      10-17-2023, 08:34 PM   #1
Six Pot
Six Pot's Avatar
Drives: 1M
2008 135i  [0.00]
2007 BMW M5  [0.00]
1M 8HP AWD Build
Well it’s time to do another one. To be clear this is a clone but has all OEM panels so as proper as it could be.
Found a 2010 E92 335xi victim. At least it’s not a M3 Comp and not a real 1M this time 😂. Yay for another full body harness swap.
High level goals will be to run a M3 DCT rear with a 8HP70x driving the AWD system. Sucks that no one makes a front differential but looking to use xdelete to bias it.
Let the strip down begin!
2011 BMW VO 1M (Currently in pieces for New Build!)
==OLD SETUP==
ViE 3884 | PR | JB4 | EOS Billet Fuel / Manifold | Seibon Hood | Spec Twin | 900IC | Slek Lip / Diffuser | EC7 Wheels | KW HAS | Maddad + GTHaus | P3 | ViE Can
ayao646.00
Yeineken1304.00
      10-17-2023, 10:01 PM   #2
scratchgolf135
scratchgolf135's Avatar
281
Drives: alpine white 135i
Watching closely. Would absolutely love to do this as well. N54 or s65?
      10-18-2023, 07:59 AM   #3
Six Pot
Six Pot's Avatar
Drives: 1M
2008 135i  [0.00]
2007 BMW M5  [0.00]
Will be a N54. There is no simple way to make a S65 AWD unless your committed to fabbing ALOT.
We looked at a DCT AWD solution as well but so many unknowns. 8HP is a tank, more support and knowns.
==OLD SETUP==
      10-18-2023, 11:02 AM   #4
WrathOTM
WrathOTM's Avatar
552
Drives: BMW 128i
Interesting build. Good luck on this one!
Mods to date: The list grows...
      10-21-2023, 05:46 AM   #5
PRTSB1M
Drives: AW3 1M
Interesting. Do you know which brakes you're going to run yet?
      10-21-2023, 02:19 PM   #6
Six Pot
Six Pot's Avatar
Drives: 1M
2008 135i  [0.00]
2007 BMW M5  [0.00]
I have another set of E92 M3 brakes but I may try the Porsche BBK route.
==OLD SETUP==
PRTSB1M303.00
      10-23-2023, 05:27 PM   #7
A97syclone
Drives: '11 128i
sweet! We can be 1M clone AWD buddies
Six Pot417.00
      10-30-2023, 07:26 PM   #8
Six Pot
Six Pot's Avatar
Drives: 1M
2008 135i  [0.00]
2007 BMW M5  [0.00]
Ripping the Xi apart, including the door looms and handles for CAS. Hoping to have it 100% gutted this weekend
==OLD SETUP==
ayao646.00
      10-31-2023, 02:28 AM   #9
nriash
Drives: BMW 507
High level goals will be to run a M3 DCT rear with a 8HP70x driving the AWD system. Sucks that no one makes a front differential but looking to use xdelete to bias it. mario games
Oh my god, how are they? Can it still be used?
      11-18-2023, 10:01 PM   #10
Six Pot
Six Pot's Avatar
Drives: 1M
2008 135i  [0.00]
2007 BMW M5  [0.00]
Car #1 broken down and done!
==OLD SETUP==
ayao646.00
Yeineken1304.00
      11-20-2023, 10:39 AM   #11
PRTSB1M
Drives: AW3 1M
If you run 3.45 gears in the rear instead of 3.15, you can probably equalize the ratios by running slightly taller tire up front than in the rear... which is how M cars were setup pre MDM.
ayao646.00
      11-27-2023, 07:54 PM   #12
Pyrat_1M
PYRAT
Drives: BMW 1M
Threads like this make me hate RHD.
TiAgAu150.00
      12-29-2023, 08:41 AM   #13
Six Pot
Six Pot's Avatar
Drives: 1M
2008 135i  [0.00]
2007 BMW M5  [0.00]
Finally making a dent during the holidays and gathering/ordering more parts. Next is to rough in the wiring and start rebuilding.
==OLD SETUP==
Yeineken1304.00
      12-29-2023, 10:59 AM   #14
changster
33
Drives: BMW E82 1 Series M Coupe
Wow, sick turbo kit. 4N right? BW 8474?
I'm very curious about the spool of this turbo. It's a big turbo.
      12-31-2023, 04:49 PM   #15
Six Pot
Six Pot's Avatar
Drives: 1M
2008 135i  [0.00]
2007 BMW M5  [0.00]
Yes 8474 is the smallest kit they offer. From what I have read it should spool like a 6266 due to the internal WG and boost controls.
==OLD SETUP==
      01-04-2024, 02:42 PM   #16
PRTSB1M
Drives: AW3 1M
255/35 Front
295/30 Rear
This setup is almost the same height with rear being ~1-2mm shorter, and available from most tire manufacturers in both 18" and 19" fitments. Tire pressures could also be setup slightly higher front vs slightly lower rear to help dial in. I use this online tool for calculations, you can compare two ratios and tire sizes side-by-side: https://www.blocklayer.com/rpm-gear
clueby4110.50
      02-23-2024, 03:55 PM   #17
scratchgolf135
281
255/35 Front
295/30 Rear
This is the tire setup I have on my 1m clone. r888r since they're the same diameter.
IG: t_turner64
      04-21-2024, 03:34 PM   #18
Six Pot
Six Pot's Avatar
Drives: 1M
2008 135i  [0.00]
2007 BMW M5  [0.00]
Time to start!
==OLD SETUP==
Appreciate 4
Yeineken1304.00
ayao646.00
      04-22-2024, 04:15 PM   #19
CalvinNismo
CalvinNismo's Avatar
United Kingdom
53
Drives: BMW 135i Coupé
Looks sick! If you can shade any more photos of how that EFR sits next to the chassis rail, I’d love to see them!
1addicts
