03-13-2020, 07:06 PM | #1 |
14
Rep 48
How Not To Have To See This Default Screen Before Profile Page
Has anyone figured if it's possible not to have to see the screen that initially comes up when you first open the door to the car before the "Welcome" page wiht your name. It stays there for about 15 seconds or so unless you click the mouse to say OK to it's warning which makes it go away.
"Warning! Use this system only when traffic conditions permit. Safe vehicle operation is the driver's responsibility." I've looked through all the settings and can't find anywhere to tell it not to show up again. |
03-13-2020, 08:02 PM | #2 |
Rep 7,361
Are any of the threads about using BimmerCode to change some of your default features or personalize familiar to you or rings a bell?
I opened my BimmerCode app to see if the G05 was supported and it was listed...so I checked some of the things that could be coded. I scrolled down to WARNINGS and this is what it reveals. Hopefully some g05 owners that has used this app to code their X will chime in for verification:
03-13-2020, 08:03 PM | #3 | |
Rep 250
I know Bimmercode just updated in the last 48 hours and I have not checked it yet but prior to the update the ability to code this off was not available on 03.2020.xx. It was available on 07.2019.xx and earlier versions. I am not sure re 11.2019.xx as I never had it. |
03-13-2020, 08:07 PM | #4 |
Rep 210
I do not have to acknowledge the warning, or say "OK". it goes away by itself as soon as I put the car in Drive or Reverse. I've only had the car about 3 weeks and only 1 day did i have to hit the button. I did not code anything out.
03-13-2020, 10:12 PM | #5 | |
14
Rep 48
I went into Bimmercode and it let me make the change. I then disconnected BC from the car, locked the car and left it for 30 minutes, then came out and unlocked it and that "warning" page is gone. It goes right to the Welcome 'My Name' page. Thanks very much. I appreciate it. |
03-14-2020, 05:30 AM | #6 |
Rep 11
Drives: 2020 X5 M50i CB/Coffee Ext Mer
I'm picking up my M50i in a few days (it's on the truck from Spartanburg now) and once again find myself intrigued by all of the possibilities Bimmercode can offer. But I'm also a bit nervous about making these changes to a brand new car... especially one that's heavily software dependent. I'm fairly competent with technology, but...
I'd love to hear peoples thoughts, experiences, and tips in this regard. The good, the bad, and the ugly! Has anyone ever "blown up" an ECU? Can it go wrong or is there a failsafe? Has anyone accidentally broken their car? Dealer issues as a result of coding new, under warranty vehicles? Must have mods?? I live in Connecticut and while there is no official quarantine in place, many school districts are closed for two weeks, some businesses are closing, and I think I'm going to have a lot of time on my hands! Thanks all - I just found this forum recently and appreciate all of your contributions. I look forward to adding mine soon!
2020 X5 M50i 1989 911 Cabrio 2015 Ram 1500 |
03-14-2020, 07:01 AM | #7 | |
Rep 4,259
Its just a database table within your cars many computes that you are changing, you are just swapping the OEM value as it left the factory for a different value that is already in your cars computers. |
03-14-2020, 07:25 AM | #8 | |
Rep 810
The coding in these cars isn't strictly "coding" in the sense of the word as associated with software engineering or development. You are merely changing the configuration and settings of features in the car; that cannot be configured directly through the iDrive system, to better suit your personal needs. Essentially its "personalisaton", and in some instances you can actually expose features hidden by BMW because they were not ready for release with the earlier software versions. I've exposed some great features, like: => Assisted Driver View (ADV) => Sports Plus (Sports+) driving mode for my Diesel/30d - since it doesn't come from the factory with that mode. => Alpina Instrument layout (damn awesome!) => Default driving mode to "Adaptive" (default at startup), instead of Comfort. => Enabled 5-flash indicator option I've also been able to disable some annoying features - like that ridiculous warning message you get on the Control screen when you first get into the car, and Auto Stop/Start (ASS). My only advice is stick to the mainstream config features supported in Bimmercode, and only use "Expert mode" very sparingly - as that is where could get yourself into trouble. Last edited by James_G0540i; 03-14-2020 at 07:31 AM.. |
03-14-2020, 10:18 AM | #10 | |
14
Rep 48
I also disabled the Auto Start/Stop function to where it defaults to the last setting, and I also enabled the '5 flash" instead of '3 flash' function for the turn signal using Bimmercode. |
03-14-2020, 08:15 PM | #11 |
Rep 7,361
Great news...glad you were able to code it off.
