01-07-2024, 08:55 PM | #1 |
Rep 29
Would 275/40/20 be ok?
The factory size is 275/45/20, would it be ok to get 20 inch rims
From tire rack and put on 275 40 20 winter tires on it for my second set? Thanks! |
01-08-2024, 01:44 PM | #3 | |
Rep 3,553
-less sidewall, so less protection against road hazard damage -your odometer will add on more mileage than you actually travel ( ~4%) (so you'll tack on an extra 4 miles that you didnt travel for every 100 miles) - your speedometer will read even higher than before over actual speed ( ~5-6mph faster than reality vs 3-4mph)
Present: 2023 G07 40i ZDH/ZDU/ZMP/ZMQ/2NH/ZPK/ZPP/ZRC/300/3AC
Past: 2013 335i 6MT ZMM/ZDH/ZTP/3AG/494/508 Past: 2016 F34 335i xDrive ZCW/ZDA/ZDH/ZTP/ZMP/2V5/5DL Past: 2019 G01 M40i ZDA/2VF/ZPP/ZPX/688/3AC |
01-08-2024, 04:41 PM | #4 | |
Rep 29
01-09-2024, 01:06 PM | #5 | |
Rep 3,553
40 aspect ratio tires have shorter sidewalls, which makes the diameter smaller roughly: 275 X 0.4 = 110mm 275 X 0.45 =123.75mm diameter of the full assembly = 2 x sidewall height + rim diameter rim is 508mm (20") 220 (sidewall height) + 508 = 728mm for 275/40/20 247.5 (sidewall height) + 508 = 755.5mm for 275/45/20 the smaller the diameter, the more revs per mile, so you will end up with a speedometer and odometer going farther and faster than you are really going.
01-09-2024, 02:49 PM | #6 |
Rep 1,082
One of my favorite sites for tire/size comparisons: https://tiresize.com/comparison/
2021 Jeep Grand Cherokee SRT Black 2006 Ford Mustang GT Convertible (car-show car) |
01-09-2024, 03:55 PM | #7 | |
Rep 29
Will the same issue happen if I go smaller size like the 19 inch oem size on rims or 18inch ? MINUS WHEEL DIAMETER: 18" Smaller Wheel Diameter Than Factory Size Learn More 18" Recommended 255/60-18 FACTORY SIZE WHEEL DIAMETER: 19" 19" Recommended 265/50-19 19" Alternate 255/55-19 |
01-10-2024, 06:54 AM | #8 |
Rep 3,553
those are all within 1% of the factory diameter:
Specification Sidewall Radius Diameter Circumference Revs/Mile Difference 275/45-20 4.9in 14.9in 29.7in 93.4in 678 0.0% 255/60-18 6.0in 15.0in 30.0in 94.4in 671 1.0% 265/50-19 5.2in 14.7in 29.4in 92.5in 685 -1.0% 255/55-19 5.5in 15.0in 30.0in 94.4in 671 1.0% 18" may not clear if you have MSport brakes, be sure to select that option for your car on the wheel finder on tire rack if you have msport.
