05-01-2022, 01:38 PM | #177 | ||
Rep 5,733
Drives: '24 iX50; '23 i4 M50
'24-I20 iX 50; '23-G26 i4 M50; '22-G82 M4Cx*;20-G05 M50i*; '20-F82 M4CS*; '18-F80 M3CS*; '18-F80 M3CS*; '18-F85 X5M*; '18-G01 X3M40i*; '18-F80 M3ZCP*; '17-F80 M3ZCP*; '15-F15 X5*; '15-F82 M4*; '12-E92 335is*; '11-E70 X5d; '11-E89 Z435is*;'09-E89 Z435i*; '08-E92 335i*; '06-E90 330i*; '05-E83 X3*; '04-E83 X3*; '03-E46 325Ci* *retired |
05-01-2022, 02:36 PM | #178 |
Rep 298
05-01-2022, 02:58 PM | #179 |
Rep 5,733
Yeah, I was confused. He mentions 8% off on a "2021" but it appears he just ordered, so IDK if he was referring to his old one or new one
07-02-2022, 09:46 AM | #180 |
Rep 27
Double checking
I have read this thread, but thought I'd ask to make sure I it right.
I have a dedicated 20 amp circuit/outlet in a convenient location. Not really needing to future proof because I am old
Many thank to all who contribute here. Have learned so much. |
07-02-2022, 12:14 PM | #181 | ||
Rep 8,700
Drives: eVeRyOnE mAD!
hi. maybe take a look at this charger instead? https://www.napaonline.com/en/p/NBCSC1455 it's less expensive and also has level 2 charging capability if you need/have access to it (requires 20A NEMA 6-20P outlet). can also use the Tesla adapter EDIT: I no longer recommend this device due to safety concerns! Last edited by nZtiZia; 01-30-2024 at 12:03 PM.. |
toofargone15.00 SomeClown18.00 |
07-02-2022, 12:48 PM | #182 |
Rep 6,805
A 16A/120vac device SHOULD have a plug that will only plug into a 20A receptacle. Not all of them do, and they may also not have a UL approval. Actually, that's fudging it a little as the device itself has an internal powersupply and if the vehicle drew 16A, the total could exceed that 80% rule, but generally, the EVSE doesn't draw much, maybe 10W for a simple one, and maybe a little more if it has a display and WiFi capabilities.
But, using the 80% rule, on a 15A circuit, you should safely be able to draw up to 12A. Telling the vehicle to pull less may help if the circuit is not dedicated. Power = volts * amps, so increase either component, and you'll be sending more power to the X5, and should shorten the charge time. |
toofargone15.00 |
05-15-2023, 05:03 PM | #183 |
Rep 2
Just picked up a X5 45e and been reading that Tesla is looking to either kill the ability to use an adapter, or switching to the universal plugs.
Both of those things would let me *not* spend $150-250 on an adapter. Is there confirmed info or general consensus on what comes next? Thanks in advance |
05-15-2023, 06:55 PM | #184 | |
IS350 to IS-F to M3 and M4
117
Rep 803
05-15-2023, 07:45 PM | #185 | |
Rep 3,681
As for "kill the ability to use adaptor", I think this applies to their new destination L2 EVSE only. They are adding authentication for Tesla car because it is free. But I think it is only for newer units. Older unit, I still still charge my 45e
2022 G05 B58/PHEV
+ a few very old BMWs |
06-14-2023, 12:57 PM | #186 |
Rep 60
Resurrecting this thread just to confirm my plans and see if there is anything I'm missing -- as I like to say, I never underestimate my ability to get things wrong.
So I live in a townhouse with a dedicated carport parking spot about 75'-100' from our front door. I have been charging my '22 X5 45e with level 1 charger using a 10-gauge, 20 amp extension cord off a dedicated 20 amp circuit -- not an ideal solution, but it's worked. The stars have aligned, and the concrete sidewalk surrounding our carport is coming up at the same time we are completely redoing our front courtyard, so we have an opportunity to have an electrician lay a 240V cable to our carport. It will be capable of running 50 amps off my panel. I know the 45e can only pull 16 amps, but I would like to future proof and get the max charging ability in case we buy a fully electric car in coming years, or if we sell the house. We are the first in our 63-home townhouse cluster to install a charger in our carport, so we're pioneering things around here. So I think I have settled on buying a hardwired ChargePoint Home Flex charger, which is capable of charging from 16-50 amps. https://www.chargepoint.com/drivers/...BoC8oQQAvD_BwE Is there any reason not to go with this one? Is there anything else I should be considering in the installation? TIA |
06-14-2023, 05:35 PM | #187 |
Rep 6,805
Rather than putting in a socket, I'd prefer to just have a junction box and hard wire the thing. While it won't prevent theft, having to deal with the hot wires and then remove the box when it's hard wired would present another thing to help avoid that...plus, it's less likely to have issues with the higher current an EVSE can provide.
