10-03-2023, 11:24 PM | #1 |
Rep 278
How rugged is the X5?
It’s an SUV, but it’s also a luxury highway cruiser. Any thoughts on how much offroad capability the X5 has? Are there specific driving modes for gravel, snow, etc? Anything special about the differential for offroad use? On the stock 20” wheels in base or M sport design, there’s a durable amount for sidewall and ground clearance seems reasonable. Nothing too hardcore, but how would it handle an occasional drive up a gravel hill at a mountainside? Thanks all!
10-10-2023, 11:25 PM | #4 |
Rep 875
I guess I don’t consider a gravel road to be difficult for any car, but this is my second X5 and I would consider them both to be among the worst off road vehicles I’ve ever owned. That’s just not what they’re designed or intended for.
M3 - X5 - 911 - Miata - Raptor - Edge
hotvee141.00 |
10-11-2023, 01:17 AM | #6 |
Rep 278
What did you try to do in in that made it the “worst” offroad vehicle? Ground clearance seems decent, as does xDrive system and chunky base tires.
10-11-2023, 01:55 AM | #7 |
Rep 825
I dunno,the X5 I drove(briefly) at the Performance Center in SC was pretty damn capable especially on that scary ass rock hill climb/descent section. I swear I had that X5 leaning so far over,teetering on 2 wheels I thought I was gonna roll it. That being said,it's not an F-250 or a Jeep so YMMV
-'24 X5MC,'22 430i
-'09 Busa,'05 GSXR-1K(GT28R turbo)'00 Busa(GT3582) Gone but not forgotten: -'22 X3MC,'20 M550i,'18 X2,F30 328xi,'07 E63 AMG (1st W211 63 in the 11s),997 C4S Cab,CLS55 AMG,E55 AMG,C55AMG |
10-11-2023, 08:51 AM | #8 |
Rep 7,548
Know (or learn) the difference between AWD & 4WD (not the same). Also understand the type of tires mounted...are they for offroad use or are they sport tires with low sidewalls & tread patterns designed for track use or spirited highway driving?
There should be at least one video embedded in the iDrive owners manual that shows examples of how iDrive operates. If not, I'm sure there's videos on Youtube about how iDrive works.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 10-11-2023 at 08:57 AM.. |
10-11-2023, 09:31 AM | #9 | |
1229
Rep 1,350
Jeep is the way to fly off-road. |
MissVito217.50 |
10-11-2023, 09:35 AM | #10 |
Rep 99
I've spent a small amount of time on relatively flat pasture. For a relatively heavy vehicle without proper off-road tires it was OK. It isn't anything like the 1st generation MB ML-class, which was actually a pretty darn good off road vehicle (*). But I've also driven worse. The suspension works well in the relatively undemanding areas I've been in.
I'm concerned about the transfer case and so would be hesitant to take it on hard uneven surfaces. There can be a downside of so much power as any kind of binding and you try to plow through can result in things breaking. Otherwise as long as the surface/tires can handle the weight and you take things slow and carefully it seems like it can handle it. (*) Edit - ...for a somewhat heavier luxury vehicle... No, it wasn't a Jeep but would come surprisingly close in everything but ground clearance. Last edited by Gene Horr; 10-11-2023 at 11:35 AM.. |
10-11-2023, 11:56 AM | #12 |
Rep 3,708
Technically, X5 is a crossover not an SUV. It has monocoque body, independent suspension. It is designed to be a on road vehicle, with the capability that if road starts to get a little rough, it will get you home. If you buy X5 and with the goal to use it as an off road vehicle, then I think you are buying the wrong car.
And I would say, for offroad capability, X5 is in the same categories as other crossovers like MDX, RX, Q7, GLE .... It is not in the categories as 4Runner, GX, Wrangler, Range Rover, G wagon ... those real body on frame SUVs
2022 G05 B58/PHEV
+ a few very old BMWs Last edited by eelnoraa; 10-11-2023 at 12:03 PM.. |
TheCookieMonster294.00 cobramite1229.00 ScaldedDog341.00 X3_Alaska154.00 nZtiZia4731.00 tooloud10790.50 MissVito217.50 ERC429.50 |
10-11-2023, 04:00 PM | #14 |
Rep 418
Yep!!
What the OP seemed to describe is just driving on a dirt road, which the X5 will do fine. I have an occasion to do that in ours, and it handles even washboards OK. Even so, doing that enough will turn anything into a rattletrap. Mark
2022 X5 45e - Wife's daily driver
2023 GX460 - My daily driver 2017 JKU Sahara - Beach jeep 1988 4Runner on 40's - Off-road trailer queen 2001 PSD Excursion - The slave that drags the queen |
tooloud10790.50 |
10-11-2023, 04:44 PM | #15 |
Rep 8,812
Drives: eVeRyOnE mAD!
specifications aside, the X5 can likely handle a graded gravel hill just fine, but there’s not enough info here: fine gravel, loose gravel, wet or dry, small or big rocks, tires type and condition? when I read “off-road”, to me that means bouldering for which I wouldn’t use the X5, though the maneuver mentioned earlier the PCD takes it through is pretty impressive, but even so I would think they only take drivers through it “when the conditions are right” (anyone who’s been through it can correct me if I’m wrong)
mark 20:00 |
10-11-2023, 04:52 PM | #17 | |
Rep 1,217
Drives: 2022 BMW X5 45e M-Sport
Edit: I will add that I looked at the tires when we first got to the vehicle we'd be using, and they weren't anything special. Just some A/S (forgot the brand) that were clearly near the end of their life (worn and some cracking), and it still handled amazingly. |
10-11-2023, 11:22 PM | #18 | |
Rep 278
10-12-2023, 10:01 AM | #19 | |
Rep 875
That said, the low profile RFT street tires, the suspension, the weight, and the lack of a proper 4WD system work against the X5 going off road. Can it be done? Probably, but it won’t work nearly as well as any number of other similar vehicles. Heck, my last X5 had this note in the owner’s manual that actually said not to drive the car on unpaved terrain:
CeEl482.00 |
10-12-2023, 07:53 PM | #20 |
Rep 1,254
Drives: 2020 Z4 M40i
And most importantly: European, African or American gravel? 😁 |
10-12-2023, 08:24 PM | #21 |
Rep 438
For what its worth, I live In a ski town and with the right tires I have found the AWD system in deep snow to be extremely capable. Didn't get stuck once year and we had a huge winter.
2022 M3 Comp xDrive - Frozen White
2024 X5 40i xDrive - Black Sapphire Metallic 2021 X5 40i xDrive - Black Sapphire Metallic - SOLD 2012 Audi A4 Avant - SOLD Insta: mtn_m3cx |
10-12-2023, 09:12 PM | #22 |
Rep 231
