01-29-2022, 12:37 PM | #23 |
Rep 98
It looks like you basically save a few hundred dollars by buying this amp off of eBay vs buying the BimmerTech amp with a mounting bracket that fits. Is this the only difference between these two setups (as it pertains to the 45e)
02-01-2022, 09:16 PM | #25 |
Rep 12
silverstar335501.50 |
03-04-2022, 12:22 PM | #26 |
Rep 143
Thanks for this write up, Is there anything missing from this list below to setup the same setup?
1. 7DSP Amp https://www.ebay.com/itm/23324804187...gAAOSwhyZcfnMD 2. Wire harness for 1.7 RAM https://technicpnp.com/product/hifi-...audio-systems/ 3. MEC Card Analog https://www.crutchfield.com/p_975MEC...ANALOG-IN.html |
03-04-2022, 07:55 PM | #27 | |
Rep 153
03-04-2022, 10:34 PM | #28 |
11
Rep 46
Drives: BMW X5 G05 40i
2dangerous I'm not seeing it with that price. Still $1349 for PP86DSP AMP/DSP.
03-05-2022, 09:14 AM | #29 | |
Rep 143
This is great and I don't have to fiddle with Ebay items from Europe. Thanks, TT Last edited by twinturbomann; 03-05-2022 at 09:29 AM.. |
03-05-2022, 09:59 AM | #31 |
Rep 143
03-10-2022, 06:46 PM | #32 |
Rep 153
Yes it did and they said it would be $350 more a day after checkout and they won't honor the price posted, so I cancelled the order for now. $999 was good price, at $1350, I need some more convincing
03-10-2022, 09:14 PM | #33 |
Rep 183
I ordered and received my amp and harness from https://www.ebay.com/str/allwoodsaudio . Took a little time to ship from the UK, but everything was in the package except the 50amp fuse, and it was less than $1K. I think they are out of stock now, but you can always reach out to them. The kit didn’t have a bracket, I just rested the amp in the bay and will attach with some bendable metal brackets soon. It’s working great!
03-11-2022, 09:50 PM | #34 | |
Rep 1,340
04-06-2022, 10:47 AM | #35 | |
Rep 517
04-07-2022, 01:26 AM | #37 | |
Rep 88
04-12-2022, 01:55 AM | #40 |
Rep 75
Drives: 2022 X5 4.5e
I first installed the Bavsound speakers ( no woofers) and it was a nice improvement. After that I installed the bimmer tech amp and that really made a big difference. It had a three-dimensional sound and music sounded great wether at low volume or higher volume. The amp upgrade was definitely the bigger improvement of the two. I have heard several people mentioned that they installed the amplifier first and felt no need to replace the HiFi speakers. I think the amp makes more difference than the speakers from my experience. Doing both makes it sound very nice for the money spent.
TE Moore
04-12-2022, 11:06 AM | #41 |
Rep 22
Thanks for this info. A lot of helpful stuff. The amp is OOS with the ebay seller. Definitely going to be one of my next mods when I can get my hands on one.
A question maybe someone can chime into. I looked up what the MEC card slot is and its; "This ANALOG IN extension card provides your MATCH UP 7 Series amplifier with two additional inputs, capable of handling high-level signals from a factory radio as well as low-level signals from an auxiliary source. You can assign these two new inputs into the rest of the amp's 7-channel mix using MATCH's DSP PC-Tool app, or you can use the extension card's 3.5mm jack as an auxiliary stereo input for a portable player or an in-car infotainment system's audio." Do I need this, or why would I need this just out of curiosity? I assume its if I later want to hook up an after market amplifier and subwoofer? I figure any input I wanted to play, I should be able to play through the cars bluetooth. I guess I dont really understand what this part means; "assign these two new inputs into the rest of the amp's 7-channel mix using MATCH's DSP PC-Tool app" Thanks |
cptcolo102.00 |
04-12-2022, 08:10 PM | #42 |
Rep 808
Just spoke to a Bimmertech authorized installer (off their website)...he had bad news...Bimmertech is only selling the amp if you buy the amp and full speaker set. Demand is so high...that they are bundling the two to make a few more bucks. Of course, this is one installer...could be different stories elsewhere.
04-13-2022, 08:56 AM | #43 |
Rep 117
[QUOTE=stikystikyricky;28790736]Thanks for this info. A lot of helpful stuff. The amp is OOS with the ebay seller. Definitely going to be one of my next mods when I can get my hands on one.
Yeah that's my bad sorry. Ordered the last one yesterday... |
04-23-2022, 07:15 PM | #44 |
Rep 627
I purchased the OEM BMW amp bracket and I as I suspected it looks like it is the same one Bimmertech uses. I have not attempted to install in the car yet but the Match amp mounts perfectly using the OEM screw and screw clip. The bracket was $35 from the BMW parts dept.
Note that you will need the special Match backing plate with fins that comes with the Match 7 BMW amp. I contacted Match and they had one laying around that they were kind enough to send to me. |
