12-29-2023, 07:35 AM | #1 |
Rep 13
2019 X5 40i LITHIUM battery - REGISTRATION required?
I have a question about the 10 AHr LITHIUM battery under the hood (2019 X5 40i). I understand it is in PARALLEL with the AGM main battery in the trunk so I'm questioning the need for REGISTRATION and why charging profile would be altered since the charging process is probably focused on the MAIN battery. Dealer says it to needs to be replaced (and also said CODING required which I believe is inaccurate because I'd replace original with identical new one) and I'm looking for input as to whether a new genuine BMW LITHIUM replacement battery needs REGISTRATION. I cannot find a definitive answer on this and I appreciate any and all expert replies. I had a 2012 X5 and have done battery coding and registration on the E73 but I understand the G05 uses enet and not Dcan cable. DOES THE LITHIUM BATTERY NEED REGISTRATION? Thank you VERY MUCH!
12-29-2023, 08:18 AM | #2 |
13493
Rep 20,099
My understanding is that it does not but have never seen anything one way or the other on official docs.
12-29-2023, 03:36 PM | #3 |
Rep 108
If the lithium battery in the 2019 x5 is the same as the 48v lithium battery in the 2022 X5, then yes it does need to be registered, per BMW AIR documentation. If you like to have that kind of repair information for yourself, you can get it directly from BMW at https://bmwtechinfo.bmwgroup.com/#/login A 1-day subscription is $32. I would suggest registering when you have plenty of free time and then spend the day "printing" documentation to pdf files for future referral.
12-29-2023, 03:54 PM | #4 | |
13493
Rep 20,099
eluded3064.00 |
12-29-2023, 05:37 PM | #5 |
Rep 7,532
One thing to look for to see if a battery may need registration is…does it have an IBS (intelligent battery sensor).
The IBS is the reason the main battery requires registration. The IBS monitors multiple parameters that affect how the charging system communicates and charges the battery. In BMWs with multiple batteries…some of the aux batteries are monitored by a PCU (power control unit) or another module (whose name is escaping me as I type this reply). Again, look at the negative battery cable to see if there’s a small mechatronic module attached to the neg cable that mounts to the neg battery post. Also, if you have software or a tool that can register the battery, you can hook it up prior to buying the battery etc and see if there is a selection for registering it, too. An example is obvious if you have the Bimmerlink app…if you connect the app and go to the 12 volt battery screen, you can see a tab to register a new battery. If your aux battery required registration…if you pull it up, the selection would be there, too. But again, on many BMWs, the smaller aux battery doesn’t have an IBS…and the software/apps don’t show any way to register them. But if the aux battery does have an IBS….the software/app should pick this up as it scans your ECUs…and give you an option to register a new replacement. In the two topology charts below, the F15 chart uses the PCU to monitor the aux battery and there is no IBS on the aux battery. But the G11 chart below, the LITHIUM battery in the engine bay DOES have an IBS…so it should be registered.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 12-29-2023 at 05:46 PM.. |
12-31-2023, 03:42 PM | #6 |
Rep 13
Lithium battery pics
Thanks to all who have replied and especially QSilver7. YOU ROCK! I appreciate the time you took to supply all that helpful information. Below are 3 pics. First pic is a new 10Ahr lithium battery. The THREADED battery post is approximately .305" diameter. Note the "port" on the battery for a 3 pin connector.
