04-27-2023, 11:19 AM | #23 |
154
Rep 303
It holds the charge by not using the battery. No charging is done except through coasting or braking. So indeed it removed the hardware needed to charge via the engine. Probably related to the automatic transmission redesign.
04-27-2023, 11:34 AM | #24 |
Rep 97
Charging with coasting or breaking uses the same hardware as changing with the engine.
nZtiZia4674.00 SwissBeemer301.00 |
04-27-2023, 12:05 PM | #26 |
Rep 8,723
Drives: eVeRyOnE mAD!
that’s not possible. HVAC and some 12V components are completely dependent on the HV battery, so it’s being used to power said functions. can’t rely on regeneration alone to maintain the HV battery level when those functions are operating. (heating alone can be a power sucker.)
SwissBeemer301.00 |
04-27-2023, 12:06 PM | #27 |
Rep 8,723
04-27-2023, 12:32 PM | #29 |
Rep 8,723
04-27-2023, 01:41 PM | #30 |
Rep 208
04-27-2023, 03:11 PM | #31 |
Rep 6,835
BMW US headquarters is in NJ...the address should be easy to find.
Regaining the adjustable battery hold functionality might be something that could be enabled via coding...you might consider looking in the BimmerCode options, or sending the author a note asking him if it's possible. IOW, the software switch to enable that functionality MIGHT exist in the software already. |
04-27-2023, 06:19 PM | #32 |
Rep 518
04-27-2023, 06:40 PM | #33 | |
Rep 208
04-27-2023, 07:27 PM | #34 |
Rep 6,835
04-28-2023, 09:20 AM | #36 |
Rep 518
04-28-2023, 09:21 AM | #37 |
Rep 518
I tried the Charging icon after pressing the Battery Hold button and do not see anything regarding a charge level.
04-29-2023, 01:43 AM | #38 | |
Rep 21
I studied good functions in other PHEVs and asked BMW to enable those in the 45e with simple coding instead of expensive mechanical or electrical changes. Do not know why they still stick to some wierd decisions... My focus was improving fuel efficiency (a lot) by letting coasting mode in electric and hybrid modes and it is also better for my personal taste (and some other improvements). Hopefully they will hear customer's voice once |
04-29-2023, 02:07 AM | #39 |
Rep 6,835
FWIW, by judicious use of the gas pedal, and watching the power meter, you can coast...it's just not quite as easy as just letting off on the pedal totally. The i3 I owned was the same way...it did not coast on its own...it went from accelerating to cruising, to coasting, to gradually increasing regeneration. The X5 doesn't have anywhere near the level or regeneration, but because it weighs over 2x as much, there's still power to be made with less deceleration at maximum rates.
