06-28-2022, 11:00 AM | #1 |
Rep 2,432
Drives: 2021 M2C
Tesla Plaid YouTuber Boils Brakes and Crashes at 170 MPH
What an absolute maroon. |
06-28-2022, 11:05 AM | #2 |
Rep 651
I still can't make the connection between being elated with a fast electric motor. It's just what they do. I can't explain it. I can't dig up a good analogy. I just don't get excited over EV's and any demonstration of "power." Slapping a horsepower rating on an EV doesn't seem apt, either.
20
XMetal1131.00 Germanauto9701.00 Humdizzle6054.00 MmmmmM22588.50 ..Rush..973.50 jesm207.50 Donatello.1080.00 Cos270608.50 2022M550i3034.00 DrFerry6728.50 StradaRedlands4933.00 Biginboca3763.50 CT_M31478.00 swanson733.00 WordOnRoad313.00 nicholasn261.00 Capt Canuck704.00 P111569.00 swagon13518.00 M5Rick60013.50 |
06-28-2022, 12:05 PM | #3 |
Rep 910
Such a moron. This will go down in history with Rob Dahm's, Mazzai's, and others experience of how NOT to drive track. I made a "racecar" so I am a racecar driver man...OFFS. People, wear a helmet and change your fluid - basics. Cletus shirt was a clue.
9
DrFerry6728.50 MmmmmM22588.50 chris7197334.00 IllSic_Design2124.00 Lady Jane70768.00 WordOnRoad313.00 nicholasn261.00 P111569.00 M3 boi3211.00 |
06-28-2022, 12:55 PM | #5 |
Rep 2,432
Drives: 2021 M2C
The many levels of stupid in this video is really astounding!
06-28-2022, 01:47 PM | #6 | |
Rep 2,349
SCOTT26 "So as an admirer of the M5 and a potential customer of an M5 Touring. I would run naked around the streets of Garching if they were to offer one."
nerdogray1298.50 Cos270608.50 Donatello.1080.00 StradaRedlands4933.00 AIRHEIR443.50 nicholasn261.00 P111569.00 swagon13518.00 |
06-28-2022, 01:57 PM | #7 |
Rep 234
What does he mean when he keeps referring to the "regen"?
-2022 G82 M4 Comp Xdrive: Portimao Blue, Fjord Int., P.A.P, Exec.Pkg, Laser lts., Carbon Fiber Ext., M Performance Rear Spoiler
-2018 F80 M3 Fully Loaded -2011 F10 550i M-Sport -2006 Saleen S281 Supercharged |
06-28-2022, 03:40 PM | #9 |
123
Rep 376
Drives: '23 AMG GLE53, '10 X6M
so what went wrong.......... did he change the brakes to ceramic?
'10 X6M
'08 Cooper S |
06-28-2022, 04:02 PM | #10 |
167
Rep 304
The fact that he talks about new brakes/bleeding and then proceeds to go straight to 170mph on the track is nuts. Should have had those brakes smoking hot before hand doing some hard stops.
06-28-2022, 04:12 PM | #11 |
Rep 3,032
I know less about the mechanicals of a car than I do about women, and even i know not to hit the track HARD after having brakes bled. Stark, raving, mad.....no matter the car.
G35POPPEDMYCHERRY4996.50 Capt Canuck704.00 |
06-28-2022, 05:37 PM | #13 |
Rep 5,506
What an idiot... a 1000hp 5000lb car in the hands of someone with zero track experience is a deadly weapon.
He stripped his car of all the stock safety equipment, then replaced the brakes without flushing with high temp brake fluid, then decide to test said new brakes on a 160mph+ entry into a corner... that's Darwin at work.
Auto Detailing Enthusiast!
06-28-2022, 06:18 PM | #15 |
Rep 3,004
"Uncle Chet" clearly in the finals for....https://darwinawards.com/darwin/darwin2022.html
Racerbruce
06-28-2022, 06:54 PM | #16 |
Rep 3,468
Most cars will let you out-accelerate what your brakes can handle on a track, EVs do it faster for sure. This is one of the primary skills you learn when you start racing. You can definitely "go faster" in places...but you can't carry more speed into a turn or slow down too late from a higher speed. It won't work. You increase the speed, you have to increase the distance at which you start to slow down...by a lot. There's likely not a tire/brake combo that will handle slowing from 170 down to what was required for that turn for that weight of car, which would be the same if it was a AMG E or M5.
Current: 2018 Camaro SS 1LE, 2023 Colorado ZR2. Former: BMW 428i Gran Coupe.
06-29-2022, 06:59 AM | #17 | |
Rep 3,909
Removing all the factory safety features without cage, harness, helmet etc is similarly moronic. |
06-29-2022, 07:11 AM | #18 |
Rep 3,241
He's referring to regenerative braking. When I did the UDE this year, they had us run the course initially in "B" mode which is with regenerative braking active. I also got to run the course with "B" mode turned off.
06-29-2022, 07:12 AM | #19 |
Rep 3,241
What track has police respond to a crash? Unless there was something special about this crash?
06-29-2022, 07:32 AM | #20 |
Rep 3,909
06-29-2022, 12:18 PM | #21 |
Rep 910
06-29-2022, 01:30 PM | #22 | |
Rep 3,675
^ Great video and the ending sums up the current state of car design. |