2nd pic is the ground lead. It just a heavy short black wire (circled in green) that connects directly to the body. That lead wire does not appear to have IBS. 3rd pic shows the battery port connection (red circle). I suppose this facilitates the DME communication. 1. do you think this battery configuration suggests registration is needed? 2. is registration just to record the installation of the lithium battery or does it have additional charging profile and battery life implications? 3. lastly, if I install new battery, do you think I can drive to have it registered by a dealer or local indy shop up to an hour drive away without causing any system damage? I'm new to the Greenville SC area so I do not yet have any indy I know and trust who will not charge me $100+ for a 5 minute job nor do I know any local enthusiasts who have INPA+ that I can pay. I have coded and registered a battery in a E71 LCI long ago but that used K+Dcan and I understand the G05 uses ENET cable. THANK YOU and Happy New Year. |
12-31-2023, 06:59 PM | #7 |
13493
Rep 20,099
Turns out registration is required. I have attached a doc on the X7 mild hybrid but it should be the same. For the 12v battery, registration and the IBS is used for tracking the charged state and age of the battery. If you don't register it then it will likely reduce your battery life as it will not provide a full charge. I would imagine something similar happens with the LiOn under the hood.
Give your dealer a call and explain the situation to make sure they will register it for you. They may not if they didn't install the battery. Link for mobile app users -48V Electrical System BMW_48V vehicle electrical system.pdf
01-01-2024, 09:29 AM | #8 |
Rep 4,383
Yes, it's safe to drive to a service center with the newly installed unregistered battery. Just don't continue driving it and forget to have it registered or it "may" shorten its life and they, as you already know, are expensive. Not to mention the strange issues a low charge will cause
01-02-2024, 07:15 AM | #9 |
Rep 7,532
Ditto the comments above from Turtle & Marty. Perhaps consider purchasing a tool or app & cable or dongle that can register the batteries. Their cost may be less than (or approx the same) as paying labor for battery registration. The end result would be you now have a tool or app that can assist you with diagnostic info…where as paying someone else to register the batteries is a one and done deal that you’ll have to repeat again if you still own the vehicle when another battery is replaced.
A diagnostic tool like a Foxwell (forget the model number that can register a battery) or an app like Bimmerlink + cable or dongle will give you a tool for future diagnostics. In regard to which cable or dongle you need to communicate with an app like Bimmerlink/Bimmercode…they have all of the recommended adapters and cables listed on their site for which platform you use to download the app to… IOS/Android/Desktop…and which series they work with: https://bimmercode.app/adapters/
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 01-02-2024 at 01:09 PM.. |
Marty in NY2753.00 YuCrew1.50 |
01-02-2024, 09:27 AM | #10 | |
13493
Rep 20,099
01-02-2024, 10:37 AM | #11 |
Rep 4,383
01-02-2024, 10:45 AM | #12 |
13493
Rep 20,099
No they didn't so I took it as it won't be addressed. I guess it makes sense since the 48v battery should be a long lasting item and rarely need to be replaced from what I have seen.
01-02-2024, 03:34 PM | #13 |
Rep 13
QSilver7: I have not found a single app yet that will REGISTER the 12V Lithium Battery. I do want to "BUY" software and hardware as you've suggested but no success yet finding anything that will work other than ISTA+ and I need to get the new battery installed soon since I now have it, and then registered. They are WICKED expensive (almost $1000 MSRP for a 8+ lb battery ... nuts!) and I need to do it right! BimmerLink confirmed their app will not REGISTER the 12V aux lithium battery. Foxwell also confirmed they do not have a product that will do the job.
01-02-2024, 04:36 PM | #14 | |
Rep 4,383
01-02-2024, 05:14 PM | #15 |
Rep 13
Auxiliary battery fault
Dealer diagnosis: replace 12V, 10AHr lithium battery to eliminate malfunction warning.
Marty in NY2753.00 |
01-02-2024, 06:46 PM | #16 | |
Rep 7,532
01-03-2024, 08:35 AM | #17 | |
Rep 4,383
- Is your car still displaying that message on your display? - Do you know for sure your 12V battery is not causing it? - Have you reset iDrive? - have you driven the car long enough in the days prior to that message as opposed to having it sit in the garage for weeks? Perhaps since yours is a 2019, we'll be seeing more of this as other 2019's continue to age Well, let us know the final results once its been replaced and registered. |
01-03-2024, 08:41 AM | #18 |
13493
Rep 20,099
Hopefully not.
01-07-2024, 12:43 AM | #19 | |
Rep 734
