12-10-2023, 10:08 AM | #1 |
Rep 62
bmw restraint system warning help
We had an encounter with a deer the other night. It ran into the car and did some minor damage but the bmw restraint system lights are on.
How can I reset them? Can I reset with BimmerLink? Does it mean that all airbags are currently not working? If I reset the sensor will airbags work again? Any help with this is appreciated. Thanks |
12-11-2023, 10:47 PM | #3 | |
Rep 62
If I clear the code and it does not return, would that mean that the sensor is fine or will it still need replacing? |
12-11-2023, 11:14 PM | #4 |
580
Rep 2,047
Its hard to know the issue without fault codes. If the airbags didnt deploy then fault might be somewhere else. Maybe pedestrian protection was triggered.
Best option is to scan the faults and see what is present after clearing the faults. |
12-12-2023, 12:19 AM | #6 |
2293
Rep 12,569
Drives: Z4 M, X5, GX460
Garage List F15 X5 xDrive35i [8.75]
E86 Z4 M [10.00] F10 550i (Retired) [9.17] F25 X3 xDrive35i (R ... [9.43] E82 135is (Retired) [9.50] E85 Z4 M (Retired) [9.41] E90 328i xDrive (Re ... [9.25] E86 Z4 3.0si (Retired) [9.24] |
How’s the deer?
12-12-2023, 07:28 AM | #7 |
Rep 62
I’m not sure lol!
I saw her cross the road, I stopped but she continued to run and sideswiped the front of the car. Cracked the headlight, grill and front bumper. Rolled over a couple of times, stayed down for 2 minutes, got up and left. So yeah, I’m actually not sure if she ended up dying in the woods. |
12-14-2023, 02:05 PM | #8 |
Rep 62
Code 930a2c
Front left light airbag sensor. I tried to clear with BimmerLink and it keeps failing to clear. Any ideas why? If the sensor is damaged will it not clear? I was thinking it would clear and reappear if it was damaged. |
12-14-2023, 03:49 PM | #10 |
Rep 68
the fault is not going to clear until the damage is fixed and the system is properly working, put the comp claim in and get the car fixed. Until then you are going to be driving with an airbag light and with it being the front impact sensor that could cause issues with the SRS system if something else happens.
GioM2Comp36.50 |
12-14-2023, 03:58 PM | #11 |
Rep 6,304
If no airbgas popped, then the code seem to reference that the sensor or wiring is damaged. I would inspect the sensor and area and take needed actions. Should be straightforward.
If you have BMW ISTA it should tell you better information about the code and a test plan/action to try and resolve the issue. Last edited by TheMidnightNarwhal; 12-14-2023 at 04:05 PM.. |
GioM2Comp36.50 |
