      01-25-2024, 09:42 AM   #1
up2up
up2up's Avatar
Drives: X5M 2019
Post Coding our SOS/Emergency Call Malfunction (Solved)
Hi everyone,
since most of us are suffering from this error due to battery drain or actual malfunction. it is better to code it and remove the error.
Disable Backup Battery
ATM 1F61
3001 ON_Board /BUB_FITTED (to nicht_aktiv)
Sometimes, it is enough to code the first one only.
Disable emergency call
KOMBI
3004 st_ecal_alive to (nicht_aktiv)
3004 st_ecal_timeout to (nicht_aktiv)
Hope this helps.
Abdol (X5m, 2019)
      01-29-2024, 02:43 PM   #2
gx5_027
Driver
gx5_027's Avatar
200
Drives: BMW
Originally Posted by up2up View Post
Hi everyone,
ATM 1F61
KOMBI
Hope this helps.
up2up This is awesome. I have Bimmerlink - can you recommend a tutorial for me to use Bimmerlink to do this coding? OR, do I need a different program?
      01-31-2024, 01:56 PM   #3
up2up
up2up's Avatar
Drives: X5M 2019
I believe biimerlink is a diagnostic tool. You need esys or biimer utility which is a great and easy tool. It has both PC and mobile version.
Abdol (X5m, 2019)
      03-06-2024, 03:39 PM   #4
ZCPM3
ZCPM3's Avatar
12
Drives: 2013 E92 M3
2007 BMW E83 X3  [0.00]
2019 BMW G05 X5  [0.00]
2013 BMW E92 M3  [0.00]
I was able to code out the emergency SOS malfunction error for my 2019 X5 with Bimmercode just now.
  • Load up Bimmercode app with your OBD2 adapter
  • Select the "Instrument Cluster" from the menu
  • Select "Expert mode" and acknowledge you are aware of the risk
  • Scroll to the top and search for "Meldung_0299" in the search box and enter
  • Select "nicht_activ", back out and then hit "Code"
Just decided I'd pass this along to anyone else that may looking for a temporary fix and disabling the SOS error message that keeps popping up when you open the door. Good luck
Diirek91.00
bloom15.00
