03-02-2021, 11:01 AM | #90 |
Rep 8,694
Drives: eVeRyOnE mAD!
mine is also 11/2020 but still switches from EI to hybrid albeit rarely
03-02-2021, 12:40 PM | #91 |
Rep 480
03-02-2021, 12:50 PM | #92 |
Rep 8,694
11/2020.38. it came from the factory like this in December so unsure (unlikely) the BDC module was replaced before I took delivery.
03-02-2021, 03:44 PM | #93 | ||
Rep 166
Some of the larger electrical consumers run on the high voltage battery. Heating & ventilation is one of them. So imagine you are on full electric with Max AC set, or with the heating blasting away on a freezing day. If you then push the accelerator, either the electric motor will not provide the acceleration you expect, or worse, you might get a dip in electrical power to the rest of the car, which the voltage regulator cannot iron out. Forcing you back to hybrid would then be a solution. Hit the accelerator, and the ICE will kick in, requiring less electrical drain to the electric motor, and not impacting the heating/ventilation I hardly ever start in electric, so this is all guess work. But I did have once or twice that while driving the car refuses to switch to full eletric when I push the button. So there must be a safeguard somewhere that prevents full electric in certain circumstances... Just an addition: the manual states that electric driving is only possible if the battery temperature is adequate... which I guess is not the case if you start full electric on a very hot or very cold day...could that be the reason ? |
03-02-2021, 04:13 PM | #94 |
Rep 8,694
wish we knew the reasons it does it, but none of the characteristics u just mentioned apply to my situation, which is that it switched from EI to hybrid upon starting the car in the morning when:
1) car has been parked in a sealed garage. (not driving) 2) high voltage battery is fully charged. 3) preconditioning isn't active. in addition, mine is set to start in EI and has started/driven off in that mode when it's 20-30ºF outside. i have not experienced the car randomly switching from EI to hybrid while driving. Last edited by nZtiZia; 03-02-2021 at 04:23 PM.. |
X5 45e1090.50 |
03-02-2021, 11:40 PM | #95 | |
Rep 2,420
It seems to be random and not related to all the propositions you made. The manual says that below certain temperatures electric drive isn't available but that is for really low temperatures. Below - 20 Celsius. Some Scandinavian owners have experienced this. |
03-03-2021, 02:32 AM | #96 | |
Rep 480
1) Default startup is EI, but sometimes it starts up with Hybrid instead of EI. HV Battery is full, temperature is normal (15 degrees Celcius). My profile is selected (can be derived from the custom avatar). 2) Sometimes the car switches from EI to Hybrid while driving. I don't accelerate, HV battery is full, not going uphill or towing anything. It just somehow thinks it needs to switch. So maybe the software update will fix it, but than it has to be fixed between version 11/2020.38 (last reported bad) and 11/2020.64 (min since yesterday). In a couple of days/weeks we will know. If the issue is solved in my car, we still don't know if it's the software update or the BDC replacement. So when it is solved for me now, we need to have someone else let his/her car update to at least 11/2020.64 and test. If it's not fixed, the BDC module has to be replaced as well. The dealer said that there were a couple of revisions already on the BDC module since my car was delivered at 02/2020. |
03-03-2021, 03:33 AM | #97 |
44
Rep 42
The single update to 11/2020.64 did not help for me. The car was updated at 22 februari.
At the second start up it was already switched from electric individual to hybrid. I barely drive the car due to covid so i did not check the car after 22 februari.
BMW X5 45e X-line
ikheetleon218.50 |
03-03-2021, 06:20 AM | #98 |
Rep 2,420
Mine started up in hybride when I left the dealer with the updated software.
03-03-2021, 07:10 AM | #99 |
Rep 8,694
what is the BDC module?
03-05-2021, 11:55 AM | #100 |
Rep 480
No dice unfortunatelly... today the car started up in hybrid again. Reported it to the dealer. They will update the case at BMW and hopefully they will start looking into the software. Somehow the software decides to switch over. They need to find out why and fix it. According to the dealer, the computer does not record any error/warning when it happens.
03-07-2021, 03:23 PM | #101 |
Rep 166
Question for those who have this problem: is it the setting in the drive modes that changes back to hybrid as standard, or only the drive mode itself when you are starting ? And are you using a "personal profile" linked to your key ?
03-08-2021, 12:39 PM | #102 |
Rep 480
In my case it's just the drive mode switching to hybrid. Profile settings are still correct. Drive mode is indeed linked to profile. But when it happens, my profile is selected (personal avatar is visible).
03-08-2021, 02:28 PM | #103 |
Rep 8,694
Electric Individual drive mode in my driver profile. hybrid drive mode in my wife's driver profile.
when my car randomly starts in hybrid, my driver profile avatar shows, not hers. are they linking somehow? Who really knows? |
03-08-2021, 03:54 PM | #104 |
Rep 480
I have just 1 profile and have the same issue. I don't think it's a profile mixup issue. It might be an issue that the profile doesn't fully load? So the drive mode stays in default.
03-08-2021, 04:28 PM | #105 |
Rep 166
Reason I was asking is that I have had a few cases already where the personal profile acts weird: the steering wheel not moving to the right postion, or the seat not moving completely to the right postion. The problem is inconsistent, no idea why it happens. So hence the idea that the profile settings might be the cause...just a tought...
03-09-2021, 12:19 AM | #106 | |
Rep 480
03-09-2021, 01:44 AM | #107 | ||
Rep 2,420
With my 40e I had an issue where the steering wheel wouldn't extend at all. Not with the memory button and not with the sw button. This was another issue and it the sw columns had to be replaced. |
ikheetleon218.50 |
03-09-2021, 04:14 AM | #108 |
Rep 480
Wow.. so it seems these issue's are probably related of multiple users have the same two issues. Some sort of signal to set the drive mode or set the steering wheel is not being send by the computer. And because the computer does not write an error/issue in the log, this must be some sort of software related issue. All related hardware has been replaced already in my case.
Indeed, with the previous model (F15), the steering wheel not extending was a hardware issue. |
03-09-2021, 04:39 AM | #109 | |
Rep 2,420
At the end both issues don't bother me enough to do any hardware modifications without garante the issue is solved. I will use it as an excuse everything time I feel I need a software update. I don't think I will be going for 03/2021. I still have to go back for the charger flap replacement. |
03-09-2021, 05:00 AM | #110 | |
Rep 480