Should you decide to move and want to take it with you, even without a plug, it's like a 5-minute thing max to disconnect the wires...shut the breaker, remove the junction box's cover, remove three wire nuts, put them back on the supply wires, put the cover back on and it's disconnected. Should you choose to put a receptacle in, insist on one made out of Bakelite versus the much less expensive plastic ones sold at big box stores. |
06-17-2023, 09:33 AM | #188 |
Rep 3,806
Random plug for Grizzl-e's warranty and customer service. My charger just randomly stopped working, all the terminals metered out as they should all the way back to my power plug - it was clearly something internal on the board. I had a replacement within 3 days, customer support was great to work with.
Something to consider when buying a charger - if it breaks, how will the warranty support be, and how fast can I get a replacement? |
01-30-2024, 12:01 PM | #189 | |
Rep 415
The Schumacher's appear to be identical to the cheaper Lectron, but with a 7' longer cord. I've not decided whether that 7' is worth the extra cost, but I'll likely go with one of these. Mark
2022 X5 45e - Wife's daily driver
2023 GX460 - My daily driver 1988 4Runner on 40's - Off-road trailer queen 2001 PSD Excursion - The slave that drags the queen |
01-30-2024, 12:14 PM | #190 | |
Rep 8,700
so far, it appears only the OEM level 1 EVSE by APTIV included with the 45e actually responds to the charge rate changes in iDrive jad03060 purchased an EVSE capable of charging faster than 10A on level 1 where one can select a lower charge rate on the device itself, and i believe it's been working as designed. |
ScaldedDog338.00 |
01-30-2024, 06:08 PM | #191 |
Rep 6,805
The level 1/2 devices typically come with a standard 120vac plug on it. Technically, when operating at 16A, it should have a different plug on it. But, on those plugs, ground is still ground. A level 2 device expects the two power leads to be 'floating' rather than having one of them tied to ground at the panel. I think that is what confuses the X5, for the thing to work, the two power leads are always floating. The current limiting only seems to work with properly configured devices. To support 16A, you need at least a 20A circuit. On a standard 15A circuit, you should only pull a maximum of 12A.
This is the one I bought. I think that it may have had some changes since I bought mine about a year ago. https://www.amazon.com/gp/product/B0...e?ie=UTF8&th=1 |
ScaldedDog338.00 |
01-30-2024, 07:13 PM | #192 | |
Rep 415
1) Do you have the 5-15P model or the 6-20P model? 2) If the former, can you confirm that you are able to turn down the charge amperage from the device? I'm just looking for a 16A Level1 EVSE for our place in FL, where I have a 20A circuit available. If I can turn down the amperage to 12A, then I can travel with it, too, though we probably won't actually do that much. Mark
01-30-2024, 07:50 PM | #193 | ||
Rep 3,681
I am a bit confuse. If you are looking for 120V EVSE, then the plug has to be 5-15 (5-xx) version, right? The 6-20 (6-xx) is 240V plug (EVSE with this plug must be L2). Did I understand you correctly?
2022 G05 B58/PHEV
01-30-2024, 08:37 PM | #194 |
Rep 415
Sorry. Yes, I am looking for a 120v EVSE, but the one @jad03060 linked had the 6-20 plug. That may have just been an oversight, or an Amazon thing, since since the 5-15, 6-20 and 14-50 models can all be purchased from that same page.
I suppose there might be an EVSE out there that comes with a 5-20p plug, but I've never seen one. Given the choice, I'd rather have a 5-15 plug, anyway, if the amperage can be stepped down. Mark |
01-30-2024, 09:55 PM | #195 | |
Rep 8,700
NEMA 5-15 model is level 1 only (120V)** NEMA 6-20 and 14-50 models are level 2 only (240V) **per the details, charge rate is adjustable 6A/8A/10A/12A/16A on the device itself |
01-30-2024, 10:21 PM | #196 | |
Rep 292
In addition I bought the adapter bundle, which as well contains a 5-20 plug and uses 16 Amp. The 5-20 adapter stand alone is $35. I have used the 5-20 adapter in the FL Keys at an RV site with a dedicated 20 Amp breaker. Didn’t charge it full overnight, but 80% was still quite useful. For sure much better than the standard 10 Amp BMW adapter. |
01-30-2024, 11:14 PM | #197 |
Rep 6,805
It seems that the one I bought is no longer available. The one I have is level 1/2 up to 16A, and adjustable in current to allow for whatever it's plugged into.
I have not looked into what's available today. I originally bought the Schumacher unit, and returned it as it did not allow the X5 to adjust the max current, so would default to 16A, and a 20A circuit was not always available, sort of defeating the purpose. I only use it on trips, as that extra 2A is useful, and sometimes can get me 16A which is 60% more than the OEM unit that came with the 45e (and the 50e). I have a Clipper Creek unit for charging at home, but the portable unit, I thought might be a useful backup should that one die for some reason. That CC unit is almost 10-years old now and still going strong. Bottom line, not all level 1/2 units will allow the X5's logic to adjust the maximum current, at least with the software in the 45e...the 50e MIGhT be different. |
ScaldedDog338.00 |
01-31-2024, 07:23 AM | #198 | |
Rep 415
The L1 version will work fine for me. Realistically I'd never use it when traveling, anyway. I've started just using Battery Control set to 100% when we travel for multiple days, and that works great. Mid 20's mpg, 400 miles of range and a full battery when I arrive if I need it. Mark
