02-25-2024, 10:50 PM | #1 |
Rep 73
Will remote starting my vehicle recharge my battery?
This topic just came to my attention and I'm interested to know the answer for.
Been doing so when I'm away for few weeks but someone said it will not charge the battery and sometimes drain it. Curious for the answer and please someone explain the mechanics behind this.
Drive a lot
02-25-2024, 11:04 PM | #2 |
13266
Rep 19,785
Depending how long you are away it won't do a remote start as it starts to shut things down to save the battery. Whether or not it will charge the battery when you start it depends on the state of charge of the battery. The vehicle uses brake energy regeneration so the alternator is on a clutch and only charges when coasting or braking. The exception to that is if the battery is below a certain percentage, 60% is most often stated then it will charge until it reaches a specific percentage, 80% it seems. I would assume even idling in park it will engage if it is below the threshold.
Ninja_H20.50 |
02-26-2024, 08:15 AM | #4 |
Rep 958
It depends.
If you're talking about just the 12v starting battery in a normal vehicle, yes, it will charge the battery. But, because the vehicle is idling, it won't do so very quickly. You'd likely need to idle it for 15 minutes to pick up any appreciable charge. The alternator spins as a speed based off engine rpm, the faster it spins, the more power it makes, typically they don't make their rated power until 2500rpm or so (it can vary wildly based off many factors) If you're talking about the mild hybrid or PHEV battery, then no, it won't. |
Ninja_H20.50 |
02-26-2024, 08:40 AM | #5 | |
Rep 849
The Fxx cars (at least my old F25) used to have a gauge under the tach that would tell you if/when the battery was charging but they seem to have removed it over the years.
M3 - X5 - 911 - Miata - Raptor - Edge
02-26-2024, 08:54 AM | #6 | |
13266
Rep 19,785
tooloud10766.50 |
02-26-2024, 09:06 AM | #7 |
Rep 136
If your starting battery NEEDS to be charged when you are gone for a few weeks you NEED a new battery. A few months, put a trickle charger on it.
02-26-2024, 09:09 AM | #8 |
13266
Rep 19,785
I would agree. I don't use a charger on the M340i when we are gone for a month and have not had any problems.
02-26-2024, 09:17 AM | #9 | |
Rep 80
Drives: 2024 X5 M60i | 2024 M440i GC
On iD8/8.5, comfort and eco modes have the battery charge indicator on the gauge below the power/rpm meter. You can also go to the Live Vehicle app to see charge status.
2024 M440i GC: Dravit Grey, Tacora Red Vernasca, 20" 740M, all packages.
2024 X5 M60i: Tanzanite Blue, Tartufo Merino, 20" 740M, all packages. |
02-26-2024, 09:21 AM | #10 |
13266
Rep 19,785
Excellent, thank you for the info.
