09-27-2023, 01:01 PM | #1 |
Rep 21
Drives: f15 X535d, f13 650, e39 m5
G05 winter setup
Winter wheel/tire setup in nearly new condition, used for ~8k miles. Used on X5 with the larger Msport brakes. Wheels are (GTS) RAC 508s in 20x9.5 ET 35 in BMW specific lug pattern. This is a square setup. Wheels have ZERO curb rash and are in otherwise perfect condition aside from the occasional light surface mark from drying with a microfiber towel. Added aftermarket BMW center caps to preserve the OEM look. Tires are Michelin Pilot Alpin 5 SUV tires purchased in September 2019, all are 275/45 R20 with very even wear as seen in pictures. Two tires measured >5.24mm and two at >6.33. New is 8-9mm so these have a lot of life left. These tires new are almost $1500, for slightly more than that you’re getting nearly perfect wheels with new (when installed) TPMS and balanced tires. Can be winter ready in 25 minutes in your driveway with a floor jack and torque wrench. |
10-02-2023, 07:31 AM | #2 |
Rep 212
Drives: Raptor
Do you have any picks of them installed on your X5? Also, what part of Jersey are you in?
2024 M2 | BSM | Manual | Instagram
2023 X5 | White 2013 335i xDrive M-Sport | Estoril Blue II | Coral Red - SOLD |
10-02-2023, 02:53 PM | #3 |
Rep 21
Located in 07079. I don’t have pictures installed on my X5, but here is a pic of the same model installed on one. Note this one is running spacers to push the wheels out.
10-13-2023, 10:25 AM | #4 |
Rep 21
Bump
05-22-2024, 02:30 PM | #7 |
Rep 21
Setup was purchased through tire rack.
