06-21-2023, 10:19 PM | #1 |
Rep 1
2021 X5m comp muffler delete?
Hey, I just got a 2021 X5M COMP, i used to have a 2018 C63 and I cut the mufflers and it sounded amazing.
What are some options for making this beast sound deeper and louder? Muffler Cut? or full straight pipe? thank you guys |
06-21-2023, 10:45 PM | #2 |
Rep 434
Going to go out on a limb here and just say you are going to prob receive some hate for suggesting to cut the mufflers off a 100+K vehicle. Considering some on here have spent in access of 10K for an Akra system with mufflers, TITANIUM mufflers..lol. Anyway, consider these options instead.
Oh boy. 1. Tuning this thing is next to impossible without sending DME to femto oversees. There are other claims out there that state they can activate the crackles by turning it on in the software. This has proven to work for some but cause idrive malfunctions for most. 2. The stock exhaust on the X5M and X5MC is quiet....period. The cheapest and fastest way to wake it up is removing the secondary catalytic converters. This will cause zero CEL's and is relatively easy to do. The next step to make even louder is replacing the catback or chopping into the factory system and installing an axleback. Depends if you want to keep the factory resonators or not. Lastly, if you want the most sound out of your beast. Primary Catalytic converter removal. You will need a CAN-BUS delete to rid yourself of the CEL. LEIB Engineering or G-Power make this module that you wire in. I have this on mine and it has worked with no issues. No CEL. 3. FI Exhaust, Dinan, Eismann, g-power, etc all make great SS exhausts. However, if you have 10K to drop on an Akra, you do you. There are plenty on here that had the coin to have that piece of jewelry. But no, it is absolutely not required to make your X5M sound alive. A great resource is Ben from RGSport. He can help you further. |
06-21-2023, 10:46 PM | #3 |
Rep 434
The easy, non-invasive way to have more power is installing the RaceChip GTS Black. This will give you a significant bump in power. Nobody currently makes an intake that really sounds special. However, if you want more jewelry to go with the Akra exhaust, get the Dinan intake. Gorgeous carbon fiber design that sets your engine baby's appearance on fire. However, we are all waiting on the Eventuri intake. It is near production, starting sometime in July. Hope this helps ya.
r33_RGSport13053.00 |
07-26-2023, 09:17 AM | #4 | |
24
Rep 38
We should have a primary o2 and secondary o2... the primary would be on the down pipe, closet to the turbo...then the 2nd being at the CATS...so my assumption is the middle section would delete those causing the CEL Which one of these do you have? LEIB Engineering or G-Power make this module? |
GotBeemed415.50 |
07-26-2023, 08:09 PM | #5 |
Rep 434
if you get the axel back plus the high flow X pipe middle section, does throw a CEL? this goes up to the primary catalytic converters, correct?
