03-09-2021, 10:52 AM | #111 | ||
Rep 2,420
03-10-2021, 04:45 AM | #112 | |||
Rep 480
04-19-2021, 10:41 AM | #113 |
Rep 480
I've escalated the issues to the central BMW organization in my country. I've been dealing with it for a year now, and with swapping hardware and updating software hoping for a miracle, we'll be in the exact same spot next year. My dealer has been very helpful and willing so far, but from day one I've said this is a software issue. If nobody is looking in that area after a year I think I've showed enough patience to step up to the next level. Expecting to hear more about it this week.
Main issues are the switch to hybrid and steering wheel that does not extend. Both random issue's. |
05-14-2021, 01:26 PM | #114 |
Rep 480
A steeringwheel module has been replaced. Also the car has been updated to 03/2021.46. Don't expect this to be "the" fix, but when it's not I can step up the pressure at BMW NL. Will update the thread when I have news on this issue.
X5 45e1090.50 |
05-14-2021, 02:39 PM | #115 |
Rep 60
Looking forward to hearing how this turns out. I've been having the same problem, but I've been waiting to see what the actual fix is before heading to the dealer. Thanks for doing all of the leg work on this.
ikheetleon218.50 |
05-14-2021, 10:22 PM | #116 |
Rep 8,694
Drives: eVeRyOnE mAD!
i haven't had an incident in a few months, but today I noticed something very odd and was pretty lucky to catch it. i have Electric Individual mode enabled by default at startup with the suspension set to Sport level. after I parked my car, I pressed the Stop engine button and observed the mode switch to Hybrid and the suspension moved up to Normal level (which is default for Hybrid). WTH?!
why does it do this?! EDIT: it did start up in EI immediately after, though. |
05-15-2021, 02:50 AM | #117 | |
Rep 2,420
It did start up in my default electric individual however. Haven't found a pattern. |
05-19-2021, 10:37 PM | #119 |
Rep 8,694
mine started in Hybrid again this evening. the only possible factor is that my wife has been driving it the past week because of the gasoline shortage. her driver profile originally started the car in Hybrid mode, but I changed that to EI as soon as the shortage hit, so that shouldn't be the cause.
07-05-2021, 11:53 AM | #120 |
Rep 480
My car is at the dealer now and they attached a datalogger (via OBD) to it. They will try to reproduce the issue and send the debug logs to BMW Germany. I got a loaner (MY 2021 X5 45e) and it already started up in hybrid once (default setting is on Electric Individual). If the steering wheel issue also occurs on this car, I will suggest the dealer to do the debugging on the loaner so I can get my car back. They estimated they need 1 to 2 weeks to catch both issue's.
I have the feeling the MY2021 is a bit faster on full electric mode compared to my own car (MY 2020). Anyone else had these models to compare? Also when switching to petrol, at first, the revs are limited. I don't think that my own car does that, or I didn't notice before. |
07-05-2021, 12:36 PM | #121 | |
Rep 2,420
I have seen the rev limiter on mine when driving with ICE. You now probably also have a low temperature signal in the dash? Maybe if that disappears the revs can go up? |
07-05-2021, 12:40 PM | #122 | ||
Rep 480
Once this software issue is fixed and you all get the solution by OTA, I'll drop my Bitcoin wallet address here. ;-) |
07-05-2021, 01:18 PM | #123 | |||
Rep 2,420
ikheetleon218.50 |
07-06-2021, 06:07 AM | #124 | |
Rep 480
07-06-2021, 06:45 AM | #125 | ||
Rep 2,420
07-25-2021, 08:48 AM | #126 |
Rep 480
My car has been at the dealer for 3 weeks to install the data logger. The device is tapped into the canbus and will log anything that passes. When I got my car back, comfort access (open/close car via door handle) is no longer working (disabled by dealer?). Since I got it back, I haven't had the issue of the steering wheel or incorrect hybrid startup. Now I'm wondering if these are related. In the past I used a mix of keyfob and keyless entry (not the automatic one when you approach/walk away). I never payed attention if it is related to using the keyfob vs doorhandle/keyless entry. For the people that have this issue, can you check if the issues (steering wheel not extending to memory preset and/or the car starting op in hybrid instead of electric individual) occur when you only use the keyfob (for unlocking) and not the keyless system?
X5 45e1090.50 |
07-25-2021, 11:08 AM | #127 | |
Rep 2,420
I don't have the steering wheel probleem. Switching to hybrid is very often the last week. I have the impression it occurs more when I drive electric only a long time. |
ikheetleon218.50 |
07-25-2021, 11:10 AM | #128 | ||
Rep 480
07-25-2021, 11:54 AM | #129 | |||
Rep 2,420
ikheetleon218.50 |
07-25-2021, 01:53 PM | #130 |
Rep 1,340
I find this thread very informative, I have a MY2022 45e on the way and will share my experience. Car should be here in August, not sure exactly when though.
ikheetleon218.50 X5 45e1090.50 |
07-25-2021, 04:21 PM | #131 |
Rep 59
I have the same issue, no discernible pattern. In the menu, Electric Individual indeed is still checked as the default mode. So far, I can rule out the following culprits: outside temperature too low (summer time in Europe), low charge (car is mostly fully charged in the morning, no lower than 50% otherwise), manual selection of different drive mode during previous drive (I barely ever switch away from EI in the city),software (happened before / after latest OTA update a month ago. Build date is 01/21.
07-25-2021, 09:59 PM | #132 | |
Rep 2,420
I still think it might be the car wanting to switch on the ICE now and then. |
Tommy1122042.00 |
