      01-03-2024, 07:33 PM   #1
Buljiver
Buljiver's Avatar
Drives: BMW 2014 x1 sdrive xline
Passenger Window e84
2014 sdrive28i passenger window doesn’t respond at all. All other windows work appropriately. I do not see front passenger window listed on fuse diagram. Any help/suggestions greatly appreciated
      01-04-2024, 06:03 PM   #2
tturedraider
tturedraider's Avatar
Drives: 2018 340i M Sport
More than likely a failed regulator. Very common on older Bimmers. Seems a little less common with the F3x generation, but very common with the E46 & E9x (to include the E84).
https://youtu.be/-ay-8p2p29w
www.bmwcca.org
member #388003 - Use me as a referral
& you could win a one day ///M Driving School!!
___________________________________________
      01-04-2024, 07:01 PM   #3
tracer bullet
tracer bullet's Avatar
Drives: '11 135i , '15 X3 35i
Agreed, that's most likely it. Maybe take off the panel and check the motor and switch with a multimeter to see if you're getting voltage to the motor when you hit the switch. If you are, but it's not moving, it's bad for certain.
