08-14-2023, 03:21 PM | #243 | |
14
Rep 38
08-14-2023, 03:54 PM | #244 |
Rep 226
Drives: 2022 BMW X5 M50i
My setup: catless downpipes, resonator delete ,xpipe , exhaust flaps permanently opened with dahler exhaust flap control module.
Exhaust note clip |
Bottom1615.50 |
08-20-2023, 01:23 AM | #246 |
11
Rep 35
Man, the lack of exhaust options for our platform is unfortunate. I REALLY like the daHler setup, but that price tag. I wonder if there is a way to do a setup like hufington has, but keep the factory flaps. hmm
Cruise'n71.00 |
08-20-2023, 07:24 AM | #247 |
Rep 226
08-20-2023, 07:37 AM | #248 | |
Rep 226
Its a cheaper option than dahler but requires more labor and time . |
08-20-2023, 04:28 PM | #249 | |
11
Rep 35
08-20-2023, 05:06 PM | #250 |
Rep 226
It keeps the flaps permanently open or it comes with a remote you can open or close whenever you want, it comes with memory function .
08-20-2023, 05:13 PM | #251 |
11
Rep 35
Ah I gotcha, so instead of opening the flaps and pulling the fuse, you still have the ability to control it. So you kept the stock muffler then right?
08-20-2023, 05:18 PM | #252 |
Rep 226
08-20-2023, 05:24 PM | #253 |
11
Rep 35
08-23-2023, 09:42 AM | #254 | |
Rep 2,079
X-pipe will actually quiter the exhaust, belive it or not. And I know because I went throught all those options. I said in previous post that the m50i resonators are stright pipes inside with one pipe having a bounch of baffle holes. Here is a vid with my leates on, AA catted DP and stock resonator back in. Previous one were. 1- Stock + Resonator delete(Straight Pipes) 2- AA DP + Resonator delete(Straight Pipes) 3- AA DP + Resonator delete(X-Pipe) 4- AA DP + Stock resonator. Video below
08-23-2023, 10:04 PM | #255 | |
11
Rep 35
08-24-2023, 10:54 AM | #256 |
Rep 2,079
I had it without DP on first option. Go to my channel or back on this thread and find the video of stock dp with resonator delete, streaight pips. It was good too. But I wanted the power of the dp.
08-25-2023, 08:41 AM | #257 | |
Rep 1
I think I want to go with just the DP and keep the stock res. However, did you have to get your car tuned after installing the DP's? Were any error codes thrown after installation? |
08-25-2023, 09:10 AM | #258 | |
Rep 2,079
In my case I had a tune first(RC Black GTS) then I installed the DP. But you shouldn't get any code without a tune, they only one you will get ofcourse is the CEL related to the DP if its catless.
08-31-2023, 12:00 PM | #259 | |
Rep 185
Wondering if you've done any mods. I called the HiTech and asked for a price on H pipe and his reply was don't listen to forums on bimmerpost. The videos on here the H is great, also so so so expensive for two prices of straight pipe that people in the USA do for a few hundred... Was between one or two thousand in Sydney. |
08-31-2023, 01:43 PM | #260 |
Rep 466
Drives: 2023 X5 M50i
[QUOTE=yoandry;30426247]FYI,
X-pipe will actually quiter the exhaust, belive it or not. And I know because I went throught all those options. I said in previous post that the m50i resonators are stright pipes inside with one pipe having a bounch of baffle holes. Here is a vid with my leates on, AA catted DP and stock resonator back in. Previous one were. 1- Stock + Resonator delete(Straight Pipes) 2- AA DP + Resonator delete(Straight Pipes) 3- AA DP + Resonator delete(X-Pipe) 4- AA DP + Stock resonator. Video below https://youtu.be/Iu6VYexugbE Sounds good and looks good. Where did you get your exhaust tips from? Maybe have a link? |
09-02-2023, 12:37 AM | #261 | |
Rep 185
What's the chances you would have starts with all of the above with a warm engines? Many of my cars sound good from the factory initially before they warm up. What would your configurator be for someone that wants a V8 sound but not too loud like the last video for my neighbours :-) |
09-13-2023, 09:33 PM | #262 |
Rep 19
Drives: BMW X5 M50i Tesla Model S
I didn’t see this mentioned, but the easiest way to permanently open the exhaust flaps is to use Bimmer Link and open the flaps, then while the flaps are open, remove the fuse F203 … or you can unclip the connector at the flap… I pulled the fuse. It took about 5 minutes and required zero skill. I hear pros and cons, since the flaps open at 4k rpm, but imo it is an improvement- I’ve got H&R springs on my M50i and I am contemplating the catted downpipes and a tune. Wanted to get some miles on her first.
09-14-2023, 12:27 PM | #263 | |
Rep 2,079
Cruise'n71.00 |
09-14-2023, 12:36 PM | #264 | |
Rep 2,079
[QUOTE=Jszlaga;30449344]
Got them from amazon, but these aren't just to bolt on on the factory pipes. Customization are needed. See first link to another thread on exhaust tips option. https://g05.bimmerpost.com/forums/sh...1885392&page=5 https://www.amazon.com/gp/product/B0...e?ie=UTF8&th=1