NO. Getting any "cat-back exhaust" WILL NOT THROW ANY FORM OF CEL WHATSOEVER. YOU DO NOT ANY FORM OF CAN-BUS MODULE. SIMPLY REMOVE STOCK EXHAUST AND REPLACE. We should have a primary o2 and secondary o2... the primary would be on the down pipe, closet to the turbo...then the 2nd being at the CATS...so my assumption is the middle section would delete those causing the CEL THERE IS A 02 SENSOR BEFORE AND AFTER THE PRIMARY CATALYTIC CONVERTER, WHICH IS LOCATED ON THE FIRST PORTION OF THE DOWNPIPE. THERE IS NOTHING MONITORING THE EXHAUST GAS AFTER THE SECONDARY CATALYTIC CONVERTER WHICH IS THE SECOND PART OF THE DOWNPIPE. THAT IS WHY YOU CAN ALSO ELIMINATE THE SECONDARY CATALYTIC CONVERTER WITHOUT A CAN-BUS MODULE. Which one of these do you have? LEIB Engineering or G-Power make this module? OK NOW THAT YOU KNOW THAT. UNDERSTAND THAT AFTER INSTALLING YOUR NEW SHINY CAT-BACK EXHAUST AND ELIMINATING THE SECONDARY CATALYTIC CONVERTER, THERE IS STILL THE PRIMARY CATALYTIC CONVERTER DIRECTLY AFTER THE TURBO. IF YOU REMOVE THIS, THE CAR WILL DETECT THE VEHICLE'S CATALYTIC CONVERTER IS NOT OPERATING AS IT SHOULD AND WILL THROW A HARMLESS CEL TO LET YOU KNOW. THE WAY YOU TRULY ELIMINATE THIS CEL IS BY EITHER SENDING THE DME OVERSEAS TO BE CUSTOM TUNED OR A CAN BUS MODULE. USING ANYTHING ELSE IS A CRAP SHOOT. YOU CAN RUN EITHER THE LEIB OR THE GPOWER, BOTH WORK WITHOUT ISSUE. https://www.leib-engineering.de/leib...bmw-x5m-f95-de |
akoni21024.00 |
07-27-2023, 06:49 AM | #6 |
24
Rep 38
GotBeemed
Thank you for clarifying that. I believe I understand... if you were to replace the down pipes, then you would have your CEL. https://www.dinancars.com/products/e...arts/D660-0092 Guess what I am just trying to find out is, would this cause a CEL? |
GotBeemed415.50 |
07-27-2023, 10:48 AM | #7 | |
Rep 114
GotBeemed415.50 |
07-29-2023, 07:32 PM | #8 | |
Rep 434
THIS WILL NOT CREATE A CEL IF INSTALLED BY ITSELF OR WITH REMOVING THE SECONDARY CATALYTIC CONVERTERS AND REPLACING THAT PORTION OF THE DOWNPIPE WITH THIS ..... https://www.rgsportshop.com/index.ph...2032&limit=100 THIS IS WHAT YOU REPLACE WHEN YOU REMOVE THE PORTION OF THE DOWNPIPE THAT HOUSES THE SECONDARY CATALYTIC CONVERTERS. BELOW IS THE LINK TO THE OTHER PORTION/SECTION OF THE DOWNPIPE THAT REPLACES THE PRIMARY CATALYTIC CONVERTERS. NOTICE THE 02 BUNGS ON THE PIPE. ON THE STOCK PIPE THE CATALYTIC CONVERTER WOULD BE LOCATED IN BETWEEN THEM. HENCE THE COMPUTER TAKING A SAMPLE OF THE GAS BEFORE AND AFTER. SINCE THAT HAS BEEN REMOVED, THIS IS WHAT THROWS THE CEL. SO WITHOUT THE CAN BUS DELETE, THIS WILL THROWE THE CEL LIGHT. EVEN IF EVERYTHING ELSE IS LEFT IN PLACE EVEN. https://www.rgsportshop.com/index.ph...2031&limit=100 |
07-30-2023, 03:44 AM | #9 | |
Rep 99
07-30-2023, 12:39 PM | #10 | |
Rep 434
Personally, I would gladly install/remove an additional product that is physically tangible to the system by my own hand. Of course, I would like everything to be remotely tunable and customizable, but alas I do not have high hopes that Fempto is going to release the capability because want to control the market. |
08-18-2023, 03:30 PM | #11 | |
Rep 99
08-21-2023, 12:50 PM | #12 |
Rep 101
just do restart catless primary and secondary downpipes. i have it on mine and its a BEAST! lol
2022 BMW X5M Competition
Marina Bay Blue/Silverstone, Full Car PPF & Ceramic Coating, Exoshield WPF, Forged Vossen EVO 5 in Bronzino, Full RW Carbon Fiber Kit, Carbon Seat Backs, M Performance Carbon Tips, Redstar Primary & Secondary Catless Downpipes, Dinan Carbon Fiber Intake, Dinan Stage 1 Tune |
08-27-2023, 04:51 PM | #13 |
2754
Rep 1,682
Will the car still pass emissions after removing the second cat?
08-27-2023, 11:19 PM | #14 |
13053
Rep 18,757
That depending on your state emission requirement.
AFAIK, most states are fine with it.
