E92 M57 timing chain snap - swapping e60 engine
03-19-2024, 02:59 PM | #1 |
Rep 1
I've got a 2008 E92 325D and a while ago my timing chain snapped doing a light pull. I found a low mileage M57 engine from a 2009 e60 that I'm putting in the e92. Does anyone have a list of the things I have to swap from my old engine to the new engine? I know I have to swap engine mounts and the oil pan, is there anything else?
Thanks! |
03-21-2024, 01:41 PM | #2 |
Rep 34
You might need to swap the lower timing cover aswell if i remember correctly due to placement of auxiliaries. This would of course require removing the chain and having tools to do the timing chain job which you should do anyway for a new engine.
Easier just to compare the engines side-by-side when you take them out. Otherwise should be fine, engine wiring of course also you need to change. |
