04-13-2023, 01:52 AM | #2 |
Check out my Youtube @n55david!
1297
Rep 3,536
Drives: 2017 m240i, 2015 X3 x35i
Do you want to be able to use antilag? Turn it on of you do...
2017 m240i xDrive 10.99@122.86mph bootmod3 stage 2+ ots
2015 335i xDrive 10.95@124.99mph w/bm3 - SOLD 2015 X3 x35i pwg 12.96 catless w/bm3 stage 2 93 ots IG: @n55david For pics and updates! Youtube: @ n55david For videos or Racing etc |
04-17-2023, 02:27 PM | #3 |
Rep 239
Drives: '17 M240i 6MT
A lot of people don't know what antilag is. And when you google antilag, you're going to get videos of rally cars and Forza gameplay. I think an explanation of antilag, and its specific effects on the B58, including reasons you would use it on a B58-powered car, would be useful. You don't owe anyone an explanation, but if all you have to add is cynicism then maybe don't add anything at all. It may be a somewhat basic question on the surface, but it's not stupid.
CT716.00 |
04-17-2023, 03:52 PM | #4 |
Rep 1,020
You need to Google "mhd antilag" to get much more relevant results.
Antilag: Allows you to quickly build a set amount of boost while limiting acceleration, then quickly take off once released. To activate antilag, press and hold the cruise control RES button on your steering wheel and apply heavy throttle. Our antilag strategy will adjust the engine calibration to build boost. Once boost is built, release the button and go! The time required to reach boost target will vary depending on your turbo, but even large upgraded turbos are able to hit high boost within 1-2 seconds! There are also various safeties in place such as coolant temp, EGT temp, max duration per use, and cooldown time between uses. These values, as well as the time delay after button press until antilag activates are all set to safe values for those using the OTS antilag flash option. OTS users will have the ability to adjust the antilag boost target (max value depends on engine). https://mhdtuning.com/products/mhd-s...icense-for-b58 Sounds similar to Launch Control. |
04-17-2023, 05:00 PM | #5 | |
1297
Rep 3,536
04-17-2023, 05:13 PM | #6 |
3042
Rep 1,813
I like keeping the explosions inside my engine..
CT716.00 SpencerC_6MT197.00 |
04-20-2023, 08:37 AM | #7 |
Rep 239
I didn't explain it because I don't know how it works with MHD. I know how anti-lag generally works in a vague sense, but I'm not going to pretend I know how it works specifically for the B58 platform. I was just calling you on being an ass for no reason. The forums are better for everyone if people aren't scared to ask questions. Also note "you don't owe anyone an explanation...". Didn't say you're obligated to answer the question, in fact, I specified the fact that you aren't.
