-05-2023, 05:48 PM | #51 |
Rep 6,862
Cells don't age exactly the same way. TO prevent damaging the pack, the logic looks at the lowest cell to keep from trying to draw it down to zero. To get them more even, you need to do cell balancing, which works best when charged to 100% first.
Cells wear more by full cycles. So what you might consider as one cycle is really closer to 70% of one. |
05-05-2023, 10:41 PM | #52 | |
Rep 12
Also for those who don't charge the car, 30% makes a lot of sense as you will not see any performance penalty and have on demand power. Higher SOC means better performance, if the car is designed for 1st owner, might as well get all performance you can and don't worry what will happen next. Say if they mess it up, they can always fix it with OTA. or better yet, push OTA to unlock more power after year 4 to boost resell value. |
05-06-2023, 03:15 AM | #53 | |
Rep 804
Is the electric range of your 45e also shorter now? If the battery degrades that fast, you will get one or two new batteries from BMW under warranty... |
05-06-2023, 10:34 AM | #54 | |
Rep 12
I do notice a bit reduced range, but there is too much variables, and thus inconclusive. Also, unlike single 18550 cell, ev pack has significant amount of capacity under 3.6v Can you help read the BMS info from EU models? |
07-01-2023, 11:54 AM | #55 | |
Rep 146
I bought the BMW Wall Charger L2 for the house. |
08-13-2023, 02:31 PM | #56 |
Rep 146
We have the X5 xDrive50e setup in the charging menue to come on at 12 a.m. and 8 a.m. with a departure of 9 a.m. Last night was the first time we did this and it work fine. The X5 is set to 32A and 80% battery charge.
We love the X5 and I tease my wife of trading in my Ford F150 hybrid for another X5. |
08-13-2023, 02:51 PM | #57 | |
Rep 8,739
Drives: eVeRyOnE mAD!
gsquare66.00 |
08-13-2023, 03:04 PM | #58 | |
Rep 146
Thank you for the info an my wife says she'll remove the 80%. What do you set it too? She just followed the BMW YouTube video of a BMW rep. |
nZtiZia4680.00 |
08-13-2023, 03:44 PM | #59 |
13452
Rep 20,015
Charge it to full all of the time.
08-13-2023, 04:01 PM | #60 |
Rep 181
If you've set the battery charge to a certain percentage on a trip once you've plugged in to charge does it go to 100% or to the charge level you set on the trip?
08-13-2023, 05:18 PM | #62 | ||
Rep 8,739
on the 45e, plugging in always fully recharges the usable capacity. on the 50e, the charge level is adjustable (though unnecessary IMHO). |
08-13-2023, 06:30 PM | #63 | |
Rep 146
Thank you, I have been learning a lot from everyone and TurtleBoy has also been a great help. From maintenance and warranty contracts to different packages. My wife's x5 xdrive50e is Black Sapphire Metallic Tartufo Ext Merino Leather M Sport Package M Sport Professional Package M Sport Package Pro Parking Assistance Package Premium Package Climate Comfort Package Multi-contour seats The dealership is in Maryland and as of Saturday they still had two open allocations for X5 xdrive50e. |
nZtiZia4680.00 |
08-19-2023, 06:56 PM | #65 |
Rep 6,862
With the active cooling and charging logic, IF you can do your normal driving and not run out of battery capacity, 80% might be fine, but personally, I'd just 'fill-er-up'.
Kairen00011.50 |
08-19-2023, 07:49 PM | #66 | |
Rep 12
Some days I drive 5 mi but other 70. So I've seen "---" couple times and also charged it 2 times a day when it was "---" |
