03-15-2023, 07:04 PM | #68 | |
Rep 6,846
In reality, a level 2, 16A unit would fit most people's situation...running overnight, for the average commute, you should always be able to leave home with enough to get back, and likely be full before the next weekend where you might want to use it all again. Now, the 50e can handle twice the power input so can get there faster IF you can feed it enough, but still the same thing...it would likely be full regardless even with the 16A unit in the morning. |
03-15-2023, 08:55 PM | #69 | |
Rep 179
I know some people who don’t want to install a new line, split a line from their dryer plug which is usually a Nema 14-30? You can get a ULC certified splitter for it. It’ll be capable of 24 amp charging MAX. |
03-16-2023, 11:52 AM | #70 |
Rep 6,846
We each have our own panels, but the line feeding them from the individual meters is what would have to be upgraded to upgrade the whole panel's capacity...as I said, in my case, that run would be about 120' through a bunch of other's basement ceilings and across numerous firewalls...not something that is practical.
My thoughts have always been to put in the largest EVSE, or at least power run, as your current panel can support...if that's only a 20A circuit...so be it. I was able to put in a 40A one primarily because the only high current load I have is the central air...stove, dryer, heat are gas...that does prevent me from considering an induction stove, but hey...I'll probably move or die before that becomes mandatory. |
05-03-2023, 04:58 AM | #71 |
Rep 2
Public Charging X5 45e
I wonder if someone can help. I just bought a 2023 BMW X5 45e, which (I believe) uses a J1772 cable. Except at Chargepoint, I haven't been able to charge it at most public charging stations (e.g., Electrify America). Is there an adapter that would enable charging the vehicle at a public station using (for example) CCS or CHAdeMO cables? Or is the car just not meant to be charged at public stations?
05-03-2023, 10:25 AM | #72 |
Rep 3,686
Car can be charge at any public L2 evse with J1772 or even Tesla destination evse if you have adapter. This car can NOT take DC charging, so no CSS, no ChadMo.
05-03-2023, 12:26 PM | #73 | |
Rep 8,736
Drives: eVeRyOnE mAD!
05-03-2023, 12:53 PM | #74 |
Rep 2
Thanks for the concise info, eelnoraa That helps narrow down the adapter I need to order and the stations I need to search for.
nZtiZia You can't imagine the look on my face the first time I drove up to Electrify America and pulled the CCS cable, then the CHAdeMO cable. Maybe it's a common sight, but I'm sure I was spectacle! |
05-03-2023, 02:04 PM | #75 |
Rep 6,846
FWIW, there are public level 2 EVSEs, and there are more of them than DC fast chargers of whatever type. Even Tesla has some level 2 devices, but with their plug on it...they call them destination chargers you might find at hotels, etc., With an adapter, if those are free, you can charge your X5. Tesla has a protocol that enables the vehicle to 'talk' to the charge point to verify identity and determine if the vehicle is authorized (for payment, if setup that way), so you need one that doesn't do that.
