      02-18-2022, 06:04 PM   #23
larrylam646
larrylam646's Avatar
371
Drives: 2020 M340i xDrive
Originally Posted by lknbimmers View Post
Thank you Larry
This worked for me as well!
I do have an additional question
With the amber lights now off, is it still possible to enable the fog lights with the parking lights?
My M340iX is not equipped with front fog lights so I cannot answer your question but if the ECE G05 can be equipped with front fog lights from the factory, then I do not believe VO Coding your FLMs to ECE would disable your front fogs.
Can you still turn your front fogs on/off? If you can, then I do not believe you will be prevented from coding the operation of the fogs.
Sorry, I could not be more helpful.
2020 Black Sapphire M340iX
2014 Estoril Blue 435iX - sold
      02-19-2022, 12:30 AM   #24
lknbimmers
lknbimmers's Avatar
79
Drives: E90/G05
Got this working. There are no issues having the fog lights on with the disabled parking lights.
Same goes for fog lights on with the high beams.
      10-07-2022, 07:17 PM   #25
shatty
Drives: 2024 M2 6MT Alpine White
Can this be done using protools on android? I know its more detailed than BC
      02-19-2024, 11:09 AM   #26
eldyf93
Extraordinaire
20
Drives: F93
Originally Posted by hkleyman View Post
The lights can be coded to the European spec to disable the side marker light. You'll need a desktop grade coding app, you can't do it from BimmerCode as far as I know.
There's five values to edit on two ECUs instead of changing the VO/FA to euro spec headlights. It's more prudent to change the LM03 voltage values to 0x00 (zero) on each front light module rather than to hamfistedly tell the car it has Euro lights installed when it does not.
      02-20-2024, 12:34 AM   #27
atervardanyan
Drives: 2022 BMW X5 XDrive 40i
Could you please clarify which 5 values specifically?
      02-20-2024, 05:52 PM   #28
eldyf93
Extraordinaire
20
Drives: F93
Code both front light modules FLM
LM03_DUTY_CYCLE_BINNING_CLASS0 ---> Wert_01 [00]
LM03_DUTY_CYCLE_BINNING_CLASS1 ---> Wert_01 [00]
LM03_DUTY_CYCLE_BINNING_CLASS2 ---> Wert_01 [00]
LM03_DUTY_CYCLE_BINNING_CLASS3 ---> Wert_01 [00]
LM03_DUTY_CYCLE_BINNING_CLASS4 ---> Wert_01 [00]
You could technically find out which BINNING_CLASS the LED "LM03" is set to on your car and set just that value to Wert_01. Which is hex value 0x00. But just set all of the five possibilities to zero and that side marker light will turn off.
      02-21-2024, 01:30 AM   #29
atervardanyan
Thanks, will give it a try
      02-21-2024, 02:07 AM   #30
samsamdar
samsamdar's Avatar
585
Drives: OG M2
2018 BMW M2  [6.67]
This worked perfectly to turn off the sidemarkers on my pre-LCI G05 X5 with lasers - thanks!
OG M2 with the OEM M mirror retrofit
      02-21-2024, 04:29 AM   #31
eldyf93
Extraordinaire
20
Drives: F93
glad you like it!
samsamdar584.50
      02-25-2024, 11:26 PM   #32
atervardanyan
Changing just
Worked for my US Laster lights on g05
