Best cold air intake
07-12-2013, 08:54 PM | #23 | |
Rep 3,732
Drives: BMW S1000XR
BMWCCA member |
07-12-2013, 09:07 PM | #24 | ||
Came to the N55 Darkside
1114
Rep 12,740
Ken nailed it on the head- critical. |
07-12-2013, 09:31 PM | #25 |
133
Rep 1,945
Drives: 2011 335xi Msport, Conv, Tech
Can someone post a e92 bms instate sound clip please?
|11 335XI N55 | M SPORT | VRSF CP | BMW PE | BMS INSTAKE | VRSF 7" IC | MHD STAGE 2+ | ER CP |
07-12-2013, 10:42 PM | #26 |
Rep 460
07-12-2013, 11:21 PM | #27 |
BMW Noob
Rep 111
07-12-2013, 11:43 PM | #28 | |
Rep 163
FYI - the Dinan is currently 20% off. |
07-13-2013, 02:17 AM | #29 |
Rep 645
07-13-2013, 02:27 AM | #31 |
Rep 3,696
07-13-2013, 02:34 AM | #32 |
Rep 3,696
OP, all you need is the following and you will understand:
1) Get a tune (JB4/Open Table Flash/Etc...) 2) Get an aftermarket FMIC + a BMS OCC 3) Get an aftermarket DP (or catless downpipe if you off road) 4) Get supporting mods: *a) DCI *b) Aftermarket metal Chargepipe *c) Aftermarket BOV *d) Meth kit (Make sure your tune supports this) 5) A little e85 mixed in with your premium octane (make sure your tune supports this). * Each one will net you gains and you will be at a reliable 400hp at the end of it all. Let your aftermarket Intercooler do it's job and the DCI will show it's strength, but did you notice where it is in my line up?? |
07-13-2013, 10:26 AM | #33 |
2020 Z4 M40i - 2022 M4C Convt
3129
Rep 5,264
Drives: 2020 Z4 M40i - 2022 M4C Convrt
Garage List 1965 COBRA (FFR rep ... [8.57]
2023 Jeep Wrangler ... [9.50] 2009 Yamaha V-Star [0.00] Cars 2-BMW, 2-FORD, ... [0.00] 2023 Ford Expeditio ... [0.00] 2020 Z4 M40i [10.00] 2022 BMW M4C [7.25] 1998 FORD Ranger 4X4 [0.00] |
Agree they come with a FMIC stock.
Kevin
Dravit Gray, Black Leather, Moonlight Roof, Red Calipers 2022 M4C - 2020 Z4 M40i - 2023 FORD Expedition XLT Max 4X4 400BHP - 2009 V-Star - 1998 Ranger 4X4 5MT - 1965 Cobra (R) 5MT - 2023 Jeep Wrangler Sport S 6MT |
07-13-2013, 10:33 AM | #34 |
1114
Rep 12,740
It is well known that our stock intercoolers are not capable of providing the cooling necessary for optimal engine life, HP, and performance when more aggressive tunes are introduced into the mix.
The stark reality is reduced engine life and overall potential engine component and engine damage and overheating, and loss of power in many cases. Upgrade that intercooler if you plan on tuning the shit out of your cars folks. |
07-13-2013, 10:51 AM | #35 |
Rep 2,556
That's as good of a deal as you're going to find for a new 'best cold air intake.'
OP: threads involving Dinan products always get derailed in this forum. It is the best engineered cold air intake out there for the N54. I have one on my car and will tell you honestly it is a waste of money if you don't have a tune. I also agree with those that recommend a fmic prior to intake. I actually installed a fmic prior to a tune as the oe fmic heat soaks quickly raising iat's thereby causing the dme to retard timing.
2007 E90 335i, TiAg, 6AT, ZPP, ZSP, ZCW, 6FL, HD
Quaife lsd, ETS fmic, GIAC s/w, Dinan intake/exhaust/oc, Koni/M3 susp, Apex Arc 8, Mich PSS |
07-13-2013, 11:09 AM | #36 | |
1114
Rep 12,740
07-13-2013, 11:43 AM | #37 |
Rep 460
I see your points about the intercooler upgrade. Granted I live in SF where it is almost always 50s to 70s. Still need one? Anyway, what is a great and affordable intercooler upgrade for reference so I can start my research. Thanks!
07-13-2013, 11:50 AM | #38 | |
Rep 460
For the BMS Oil Catch Can... Is this just marketing? My car already had 38,000 miles so how would I get rid of the intake gunk that has already accumulated?
07-14-2013, 10:07 PM | #39 | |
Rep 3,696
Next, if your planning to try and clean the stock FMIC or Charge pipe... to get those off you might as well just replace them with after market upgraded parts. Because its work to get it off, you might as well just replace rather than re-use. However, let's say you buy a used FMIC upgrade from someone has lots of oil in it... I'm sure someone on this forum has a DIY for correctly de-greaseing the parts. The more simple alternative would be to just let it slowly blow it's way out of the system on it's own?? I wouldn't want you to do more work than benefit... so I wouldn't attempt to clean what is already in the pipes... just keep it from dumping new oil into it. A nice mod you can do with the charge pipe is to have the Blow-off Valves (BOV) Vent To Atmosphere (VTA), these cars don't require that the BOV air to be re-circulated back into the system as metered air (Like my eclipse GSX did). So you can gain a nice Whhhoooooossssssssssssh sound when you let off the gas if you VTA |
07-14-2013, 10:12 PM | #40 | |
Rep 3,696
07-14-2013, 10:27 PM | #41 | |
Rep 3,696
No stock intercooler will ever do a good job, they build these cars so you have to upgrade those parts (That's why turbo/super charger cars are "tuner" cars). Also OCC are not really emissions legal, but no one checks for them because its not a performance mod (So no one will care that you have it, plus no one will ever see it unless they take apart the shelf below the HVAC filter EVEN THEN they have to know what to look for). The reason we want cold air is because you can pack more volume of oxygen into colder air as opposed to warmer air which takes up more space. More Air + More (correctly matched) fuel + More (correctly matched) Spark = More power. That is why Nitrous and other additives help, they make the air colder so you can pack more air volume in per combustion cycle = Moar Power This lesson has come courtesy of lessons learned via Mike over at Road/Race Engineering in Santa Fe Springs, Ca from wayyyyyy back in the day when they were a small shop. - Faz |
07-15-2013, 12:01 AM | #42 | |
Rep 460
07-15-2013, 12:10 AM | #43 | |
Rep 460
My CPO warranty is ending in March 2014. Should I wait to install my OCC? The BMS OCC is pretty hard to detect because it is under the cowl, so I can't imagine it not passing the visual inspection during smog check. Right? :-) |
07-15-2013, 12:10 AM | #44 | |
Rep 3,696
It's better to have it than not to have it. But the only one recommended hands down is the BMS OCC, no one else. |
