08-14-2023, 07:24 PM | #1 |
Rep 56
Infotainment screen on while charging
Hello everyone!
I recently picked up my first BMW and it's the 2024 50e. I noticed after I plug it in to charge, the vehicle locks, screens turn off and everything seems fine. If I head back out to the garage 20 minutes later, I see the infotainment screen is on and showing BMW. Has anyone else experienced this? Thanks! |
08-14-2023, 10:26 PM | #2 |
Rep 6,881
Note that if you have your key fob with you, depending on your iDrive settings, just getting near the vehicle may start to turn some things back on in anticipation of you getting in to start driving.
08-15-2023, 06:35 AM | #3 | |
Rep 56
In my photo, no key fob is present or near the vehicle. I will also mention that if I push the lock button on the key fob, it will cause the infotainment screen to turn off and BMW is no longer displayed. That lasts another approximately 20 minutes before it does this again. |
08-15-2023, 07:10 AM | #4 |
Rep 8,798
Drives: eVeRyOnE mAD!
before you open the door to exit the vehicle, are you pressing the engine Stop button or just placing the vehicle in Park then opening the door? if doing the latter, that keeps the vehicle idle. you want it to go into standby, so need to make it a habit to do the former.
many folks with PHEV forget to press the engine Stop button at the end of a trip if the ICE isn’t running because there’s no engine to turn off, but the vehicle electronics still need to be turned off |
08-15-2023, 07:59 AM | #5 | |
Rep 194
Drives: 2024 X5 50e
Former: 2020 Volvo XC60, 2018 Volvo XC90 T8, 2016 X5 40e, Lexus RX 450h, Acura MDX
First: 1963 Chevy Corvair (in 1984) |
nZtiZia4722.00 |
08-15-2023, 09:48 AM | #6 | |
Rep 56
This situation occurs after I walk away from the vehicle, it locks itself and then about 20 minutes later, this happens with the screen illuminated and saying BMW. |
08-15-2023, 09:50 AM | #7 | |
Rep 56
08-15-2023, 10:28 AM | #8 | |
Rep 8,798
I always put my vehicle in Park first, let go of the brake pedal since it’s no longer needed to hold the vehicle in place, then press the button. I’ll need to do some simulations your way to observe its behavior then report back. |
08-15-2023, 12:32 PM | #9 |
Rep 194
Drives: 2024 X5 50e
I schedule my daily charging to begin after midnight for the lowest rates, so I can't say what the screen looks like when charging ends. I haven't noticed anything different or unusual on the screen in the morning, but again that's typically several hours after the charging session has ended. If I do a mid-day charge, I'll try to monitor what if anything happens with my screen.
08-15-2023, 04:06 PM | #10 | |
Rep 56
08-15-2023, 04:07 PM | #11 | |
Rep 56
08-15-2023, 04:20 PM | #12 |
Rep 56
I emailed BMW Genius last week about this. Below is their response which I received a few hours ago. Unfortunately, I already had the "Turn off after opening door" enabled. The other workaround with the thumbwheel did turn it off briefly but again after 20 minutes, it was back on. Seems like another service visit might in my future soon.
When your BMW is in idle state, it is switched off, including the iDrive screen. The vehicle is in idle state prior to opening from the outside and after exiting and locking. For your BMW, the idle state is automatically established under the following conditions: After several minutes, if no operation takes place on the vehicle. If the charge state of the vehicle battery is low. Depending on the setting via iDrive, if one or both front doors is opened when exiting the vehicle. In some situations, the idle state is not set automatically, for instance during a phone call or when the low beams are switched on. After a trip, the sleep mode can be established by opening the front doors. For this purpose, all passengers must exit the vehicle. Please follow the below steps: Via iDrive: "MENU" "Vehicle apps" "Doors and windows" "Lock/unlock" "Turn off after opening door" In order to manually establish an idle state in the vehicle after the end of a trip, press and hold the thumbwheel in the center console until the OFF indicator in the instrument cluster goes out. If after attempting these steps you still have concerns, please contact your local BMW service center for further assistance. Should you need to access a list of our authorized BMW centers, please visit our website at: www.bmwusa.com, and select “Dealer Locator.” |
08-15-2023, 04:42 PM | #13 | ||
Rep 8,798
is it a setting? are you on iDrive 8 or 8.5? there’s been lots of bugs reported on 8.5 |
08-15-2023, 05:08 PM | #14 | |
Rep 56
One "trick" I noticed is if I use the remote to lock the car again (even though it's already locked), the infotainment screen goes off again for 15 to 20 minutes |
08-15-2023, 05:10 PM | #15 |
Rep 12
Mine does this as well! The key is far from the car, it’s locked and properly turned off and the BMW screen stays on all night! Only when the car is charging though.
08-15-2023, 05:16 PM | #16 | |
Rep 56
BMW is recommending taking it in for service. Any chance you brought it in for service already? |
08-16-2023, 01:26 AM | #17 |
Rep 12
I have not, I feel like it’s not an urgent issue but I will mention it at my first service. Maybe it will get fixed with ID 8.5
astute_alpaca12.00 |
08-16-2023, 04:40 PM | #18 | |
Rep 56
I did make an appointment for service tomorrow and I'll report back my findings. |
08-17-2023, 02:59 PM | #19 |
Rep 56
It turns out my vehicle was on ID 8 after all. The dealership upgraded it to 8.5 and claimed to have charged it for 20 minutes and the screen did not come on. Of course I took it home, plugged it in and the screen still turns on.
I guess I'll try making an appointment for a different dealership next week. |
08-17-2023, 03:24 PM | #20 | |
Rep 8,798
08-17-2023, 07:05 PM | #21 |
Rep 110
My fresh week 32 50e with ID 8.5 does this too - same thing with the BMW logo. I feel like it has to be intentional?
08-17-2023, 08:35 PM | #22 |
Rep 56
I strongly believe they never plugged it in. I looked at the myBMW app while at the dealership and mentioned to the service advisor that it didn't register a charge in the app. He said something to the effect of "huh, that's odd". Every charge I have done in the past that lasted more than a few seconds has registered as far as I could tell.
