01-04-2020, 02:51 PM | #24 | |
Rep 419
https://www.bimmerpost.com/forums/sh...php?p=24689610 I may have missed it but I couldn't find it in the driver's manual.
2019 X5 40i M-Sport
07/2020.54 -> 11/2020.50 -> 03/2021.50 -> 07/2021.85 [All OTAs] |
01-05-2020, 01:09 AM | #25 | |
805
Rep 1,790
01-05-2020, 05:13 AM | #26 |
Rep 1,417
https://g05.bimmerpost.com/forums/sh....php?t=1606933
I've had this in my past 3 BMWs, it's not a new thing. The blue battery/line during coasting is showing energy recovery. For some reason I love seeing it come on. BMW explains it better than I could in the driver's guide: "During energy recovery, the kinetic energy of the vehicle is converted into electric energy during coasting. The vehicle battery is partially charged and the fuel consumption can be reduced" (no $hit to the last part, it only works when your foot is off the gas and brake, I'd hope that my fuel consumption would be reduced just from that Maybe that's why I love seeing it come on ) |
01-05-2020, 08:19 PM | #27 | |
805
Rep 1,790
"Energy recovery During energy recovery, the kinetic energy of the vehicle is converted into electric energy during coasting. The vehicle battery is partially charged and fuel consumption can be reduced." |
01-19-2020, 11:40 PM | #28 | |
Rep 810
I'm now getting the identical error. On a related note; maybe coincidence, but it also started after I've subscribed to Drive Recorder App; which uses the car's front/rear/side cameras like a dash-cam. |
01-21-2020, 08:40 PM | #29 |
Rep 810
OK, took my car to the dealer this morning, and this error message relates to low charge in the Battery.
The dealer Service Manager asked me if I was using the car for long period without the engine running, and of course the answer is "no". He put it on a special high current charging unit they have for 1 hour, and all good - error message has vanished. So if anyone gets this error message, it means your battery is drained and low, and just needs a charge. |
01-22-2020, 05:50 AM | #30 | |
Rep 418
Drives: ‘20 X5/M50i (ordered); &
01-22-2020, 05:59 AM | #31 |
Rep 810
01-22-2020, 06:09 AM | #32 |
Rep 418
01-22-2020, 07:47 AM | #33 | |
Rep 1,448
2015 BMW X5 xDrive 50i/XL/CW/DA+/EP/LP/FVS retired; 2008 X5 4.8i; 2012 X5 5.0i retired, 2004 X5 4.4i retired R360c + EL, V1G2 + V1Driver, Uniden R8 |
01-22-2020, 07:55 AM | #34 | |
Rep 810
The only thing that has changed for me in the last 4 weeks is the subscription to Driving Camera service about 2 weeks ago, which uses the onboard front/rear/side cameras as a dash-cam. In theory it shouldn't matter, as the camera systems should shutdown once I lock and walk-away, but I'm suspicious this might not be happening and therefore draining the battery. |
01-22-2020, 11:48 AM | #35 | ||
Rep 802
2020 X5 M50i | 2015 X3 28i xLine | Retired 2013 335i M Sport
03-20-2020, 02:14 PM | #36 |
Rep 1
Power Supply Warning
Having the same issue with 2019 X5 - had it in once to check the power supply warning light, roadside said i only had 7 miles. Dealership was within range so I was able to go there without tow, light shutoff upon arrival. Dealership had it for 3 days, said nothing wrong, drove about 30 miles since and I have nothing connected to any outlets, no drive cam, and power supply warning light came on again. This time roadside said not sure can’t seem to get any reading and wanted to send a tow. Any advice?
03-20-2020, 07:27 PM | #37 |
Rep 810
I had this same warning message almost every day, and I have solved this issue, but does come with some minor inconvenience with respect to one feature.
It is NOT battery related, contrary to what dealers tell you (I was going to call them something but will refrain). I have an an advanced Battery charger that does testing (voltage, CCA..etc), maintenance/trickle charge, reconditioning and normal charging - and my battery was fine when I was getting this message, it was >80% charge and my CCAs were up above 600A. To solve, you need to disable the "lock on leaving" function, the car has an issue with this feature and does not fully shut down properly. This is the feature that uses proximity to detect that you are leaving the car, and locks automatically. "Unlock on approach" is fine, and I have this enabled, however I just use the key fob to lock the car when I get out and walk away. Since using this approach, I've haven't seen this message again. I'm on S/W release 11/2019.34 - and I'm quite happy with this release, but until I'm on a newer version and can verify/test it fixes this issue - I'll keep "lock on leaving" disabled. Last edited by James_G0540i; 03-20-2020 at 07:33 PM.. |
03-21-2020, 05:47 PM | #38 | |
805
Rep 1,790
I have a 2020 X7 on software version 07/2019.59. I've had the car since mid November and have just over 6K miles on the car. I've yet to see any battery issue warnings and I have my vehicle set to lock when departing and have had it on that setting since I took delivery. |
03-21-2020, 07:10 PM | #39 |
Rep 76
Also have a 2019 X5 M Sport 5.0i, and had this message around 6 months ago. It became gradually worse, to the point all electronics started failing with various error messages, and ultimately the car struggled to start in a parking lot. My dealer diagnosed it as my battery needed replacing. It was replaced along with a software upgrade, and I've had no problems since. I suspect the older iDrive software I was running taxed the battery until it failed. Crossing my fingers it doesn't fail again.
2019 BMW X5 50i & 2019 BMW X3 M40i
2016 BMW 435i (retired) 2012 BMW X5 35d (retired) 2008 BMW 550i (retired) 1997 BMW Z3 30i V6 (retired) |
03-21-2020, 08:37 PM | #40 | |
Rep 810
03-21-2020, 08:38 PM | #41 | |
Rep 810
By locking my car manually (ie. via the key fob when I get out), I haven't seen that warning message again when getting back in, and my battery has thanked me for it, because its sitting at a nice 70-80%. What S/W version did they upgrade you to? Last edited by James_G0540i; 03-21-2020 at 10:12 PM.. |
03-22-2020, 08:06 AM | #42 | |
Rep 76
08-09-2020, 04:50 PM | #43 | |
Rep 148
Hi Xeno, was the problem solved? I'm getting the same notice after my battery died and recharged. I also lost my comfort access. Seems only getting it after the car was parked for a few hours. Thanks |
08-09-2020, 05:55 PM | #44 | |
Rep 1,448
The most recent episode was the last few days on a short trip where I had BV in parking mode and did not drive the car very many miles each day after reaching my hotel. I doubt the same will be true next month when most days I will be driving a few hundred miles each day.
babyghost94.50 |
