11-13-2022, 12:33 AM | #23 |
Rep 78
Side question: would be possible to run the BMW 45e without gas at all but with still same charge in the battery? Like for example when we run out of gas and would like to continue to run on battery until find a gas station
11-13-2022, 12:48 AM | #24 |
Rep 3,744
I don’t see why it is not possible but i haven’t tried. And I don’t intend to try. Running tank to empty is bad for fuel pump. How do you get to they situation? Like charge batter full, then drive in sport model only until tank empty?
2022 G05 B58/PHEV
+ a few very old BMWs Last edited by eelnoraa; 11-13-2022 at 02:36 AM.. |
11-13-2022, 12:54 AM | #25 |
Rep 6,942
First, you don't really want to actually run the tank down all that low as you can damage the fuel pump because it is in the tank and both cooled and lubricated by the fuel. But assuming you didn't damage that, you could keep going with the EV motor. You'd want to probably put it in EV mode versus hybrid so there's less chance it would want to start the motor if you pushed the accelerator too hard...it can still happen, but you have to mash it past the detent. In hybrid mode, it will try to start the motor much sooner and at a lower speed.
aMIC31.00 |
11-13-2022, 01:44 AM | #26 | |
Rep 78
Other PHEV may have a limping (?) mode for this situation : |
11-13-2022, 03:41 AM | #27 | |
Rep 3,744
In theory, yes, this is correct. But in reality, this is really not the issue. LPFP is driven by electric motor. When there is no liquid, the pump will free spin at a much higher rate, this is usually what cause the issue. However in reality, this isn't the issue either. When car is moving with low fuel, gasoline swash around in tank. LPFP will start sucking in air, but there are still enough gas in the fuel system, so no so called cooling/lubricant issue. The pump will spin fast when it encounter air pocket, then slow down there is gasoline. Engine will start "choking". From chocking to engine no long can run, probably take 2-3 minutes. And even when engine cannot run, there is still quite some gasoline in the fuel system, just enough air pockets inside. Overall, the stress to the fuel pump is not bad. Running out of fuel a few time definitely won't damage fuel pump. LPFP is very simple and robust device. Just don't make a habits out of it.
2022 G05 B58/PHEV
+ a few very old BMWs |
11-13-2022, 04:42 AM | #28 |
Rep 225
Once it happened to me that my usual gas station was closed and I decided to keep going with the tank almost empty. I should have made it to the next station just fine but there was a detour so I've burned (practically) all my fuel and came to the station with my remaining electric range equaling total remaining range. And here's the message that I've got. But otherwise the car was running on electricity with engine off and no error messages for the last few kilometers.
11-13-2022, 08:35 AM | #29 |
Rep 8,864
Drives: eVeRyOnE mAD!
You'll get a warning of limited drive power if you let the fuel tank run empty. the ICE is completely offline so you're only running on Electric power. depending on your traffic situation, this can be very dangerous.
I let it run completely empty during my commute to work when I first got it to see what happens. my advice is don't let fuel run empty. |
11-13-2022, 09:02 AM | #30 |
166
Rep 335
Why would anyone even think of driving a PHEV with an empty gas tank. I guess there are those who will buy an $80,000 BMW and allow the 25 or 30 mile range on battery to limit their freedom. This makes no sense at all as in why not just buy a fully electrified ride that doesn't drag an engine along with all the other hardware around.
11-13-2022, 10:22 AM | #31 | |
Rep 8,864
volodp199.50 |
11-13-2022, 10:34 AM | #32 | |
166
Rep 335
11-13-2022, 11:12 AM | #33 | |
Rep 8,864
11-13-2022, 01:08 PM | #34 |
166
Rep 335
11-13-2022, 02:29 PM | #35 |
Rep 225
I certainly wasn't doing this intentionally or for testing purposes. Just ran out of fuel while getting to the next gas station and while still having some battery charge left. So I thought I'd share what happens in that scenario. Nothing more, nothing less.
11-13-2022, 02:50 PM | #36 |
Rep 3,744
Thank you for sharing. It is always good to know what to expect in certain special scenarios. While not intended, but in a pinch, we need to go for the extra miles to get to the next station, it is good to know we can do it.
2022 G05 B58/PHEV
volodp199.50 |
11-13-2022, 02:51 PM | #37 | |
Rep 3,744
2022 G05 B58/PHEV
nZtiZia4752.50 |
11-13-2022, 06:24 PM | #38 |
Rep 6,942
If you happen to be going up an incline...what fuel you may have may not be able to get to the pump, and then, it's spinning with no cooling or lubrication...not good for anything. There's a reason why the low fuel indication comes on...abide by it and seek fuel soon. It also puts a lot of stress on the engine if it's misfiring from lack of fuel.
volodp199.50 |
11-13-2022, 06:31 PM | #39 |
128
Rep 305
I have been driving my 45e without gas for a few months this summer with no issue at all.
Pros - car feels a bit lighter and a bit quicker than when your gas tank is full. |
11-14-2022, 08:10 AM | #40 | |
Rep 549
This is not something you want to have to learn on the fly in a remote area. Things worked out okay in this case but I won't cut it that close again. |
volodp199.50 |
11-14-2022, 08:41 AM | #41 | |
166
Rep 335
Experimentation is fine if that is what you are interested in doing but understand that driving around with no gas in the tank is a bad idea. |
aMIC31.00 |
11-14-2022, 05:32 PM | #42 |
Rep 6,942
You can select range to empty that is either ICE only, or ICE plus EV, and view the EV range alone, at least in the app, and I think on the display in the vehicle. But, keep in mind, all of those estimates are based on you driving exactly as you had been for the past about 18-miles, or 30Km. Change your driving style, the value will slowly change, but if there's not much left, it can change fairly rapidly.
